 Transaxle with Pressure Clutch
Transaxle with Pressure Clutch Empty
PostSubject: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 10th 2016, 2:23 pm
Evening,
Surfing through ebay, found this - Transaxle with pressure clutch fitted
It appears to be a Peerless 900/MST series trans fitted with a 'Pressure Clutch' on top of the pulley.
Never seen one of these before.
Anyone know how these work, what's the advantage of them over a belt clutch?Ride-On-Mower-Gearbox-With-Pressure-Clutch-Fitted
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 10th 2016, 3:26 pm
I imagine it would work the same as a car type clutch. Your v belt wouldn't need a clutch, just would need to be tight all the time. "Real" style clutch like this would be much less hassle than a v-belt clutch setup. Honda liquid cooled lawn tractors have a setup sort of like this from the factory and of course cub cadets are a more popular example.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 10th 2016, 3:55 pm
Yeah, it's a pretty neat deal. Anyone ever seen one of these before?
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 12:56 pm
The trans in my Rat Rod had one of these setups on it. The friction disk was too wore out though, so I had to do away with it.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 1:33 pm
Interesting. Was that the 600 in your Rat rod or the previous trans?
From the research I've done, it's two friction plates that ride together when the cable is pulled.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 1:48 pm
Interesting, never seen a setup like that.
I wonder if it would be prone to slipping when submerged.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 1:55 pm
Yeah it was on the 600. Kinda wish I'd kept that old clutch haha.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 4:31 pm
It probably would slip, unless you could stop water/mud getting into the disks somehow.
Cool, I'm sure it is very hard to find parts for it though. Probably cost the earth to get a new disk or whatever it needed.
PostSubject: Re: Transaxle with Pressure Clutch   Transaxle with Pressure Clutch Icon_minitimeDecember 11th 2016, 4:41 pm
Yeah that's pretty much what I thought at the time.
» Using the pto clutch as a drive clutch
» pressure washer yammy.
»  Tranny locked up under pressure?
» Adding Amp and Oil pressure Gauges On Lawn Tractors?
