 MTD - "Budgie"
BlakeGroce
diddie
RockeyDA
George Gooding
Dave.MTD
23 posters
Go to page : Previous  1 ... 7 ... 11, 12, 13, 14, 15  Next
MTD - "Budgie"  - Page 12 Empty
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 15th 2019, 9:00 pm
Just keep your eye out, they're not that hard to come by
BlakeGroce
BlakeGroce
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 16th 2019, 10:32 pm
This is gonna be good. bounce
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 18th 2019, 5:30 am
Cleaning out the stock fuel tank i found this probably 30 year old gas can thing someone dropped in, kinda funny. There was a bunch of pieces of float from the gauge cap it has(it's just the cap and the frame thing now) in there too. The petcock at the bottom was plugged but i managed to blow it out. Can't get the valve to close but that's ok. I ran the fuel line (5ft was just enough) and put a little fuel in the tank to let it sit and see if it leaks.
MTD - "Budgie"  - Page 12 20190650
I meant to be doing wiring but i got sidetracked trying to make a pull start out of the booster fan.
As you can see, there's already no room between the clutch and spinny wheel of death to you and your loose bootlaces
MTD - "Budgie"  - Page 12 20190652
So i put the face plate on the lathe, center the fan by pushing it up against the plate with a dead center in the tailstock, and tighten it down with two ¼-20 bolts. I couldn't find a spot to properly indicate this in, as the outer ring is barely round as is. As far as i could tell it had maybe .030" of runout. Not a big deal. This little piece of aluminum won't throw the entire oppy out of balance, especially at only 3600.
MTD - "Budgie"  - Page 12 20190651
Cut the groove, good for two wraps with my signature 3 strand braided baling twine pull ropes. Shouldn't need more than 2 turns if this oppy starts like my other horizontal.
MTD - "Budgie"  - Page 12 20190653
Cut two notches about 180° apart, might try to maintain at least some balance lol.
MTD - "Budgie"  - Page 12 20190654
Bonus-
A look up the frame tunnel when i had the top plate off the frame to put the fuel tank in
MTD - "Budgie"  - Page 12 20190655
The setup i used to drill the cotter pin hole in the rod that the gas tank sits on. I always wanted an excuse to use the tailstock round stock drilling atatchment thing.
MTD - "Budgie"  - Page 12 20190656
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 19th 2019, 2:45 am
Made a pair of cross supports then discovered i can't get a mower battery with the engine tins on. Decided to go to a motorcycle battery i got a few months ago. Made the little battery box for the motorcycle battery.
MTD - "Budgie"  - Page 12 20190657
Battery fits in easily.
MTD - "Budgie"  - Page 12 20190659
Wired everything from scratch in about an hour. Key switch has an extra position, used it for the one working headlight. Zip tied it in wire loom, looks pretty neat compared to anything else i have.
MTD - "Budgie"  - Page 12 20190660
After the wiring i got her running and took her for the first test drive with a rigged throttle(runs great). Clutch didn't want to work because the belt was out of position for the keepers to work. No big deal. Fuel pump pulled fuel through 5ft of line and a foot of rise and filled the bowl in a couple seconds of cranking. Anyone who says oppy fuel pumps are trash are clearly ignorant.
On to the foot throttle. Using the same one as before with the integrated belt keepers. The cable kept slipping past the screw so I just drilled a hole though the manifold to feed it through. This is actually the first time I've seen this governor setup on a horizontal and i don't like it. Anyways with the same return spring i was using before and some adjustments it works really well. Cranked the gov screw to get some extra rpms too.
MTD - "Budgie"  - Page 12 20190661
Added some belt keepers to the existing keeper/gas pedal tree. Haven't tried it yet but there's no reason for it not to work.
All systems on the oppy are nominal even after sitting as long as they did- ignition, charging system, starter, and I guess governor if you wanna count that. Got pretty lucky with this one.
A skidplate for the trans and bottom of fuel tank is looking like a good idea right now. As well as a new front axle bolt to tighten up the steering- she does get death wobble sometimes.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 19th 2019, 12:31 pm
Interesting, I have one of those fans already with a pull rope slot. I could not seem to get enough RPM's to get Red started with it, so I put it back to stock.
MTD - "Budgie"  - Page 12 02041810
I have contemplated putting an Alternator in "Patriot". Just not sure of placement at this time. You have yours on the drive belt, I wonder how belt slip affects it? Granted, it should only slip while clutched.
