| pressure washer yammy. | |
+4CraftsmanQuad19 mr.modified RichieRichOverdrive muckmudd 8 posters | |
Crazy_Carl Veteran Member
| | | | muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3562 Posts : 825 Location : In the shop
| Subject: Re: pressure washer yammy. Mon Nov 05, 2018 11:18 pm | |
| - Crazy_Carl wrote:
- What has you concerned the most about building the throttle?
Not having a cable, twister or way to attach it. | |
| | | Liftedlawnrider New Member
| Subject: Re: pressure washer yammy. Wed Nov 07, 2018 10:44 pm | |
| That gear ratio looks a lil sketch, but to each his own. You could probably just put a dirt bike carb and throttle assembly on the engine, although just using stock carb would be cheaper. | |
| Subject: Re: pressure washer yammy. Thu Nov 08, 2018 6:09 pm | |
| - Liftedlawnrider wrote:
- That gear ratio looks a lil sketch, but to each his own. You could probably just put a dirt bike carb and throttle assembly on the engine, although just using stock carb would be cheaper.
Just going to see if t works or not to start with. | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5718 Posts : 1402 Location : Central PA
| Subject: Re: pressure washer yammy. Thu Nov 08, 2018 7:32 pm | |
| You can get a cheap CVT off of ebay, the backing plate should bolt right on to that engine. I think that would be something to plan to get. | |
| Subject: Re: pressure washer yammy. Fri Nov 09, 2018 3:00 pm | |
| - TheBeal wrote:
- You can get a cheap CVT off of ebay, the backing plate should bolt right on to that engine.
I think that would be something to plan to get. Still going to be upwards of 100$ that I don't really want to spend on this project. | |
| Subject: Re: pressure washer yammy. Sat Nov 10, 2018 12:35 pm | |
| - TheBeal wrote:
- $65ish?
Always an option for a future upgrade at any rate. Cound'nt find one for cheaper than 100$ CAD so far. | |
| Subject: Re: pressure washer yammy. Fri Dec 21, 2018 11:51 pm | |
| Sent this bike off as a part of a trade. It wasnt worth much but it helped. I'll be making a new thread soon. | |
| Who is online? | In total there are 37 users online :: 1 Registered, 0 Hidden and 36 Guests RichieRichOverdriveMost users ever online was 412 on Sat Jan 07, 2023 6:59 am |
