 [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
Camdg2010
Dave 007
17 posters
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Empty
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 8:40 am
finally got the frame & subframe all stitched & bolted up.... gonna try and get my rear wheels built today so I can roll the thing around & hopefully test drive & make some decisions about pulleys etc.
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0512
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0510
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0511
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 9:44 am
You going with a single belt or try to do multibelt? If single, that will be a lot of belt to sag. Maybe a lot of belt keepers. Smile
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Sig115PROJECTS:
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Sig214[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Sig314
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 3:19 pm
Yeah two belts with a jackshaft or double idler connecting them in the middle seems like the way to go.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 9:32 pm
got one of my rims done... hopefully by end of week have a roller....
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0513
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 9:38 pm
I bought a super huge one... i am planning on running two extra idler pulleys and seeing how it goes....
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 29th 2018, 9:56 pm
Sweet! How you gonna do the shifter linkage?
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 30th 2018, 7:44 am
I am not 100% but I am pretty sure I am just going to weld a tab where the current shifter is and use another one further up, which will have some kind of push pull action. I might put the shifter under the seat or somewhere else that doesn't hang outa mile like the stock..
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 30th 2018, 4:54 pm
Yeah I had a problem with belt sag and belt flapping on my Westwood, solved it by putting an idler along the belt, which keeps the belt tensioned in the middle. How are you modding the rims?
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 30th 2018, 7:26 pm
I just watched @Camdg2010youtube videos on his homemade gators almost identical to this using craftsman frames.  He used a FF idea and used the deck height lever for a slap shifter.  The linkage looked really simple to fabricate.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 31st 2018, 8:38 am
I just did the ol' cut the center out of a 8" rim and weld it inside the 12" rim.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 31st 2018, 8:45 am
Ill have to check that out, I have a hydro axle so I think it will be easier... I did rip out my deck lever so I could move all the wiring under the gas tank.. The kohler engines have more wires/relays and such... I still want to use the factory ignition switch with it, and I will have the battery under the seat or something.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 31st 2018, 10:03 am
weird my kohler only has a kill wire, charge wire, and ground.  Pretty simple my rectifier is mounted on the motor and I cut the needle off the evil soleniod valve on the carburetor.
Camdg2010
Camdg2010
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeJuly 31st 2018, 11:36 pm
well good news. i figured it out! and it runs like brand new!. gotta adjust the tracking again. hopefully tomarrow i can post a video of it driving
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 4th 2018, 10:04 pm
oooOOO no did some work on the wiring, and mounted the rear tires!! front tires are just rollers for now... Got to do some more frame stiffening has a bit of flex to it, but i need some tube on it anyway to mount the seat etc.....
anyway as you can see I got some 12" rims from a scotts tractor and just mounted up the 25's!
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0517
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0516
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 4th 2018, 10:07 pm
Looks good on four wheels, can't wait to see it with the bed on.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 5th 2018, 4:29 pm
So you found 12" rims for 3/4" keyed shaft after all? nice.
Do you have any design ideas for the bed?
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 5th 2018, 9:44 pm
yeah they are from a scotts mower... anyway the bed i have is a trailer, so I am just going to use a pillow block so that I can tilt it back. It is going to be manual lift, no fancy stuff....
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0610
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 6th 2018, 9:29 pm
Yeah I would put the pivot point about where that axle is to make it easy to dump manually with a full load.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 7th 2018, 12:10 am
Looks good, what welder are you using? looks like flux core.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 19th 2018, 8:59 pm
yeah i am the flux splatter master...
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 19th 2018, 9:01 pm
Did some work on the wiring and hood this weekend, getting done what I can before I need to go buy some tube... I have a simplicity shroud which I will have to blend into the craftsman, probably use some fiberglass and bondo to make it look right....
[Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Img_0617
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 21st 2018, 12:17 am
I like the simplicity hood.
Are you going to raise the seat up or make it a lowrider?
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 21st 2018, 7:21 am
Haha I have a donor simplicity I want to pull the running boards off & the seat mount.. then decide how much tube I am going to need to mount the bed. So its just sitting there for now, I want to put a removable seat in the bed so that two people can ride around the property in it.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 21st 2018, 6:08 pm
Nice, I would move the seat up some, but have no fenders under them because on other rigs where people did that, it looks quite odd.  I like the bench seat idea.
I'd do a winch lift on the bed, like this guy.
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 21st 2018, 6:38 pm
What if you put the seat at the stock distance from the dash, and where the fenders would normally go put some big ammo cans on either side, almost like saddle bags
PostSubject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] - Page 2 Icon_minitimeAugust 23rd 2018, 12:34 am
Muahahaha, me too.
Page 2 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]
» [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