MTD - "Budgie"  - Page 12 Sig115PROJECTS:
MTD - "Budgie"  - Page 12 Sig214MTD - "Budgie"  - Page 12 Sig314
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 19th 2019, 12:55 pm
All of the boosters I've had didn't have the notch. I woulda just put a pulley on like i have on my RER with the oppy and booster fan.
Maybe I'm a bit younger guy and can pull it faster or my engine is in better shape, but she always starts first pull with the choke on.
I think i tried the alternator like once on a battery. The 10si was a bit much for the 6hp but it didn't slip so much. The 10si is a bit much for the motorcycle battery, I'm gonna take it out and put the idler back in place that I had. If anything here needs help with the charging system, it's Mutt. I have a rectifier from a vanguard for her.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 19th 2019, 9:03 pm
Take your fuel filters seriously folks, only took 20min of running without one to make this thing start surging. It was an easy cleaning though and she's back to running like new.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 23rd 2019, 1:27 am
Messed up the clutch a bit from running over a log.
This oppy really seems to make a lot of heat. The hood gets hot to the touch if it runs for more than 20min. Hopefully this will go away when I get the muffler out from under the hood.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 26th 2019, 3:00 am
I know it'll help at least some.
I'll get this thing in the shop after i fix/get tired of mutt. Something needs to be done with the clutch pedal/booster fan, as they got in a fight once when the table i put in the shop shoved the clutch pedal over into it. Along with the actual clutch issue lol. Might rework the pedal entirely.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 1:29 am
Fixed the clutch issue.
MTD - "Budgie"  - Page 12 20190664
Did a stupid and drilled into my gas tank. I ran out of words to insult myself with. Pair of flat uhmw or nylon plastic washers and a ¼-20 bolt and she seems to hold.
MTD - "Budgie"  - Page 12 20190665
Grease and a piece of copper tubing helped getting the nut on the inside of the tank.
MTD - "Budgie"  - Page 12 20190666
At the moment I'm making a ball hitch/bumper type deal. That's why i was drilling the back plate. My first back bumper ever really. I'll get a pic when i get at least tacked
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 3:44 am
I'll cut the ends down eventually but for now this is what it'll be.
MTD - "Budgie"  - Page 12 20190667
I'm gonna take some inspiration from Allis and not paint it, as almost nothing else is painted on this rig. Maybe someday I'll paint this whole thing, idk though. The burgundy is starting to grow on me
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 8:43 am
Atta boy!! MTD - "Budgie"  - Page 12 1098998679
Haha, looks good!
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 2:59 pm
I think i have room in front of the bumper for an ammo can. That'd be cool, I'll have to try that
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 3:16 pm
I've done stuff like drill into a gas tank before. It happens lol.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 4:16 pm
Yeah sucks lol.
Ammo can fits in with a bit of cutting
MTD - "Budgie"  - Page 12 20190668
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 29th 2019, 10:16 pm
So the flyhweel side main seal leaks pretty bad on this, might've been why it was put out of commission. Front left side of the frame is coated. It's not severe but it's not good. I imagine the pressure lube is feeding the oil right out there as that bearing does get oil from it.
This thing does wheelies like mad with a trailer behind it. Mutt does too, but this has a bit less weight on the front than mutt. Guess I'll see what i can do about that soon.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 30th 2019, 1:22 pm
I was fully aware it'd be somewhat of an issue but i wasnt gonna move the hitch down to fix it and ruin my departure angle
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJune 30th 2019, 8:24 pm
Put the bumper to the test today. Works nice. Steering is manageable
MTD - "Budgie"  - Page 12 20190670
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 3:25 pm
Leak in the left rear tire is getting progressively worse. Might need to get a tube for it or find some new tires to replace these old mudlights.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 3:39 pm
Did you ever try Tire Sealant? That stuff's amazing!
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 3:42 pm
Don't resort to the dreaded Slime!
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 3:45 pm
I'm not doing tire puke. There was some of that garbage in these tires when i got em.
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 3:47 pm
Yeah yeah whatever.
If I only had some pics of the tires I've brought back with it....
And it only "pukes" for a few days, then it stops. But I'm obviously never going to convince you on how good it is, so why not try that "Great Stuff"...
PostSubject: Re: MTD - "Budgie"    MTD - "Budgie"  - Page 12 Icon_minitimeJuly 2nd 2019, 4:00 pm
Why would i make my life a living hell when i inevitably take it off when i could put a tube in it now and it'll last forever?
MTD - "Budgie"
Page 12 of 15Go to page : Previous  1 ... 7 ... 11, 12, 13, 14, 15  Next
