| manual trans-axle | |
Dustin138 Member
Age : 27 Join date : 2011-06-15 Points : 4977 Posts : 40 Location : Upstate NY
| Subject: manual trans-axle July 12th 2011, 2:41 pm | |
| I am looking to replace my hydro trans-axle with a manual one. I have a craftsman lt1000. Does any one know where i could get the manual trans-axle for it. Or if any one know of a manual trans axle that willfit the lt1000 and it has to have the shifter on the right rear fender. I dont want to spend hundreds of dollars either. | |
| | | Fattypipemuarry Member
Age : 29 Join date : 2011-06-02 Points : 5039 Posts : 62 Location : Russell County Kentucky
| Subject: Re: manual trans-axle July 12th 2011, 4:28 pm | |
| the shifter an stuff dont matter you may just have to make your ownn an bout any rearend will work craftsman an muarry are the same make have to rig somthin up | |
| | | noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5375 Posts : 252 Location : DFW Texas
| Subject: Re: manual trans-axle July 12th 2011, 5:08 pm | |
| - noledroByrreK wrote:
- i have a craftsman lt1000 with a manual transaxle. lemmee go look and i will get you the part number. you can use a tranaxle from almost any mower tho as long as you have the tools. would probable need somethin to cut with and a welder
or you can even find the same transaxle on another brand mower because craftsman does not make there one transaxle. mine is a tecumseh | |
Age : 45 Join date : 2010-06-28 Points : 5808 Posts : 511 Location : Southern WV
| Subject: Re: manual trans-axle July 12th 2011, 8:06 pm | |
| Seems like there are 2 major types or brands of transaxle, the tecumseh/peerless or the spicer. Either one has different models but they are similar, different number of gears. Check out www.surpluscenter.com in the power transmission section. They sell a few different kinds and have specs and pics which may be useful. | |
| Subject: Re: manual trans-axle July 12th 2011, 10:32 pm | |
| oh i didnt get the model number yet but i believe its a peerless 200 6 speed | |
Age : 54 Join date : 2010-02-10 Points : 7078 Posts : 1726 Location : Florida, USA
| Subject: Re: manual trans-axle July 14th 2011, 6:53 am | |
| Cheeper alternative might be around the corner- look around for a similar model tractor with like a bad motor - most tractors ive gotten were under $50 .
If modding the tractor- it also makes sense to dump the old gear oil/grease and prep it for severe duty- ive broken one when i left the old grease in it. | |
| | | Dustin138 Member
| Subject: Re: manual trans-axle July 14th 2011, 11:32 am | |
| My grandma has some old lawn mower that the engins dont work. I will see if they have any working trans-axles. Also i found a lawn tractor on craigslist with a broken motor. So i might be able to find a trans-axle. | |
| Who is online? | In total there are 82 users online :: 0 Registered, 0 Hidden and 82 Guests
