| How to determine belt length? | |
Jamus Established Member
| Subject: How to determine belt length? August 2nd 2011, 11:37 pm | |
| For those of you who build custom stuff and need a different length belt than stock, how do you determine the correct length? On my murray I've swapped pulleys, both 5" and I changed the clutch setup to a design that needs a longer belt. The stock 96" belt is way too short, it's tight before I even get it on the motor pulley, tight just against the motor shaft. I put all the pulleys on and released the clutch and used rope to measure and came up with 98". This is obviously too short since the small rope fits into the V notched pulleys tighter than a belt does. So I'm kinda stuck, especially since I plan to order the belt online, much cheaper. So is there a foolproof way to get this measurement? | |
| | | noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5373 Posts : 252 Location : DFW Texas
| | | | ferg Member
Join date : 2011-10-24 Points : 4820 Posts : 45 Location : Cheshire, England
| Subject: Re: How to determine belt length? October 27th 2011, 8:13 am | |
| you are going to want to do a bit of maths!! but i use a piece on think ish rope, I also once got a 150 inch belt and cut is in half, I can use it as guide. | |
| | | | Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5468 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: How to determine belt length? October 27th 2011, 10:36 am | |
| - Jamus wrote:
- I forgot I posted this. I ended up cutting a belt to measure with. Ended up needing a 101".
101" ?? How long is your machine??? Man the longest belt I think I've ever needed is 88" lol | |
| Subject: Re: How to determine belt length? October 27th 2011, 4:18 pm | |
| Stock is 96" I think. Then I swapped the double pulley clutch from a hydro murray onto it which requires more length.
| Subject: Re: How to determine belt length? October 28th 2011, 1:24 pm | |
| Thats nothing- the belt on my 42" dynamark deck is about 107" long- thing was longer then the belt mesuring stick at TSC, one of the longest belts they carried. | |
| Who is online? | In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests
