 Wheel Horse Charger 8
10 posters
Go to page : Previous  1, 2, 3, 4, 5
Wheel Horse Charger 8 - Page 5 Empty
PostSubject: Re: Wheel Horse Charger 8   Wheel Horse Charger 8 - Page 5 Icon_minitimeMay 2nd 2018, 1:14 pm
MightyRaze wrote:
How is the gasket between the intake and block.
Other things to look at if gasket is good and the bolts are tight.  Is your gas cap venting propery?  Loosen it see if it smoothens out.  Filter looked good.
Yeah ill check it out, I think the gasket was ok. I think if I spray carb spray on the gasket area & it bogs down that could be the issue.
PostSubject: Re: Wheel Horse Charger 8   Wheel Horse Charger 8 - Page 5 Icon_minitimeFebruary 25th 2019, 8:40 pm
Put some ATV rims and tires on my little wheel horse (lawn ranger), they are 20" tires, I re-drilled the rims to the 5 bolt pattern. It worked out ok, I wont say its perfect but I only use this little one to run around with occasionally... I was a few mins from running bigger but I would have had to take off the rear fenders and do something crazy, its a pretty little tractor.
Wheel Horse Charger 8 - Page 5 Img_1814
Wheel Horse Charger 8 - Page 5 Img_1816
Wheel Horse Charger 8 - Page 5 Img_1815
PostSubject: Re: Wheel Horse Charger 8   Wheel Horse Charger 8 - Page 5 Icon_minitimeFebruary 26th 2019, 6:43 pm
They look good on there. Did you get the backfiring issue sorted out?
PostSubject: Re: Wheel Horse Charger 8   Wheel Horse Charger 8 - Page 5 Icon_minitimeFebruary 26th 2019, 9:10 pm
running pretty good now, sat for a long time, since last spring... Anyway it is not very useful for much so I only ride it around just to see its running, but I might mess around more since the tires are worth a crap now....
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
» [Finalist] [22 BO] MN MUDDER Wheel Horse Pulling tractor "HORSE N AROUND"
» Destructive's 1973 Wheel Horse 12 (Wheelin Horse)
» Wheel horse work horse mud rig
» 74 Wheel Horse C-100
» wheel horse 14 hp
