Snapp Dragin RER Mudding pre build
+2 Double W Cross Ranch
6 posters
Author Message biggasmowers Veteran Member
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas Double W Cross Ranch Veteran Member
Age : 20Join date : 2017-06-09Points : 5492Posts : 2640Location : Literally Nowhere, Texas biggasmowers Veteran Member
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas CraftsmanQuad19 Veteran Member
Age : 24Join date : 2016-04-12Points : 5981Posts : 2645Location : Indiana RichieRichOverdrive Mod erator
Age : 22Join date : 2016-10-29Points : 7221Posts : 4020Location : Lewisburg, KY Subject: Re: Snapp Dragin RER Mudding pre build January 27th 2018, 10:04 pm Looks excellent, I love Snappers. You should rename it the NeckSnapper lol. If it's gonna be a dragster I wanna see a wheelie bar! Haha
Age : 20Join date : 2017-06-09Points : 5492Posts : 2640Location : Literally Nowhere, Texas Subject: Re: Snapp Dragin RER Mudding pre build January 27th 2018, 10:08 pm CraftsmanQuad19 wrote: Ooh...I see slicks. That means dragster. What kinda speeds you hoping for? How come he calls it a mud build then?
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas Subject: Re: Snapp Dragin RER Mudding pre build January 27th 2018, 10:43 pm no, sorry. the slicks are shot, but i am going to use the rim(s) for mud tire(s). I dont want to blow the foote up with high speeds
Age : 20Join date : 2017-06-09Points : 5492Posts : 2640Location : Literally Nowhere, Texas Subject: Re: Snapp Dragin RER Mudding pre build January 28th 2018, 9:17 am Well you can always just keep the stock pulley ratio, then put a 60 tooth sprocket on the trans and a 10 tooth sprocket on the axle. You'd go super fast, and not have to worry about blowing having to pick gears up out of the road.
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas mrshaft696 Established Member
Join date : 2016-07-10Points : 4059Posts : 870Location : Phillydelphia Double W Cross Ranch Veteran Member
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas Subject: Re: Snapp Dragin RER Mudding pre build January 29th 2018, 9:31 am Thanks lol, it should be a fun build to ride around on if it doesnt win at least Nope , its not going to be reverse but might be a trike
Age : 20Join date : 2017-06-09Points : 5492Posts : 2640Location : Literally Nowhere, Texas mrshaft696 Established Member
Join date : 2016-07-10Points : 4059Posts : 870Location : Phillydelphia biggasmowers Veteran Member
Age : 20Join date : 2017-06-09Points : 5492Posts : 2640Location : Literally Nowhere, Texas Subject: Re: Snapp Dragin RER Mudding pre build January 29th 2018, 2:18 pm biggasmowers wrote: Nope , its not going to be reverse but might be a trike Just a thought, Scag makes a 3 wheel mower that is FWD with a rear wheel that steers. Would work if you want to make it reverse.
VIDEO
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas Subject: Re: Snapp Dragin RER Mudding pre build January 29th 2018, 3:27 pm i was thinking about doing that but id get mud and stuff thrown into my face lol, and it would get stuck easy with little weight on the axle.
Age : 22Join date : 2016-10-29Points : 7221Posts : 4020Location : Lewisburg, KY Subject: Re: Snapp Dragin RER Mudding pre build January 29th 2018, 11:17 pm A few other brands made mowers like that. They came before the modern day ZTRs. You could work out weight distribution with engine and seat placement, it wouldn't be too bad.
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas biggasmowers Veteran Member
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas Subject: Re: Snapp Dragin RER Mudding pre build January 30th 2018, 1:19 pm Parts! this is slightly the look i am going for, but it will get mud tires which will be the most costly and probably the only thing i will have to buy for it aside from welding rod/wire, angle grinder disks,new brake mechanism hardware( 12 bucks),and paint. what color should it be ? i dont want red ,black,or green, but what color would look best for a mud dragster look? Super ready for the build off to start in a DAY!!!!
Age : 24Join date : 2016-12-30Points : 4930Posts : 1944Location : Kansas MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15675Posts : 10987Location : Oklahoma Sponsored content
