| pulley swap on a hydro | |
Dustin138 Member
Age : 27 Join date : 2011-06-15 Points : 4975 Posts : 40 Location : Upstate NY
| Subject: pulley swap on a hydro June 29th 2011, 10:37 pm | |
| can i do a pulley swap on a lawnmower with a hydrostatic transaxel
its a 2005 craftsman lt1000 with a hydrostatic trans-axel | |
| | | Fattypipemuarry Member
Age : 29 Join date : 2011-06-02 Points : 5037 Posts : 62 Location : Russell County Kentucky
| Subject: Re: pulley swap on a hydro June 29th 2011, 10:39 pm | |
| - Dustin138 wrote:
- can i do a pulley swap on a lawnmower with a hydrostatic transaxel
its a 2005 craftsman lt1000 with a hydrostatic trans-axel you can but them come stock with like a 4 inch so you really need a bigger front pulley an leave the back on the same you cange it you will get everything in there hot cause it has a fan type thing on the pulley that cools it i ran in to that promble on my dads mower wanted to mow faster lol | |
| | | Dustin138 Member
| Subject: Re: pulley swap on a hydro June 29th 2011, 10:44 pm | |
| - Dustin138 wrote:
- so i can change the front pulley but not the rear pulley.
yea man it is the safest way cause of that fan thing get in the chat room | |
| | | Dustin138 Member
| | | | redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6376 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: pulley swap on a hydro June 30th 2011, 12:50 am | |
| nooooooooooo sorry you cant speed a hydro up!!!! you will blow up the hydrolic pump in the rearend and your tranny wont work anymore | |
| Subject: Re: pulley swap on a hydro June 30th 2011, 12:28 pm | |
| - redzz02 wrote:
- nooooooooooo sorry you cant speed a hydro up!!!! you will blow up the hydrolic pump in the rearend and your tranny wont work anymore
you can to a little not all that much but you could put a 4 on the front | |
| Subject: Re: pulley swap on a hydro June 30th 2011, 2:41 pm | |
| Depends on the model as to what size pulleys you have. For example I have 2 murrays, one manual, one hydro. The manual has a 3" engine pulley and a huge(12"?) tranny pulley. The hydro has a 5" engine pulley and 3" tranny pulley. This might also prove useful for others looking for cheaper pulleys, since the rest of the hydro mowers are about worthless for what we do. | |
| | | Guest Guest
| Subject: pulley swap on a hydro June 30th 2011, 4:14 pm | |
| Go big on the tires.. That will get you a little more speed. If you want to go stupid fast...you could do a chain drive from the tx to sprokets to drive the wheels. You will need to do at least an 8" lift to pull this off |
| | | Dustin138 Member
| Subject: Re: pulley swap on a hydro June 30th 2011, 7:04 pm | |
| i am getting bigger tires.....and so i can change the engine pulley from a 3 inch to a 4 inch | |
| Who is online? | In total there are 75 users online :: 0 Registered, 0 Hidden and 75 Guests
