| Simplicity Mouse | |
+9TheBeal MightyRaze Crazy_Carl muddstir Double W Cross Ranch AllisKidD21 biggasmowers CraftsmanQuad19 mrshaft696 13 posters |
biggasmowers Veteran Member
| Subject: Re: Simplicity Mouse February 8th 2018, 9:17 am | |
| Nice ! I have a carb that is the previous version of the one you have, its quite interesting but i don't think i am going to put the time in to clean it up because of how old and brittle the seals all are. | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4060 Posts : 870 Location : Phillydelphia
| Subject: Re: Simplicity Mouse February 8th 2018, 12:17 pm | |
| - biggasmowers wrote:
- Nice ! I have a carb that is the previous version of the one you have, its quite interesting but i don't think i am going to put the time in to clean it up because of how old and brittle the seals all are.
yeah they are called a flow jet carb, pretty gigantic compared to OHV carbs & others I have. | |
| Subject: Re: Simplicity Mouse February 10th 2018, 8:37 pm | |
| yeah ok the fawking rear wheels are suck.... | |
| Subject: Re: Simplicity Mouse February 10th 2018, 8:39 pm | |
| Yep, that always sucks big time. I've had to cut 'em off before, it's a real pain. Anti-Seize goes on afterwards for sure, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5982 Posts : 2645 Location : Indiana
| Subject: Re: Simplicity Mouse February 10th 2018, 9:08 pm | |
| Ooh I hate when they stick to the axle. Now that I look at your hood though, almost looks like an international or a Massey Ferguson. Mine looks a little like a baby sears SS series | |
| Subject: Re: Simplicity Mouse February 10th 2018, 9:40 pm | |
| im gonna try a few more things, I saw online some guy using some kind of puller to take them off, I am not sure what it was for though.... Basically a bolt in the middle and a clamp that goes around the keyway bulge... | |
| Subject: Re: Simplicity Mouse February 10th 2018, 9:41 pm | |
| The rim has two holes 180 degrees apart right? See if you can make a rim puller. That’s what I’m gonna do on the spare MSTs I have | |
Crazy_Carl Veteran Member
| Subject: Re: Simplicity Mouse February 10th 2018, 9:45 pm | |
| i’ve had good luck using heat and a puller with the two holes in the middle. The rim was stuck on so bad that the metal deformed around the holes but the rim was OK. | |
Age : 49 Join date : 2016-09-06 Points : 15676 Posts : 10987 Location : Oklahoma
| Subject: Re: Simplicity Mouse February 11th 2018, 12:39 pm | |
| Ok I forgot I had a pulley puller set, and this thing was in it, and it worked good. Oh and yes it had to pee, oil leaked into the intake & I had to pull the carb again and clean the oil out of it, stupid move.... | |
| Subject: Re: Simplicity Mouse February 11th 2018, 12:46 pm | |
| I need one of those...what did that run you? | |
| Subject: Re: Simplicity Mouse February 11th 2018, 6:51 pm | |
Last edited by mrshaft696 on February 12th 2018, 8:36 am; edited 2 times in total | |
| Subject: Re: Simplicity Mouse February 11th 2018, 7:29 pm | |
| - mrshaft696 wrote:
- Ok I forgot I had a pulley puller set, and this thing was in it, and it worked good.
That's just like the one I borrowed one time from the electric motor repair shop at Kodak Industrial Park. It worked great. | |
| Subject: Re: Simplicity Mouse February 11th 2018, 7:49 pm | |
| Those tires don’t match lol, but they oughta work. I like that craftsman too. And thanks for the link, I appreciate it | |
| Subject: Re: Simplicity Mouse February 12th 2018, 7:13 am | |
| - CraftsmanQuad19 wrote:
- Those tires don’t match lol, but they oughta work. I like that craftsman too. And thanks for the link, I appreciate it
Haha thanks, I am very well aware. I didn't have time to mount all the tires I needed, that one was a spare I have the other matching ones.. The atv rims are much harder to get the tires off of, compared to tractor rims. They are very flat and wide. | |
| Subject: Re: Simplicity Mouse February 12th 2018, 9:20 am | |
| On my simplicity there wasn't a fancy recitfier or reguator either. There was one wire for charging the battery and another wire for headlights. When I first got the tractor only the charging wire was hooked up because it didn't have headlights. I hooked up the other wire to the headlights through a relay that was controlled by a switch. | |
| Subject: Re: Simplicity Mouse February 12th 2018, 1:03 pm | |
| - Crazy_Carl wrote:
- On my simplicity there wasn't a fancy recitfier or reguator either. There was one wire for charging the battery and another wire for headlights. When I first got the tractor only the charging wire was hooked up because it didn't have headlights. I hooked up the other wire to the headlights through a relay that was controlled by a switch.
I thought it had to have a diode somewhere to convert the voltage or something.... | |
| Subject: Re: Simplicity Mouse February 12th 2018, 1:42 pm | |
| I recall there being a small diode in the wiring harness coming from the motor but it was a long time ago and I don’t have the tractor anymore. | |
| Subject: Re: Simplicity Mouse February 12th 2018, 2:13 pm | |
| - Crazy_Carl wrote:
- I recall there being a small diode in the wiring harness coming from the motor but it was a long time ago and I don’t have the tractor anymore.
Yeah I have to look at all the wiring I ripped out again and see if there is one hidden somewhere. | |
| Subject: Re: Simplicity Mouse February 16th 2018, 7:10 am | |
| None of the carbs I have messed with lately are close to the same, the OHV carb, Opposed carb, & flo draft carb. Figuring out why I have parts left over after the rebuild is the hardest part. | |
| Subject: Re: Simplicity Mouse February 16th 2018, 8:44 am | |
| Yeah, that may not be a good thing unless you used a rebuild kit. | |
Age : 24 Join date : 2016-12-30 Points : 4931 Posts : 1944 Location : Kansas
| Subject: Re: Simplicity Mouse February 16th 2018, 10:43 am | |
| I opened up an oppy carb and it was full of white powdery flakes from having water in it for years, once i cleaned it a couple times it ran fine tho, i think it was a 4 bolt carb cause it didnt have adjustment screws like the older ones do.
I really like the looks of this little tractor . | |
