| MTD - "Budgie" | |
+19BlakeGroce diddie TheBeal RockeyDA Buck Creepycrawler prancstaman George Gooding SebastianAlbrecht MightyRaze muckmudd Crazy_Carl Dave.MTD Double W Cross Ranch AllisKidD21 biggasmowers CraftsmanQuad19 MatthewD RichieRichOverdrive 23 posters |
Crazy_Carl Veteran Member
| Subject: Re: MTD - "Budgie" August 2nd 2018, 10:50 pm | |
| I'll probably get one for like a max of $50 here at the next local auction.
No carl, I'm talking gx390 or bigger. I already have a 6.5 i could put on er. | |
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
| Subject: Re: MTD - "Budgie" August 3rd 2018, 7:33 pm | |
| looks good man, if you have any more belt issues build you a belt brake, wheel horses have them factory and they make shifting much nicer, sears have a variation of it too, I usually add them to my clutch systems if they dont have them factory. basically just a belt guard that pinches the belt at the very end of the clutch pedal movement, so that when you push the clutch completely down it pinches the belt a bit to slow/stop the belt so you can shift easy | |
| Subject: Re: MTD - "Budgie" August 3rd 2018, 8:31 pm | |
| Thanks. I get what you mean. Dont think I'll need it. Gas pedal i made kinda inspired by the one on Alliskid's MTD | |
| Subject: Re: MTD - "Budgie" August 3rd 2018, 9:31 pm | |
| I like it! Looks pretty good. Neat how you incorperated the belt guide you made into the pivot and stuff for the foot throttle. Good thing you made it outta heavy steel in that case. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD - "Budgie" August 3rd 2018, 10:10 pm | |
| Thanks. That piece was just the closest to mount it to, so thats where i mounted it. It needs a little bit of support but i have a really simple idea on how to do that lol.
So the steering on this thing is absolutely terrible...not sure what I'm doing about that yet | |
Age : 23 Join date : 2018-02-27 Points : 3846 Posts : 1299
| Subject: Re: MTD - "Budgie" August 4th 2018, 10:19 am | |
| Hmm, someone clearly doesn't know surface rust when he sees it. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD - "Budgie" August 4th 2018, 5:38 pm | |
| I dunno where the two ignorant ones got the idea that it was really rusty it's not. | |
Buck Member
Join date : 2017-11-01 Points : 2882 Posts : 282 Location : Eastern Ontario
| Subject: Re: MTD - "Budgie" August 4th 2018, 7:31 pm | |
| - Buck Mault wrote:
- that's not rust that's patina
once I said to keep the patina, Rich said it's uglier than my mom, and now he tells the opposite??? | |
| Subject: Re: MTD - "Budgie" August 4th 2018, 9:32 pm | |
| Welded a stop on the gas pedal and put a stronger spring on, feels a lot nicer. I also put a return spring on the brake lever, which I'm not sure if that's staying but it works for now. Took this thing out, has a whopping top speed of 12mph... lol. The front end jumps like mad on pavement when i try to do a sharp turn, a problem i never had with mutt. It really needs some more weight on the front... a bumper maybe? | |
| Subject: Re: MTD - "Budgie" August 4th 2018, 10:20 pm | |
| Rig is looking real good Rich.
[adm]I am not warning or pointing any fingers. Please be courteous with each other as to not cause unneeded frustration.
Thank you. [/adm] | |
| Subject: Re: MTD - "Budgie" August 5th 2018, 3:14 pm | |
| So it wants to lift the front end in the air when you accelerate? Yeah sounds like a robust front bumper would kelp that or a K series 10hp or bigger.
I like the gas pedal. Looks like it won't collect too much crud.
Are you thinking about swapping steering from another tractor into this one? | |
| Subject: Re: MTD - "Budgie" August 5th 2018, 3:17 pm | |
| I mean when I'm turning the front wheels hop because of the locked diff and light front end lol | |
| Subject: Re: MTD - "Budgie" August 9th 2018, 9:21 pm | |
| So the little bit I've driven this thing, I've figured out that the steering absolutely SUCKS. Too much slop, and it skips kinda easily. I wish i hadn't wasted that worm box on Mutt, it would probably have done fine on here. I have another two worm boxes, one is like 30:1 and the other has like 3/8 input and output shafts so that won't really do. Might be able to steal the steering outta the LT18RS project, it's the same thing as in Mutt too. I'm not sure if i wanna use that on this build yet, we'll see. | |
| Subject: Re: MTD - "Budgie" August 9th 2018, 9:27 pm | |
| I would think 30:1 would be too low of a ratio really. I love me a low steering ratio but there's a line, haha. Maybe this rig could get a rack and pinion? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD - "Budgie" August 9th 2018, 9:34 pm | |
| Rack in pinion would go in Mutt before jt would get anywhere near this one, lol | |
| Subject: Re: MTD - "Budgie" August 9th 2018, 9:37 pm | |
| Hahaha, I coulda bet money that you were gonna say that. But yeah I guess a rack would be pretty awesome in ol' MUTT. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD - "Budgie" August 9th 2018, 9:48 pm | |
| So steering upgrade for MUTT then take MUTT's steering and drop it into budgie? | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3561 Posts : 825 Location : In the shop
| Subject: Re: MTD - "Budgie" August 10th 2018, 6:54 am | |
| Could. Just gotta get a rack first lol | |
| Subject: Re: MTD - "Budgie" August 18th 2018, 4:32 pm | |
| Put the hood on it Tacked on a turn down for the exhaust. | |
| Subject: Re: MTD - "Budgie" August 18th 2018, 5:01 pm | |
| Now I knew why U always destroy everything in few seconds....
Cuz U beat everything as hard as U can..... | |
| Subject: Re: MTD - "Budgie" August 18th 2018, 5:12 pm | |
| Sebastian, if you call that abuse, I couldn't even imagine what your reaction to actual abuse is.
I didn't even hurt anything on it doing that. Hell, i couldn't hurt anything on it doing that. If your mower breaks doing what I was doing, you need to face the fact that it's a piece of sh*t and you need to fix it so it won't break at the slightest hint of real offroading. | |
| MTD - "Budgie" | |
