 pulley swap on a hydro
WellThatsSurprising
greener179
crafsmankiller
avrappy
11 posters
avrappy
pulley swap on a hydro Empty
PostSubject: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 12:46 pm
I have a power kraft tractor and it has a 4" pulley & I want to put a 2" or so on it. I don't need it to go fast, just speed it up alittle. Will it help? I will be useing it for pulling a trailer and work.
crafsmankiller
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 1:20 pm
If you pulley swap a hydro you'll blow the pump inside it, and if you dont blow the pump you will seriously shorten its life. and you wont get much speed out of it anyways, they have a pressure release inside them.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 1:23 pm
so wouldn't you have to pull out the tranny and remove it?
greener179
greener179
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 1:37 pm
Hydros will go faster pulley swap it will last if you dont go over board on the pulley
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 4:26 pm
I wouldn't. No no no. Just buy a cheap manual transaxle.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 4:29 pm
so like my hydro is a 1:1 what would a good Ratio be?
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 4:31 pm
I agree with WTS... sell the hydro on craigslist and buy a peerless manual. It will be worth the effort on the conversion.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 4:48 pm
I would swap in a manual transaxle. Even if it is a FNR. Ive blown one hydro just mowing my lawn.
Just go on Craigslist or to a junkyard and look for a broken mower. Chances are it will just need a carb cleaning. Then youll end up with an extra body, engine, and a better transaxle.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 9:23 pm
I must be lucky the hydro in my tractor is from 06 never been repaced and never skips a beat so when it dies then I would get a manuel perless.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 9:41 pm
Iv got a hydro in mine it does fine but its not pully swaped.
I agree with WTS i would swap it to a manuel.
Chopperhed
Chopperhed
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 6th 2013, 11:06 pm
Hydro transaxles are rated to operate at a set rpm and pressure.
Changing pulleys changes nthe RPM and pressure. There is a relief valve in the system to prevent over pressure situations.
Changing out the pulley to increase RPM increases pressure, which causes the relief valve to start relieving. Problem is, relief valves are not regulators. Constant use of a relief valve tears up the sealing surface, making it inoperable, hence the pump starts bypassing, and the hydro system fails.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 7th 2013, 12:37 pm
You dont need to swap pulleys - you need to adjust the pedal linkage to increase the speed - if any faster then that, then swap in a manual trans.
Hydro transmissions already run a small pulley - the pulley on my 99 hydro murray is about 3 1/2" and its stock ( I know this because the trans case actually forms around the pulley).
greener179
greener179
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 7th 2013, 2:35 pm
i had a hydro it over revd and i could get going almost 13mph
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 7th 2013, 4:43 pm
What also helps with my tranny is the stock tires were 20" now they are 22" tires so I go a little faster than normal
avrappy
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 7th 2013, 10:35 pm
Thanks for all your imput. The mower has a 4" pulley now How small can I go? 3 or 2 1/2?
Chopperhed
Chopperhed
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 7th 2013, 10:40 pm
All of the above said don't bother, think on that
Stick with the stock pulley, go with taller tires.
Pulley swaps don't really work on Hydro transaxles. Unless you want to kill it.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 8th 2013, 1:16 am
I honestly would do a small pully swap for some added pressure but not alot though and it would give some speed not alot.
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 8th 2013, 9:22 am
Yeah you could do a small pully swap but nothing crazy.
You could try a size smaller but im not sure if it will gain speed.
dked41
dked41
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 8th 2013, 12:07 pm
If you have your heart set on a pulley swap, just do it. When the tranny fails, find a good manual trans and swap them out. Just remember a junk hydro is worth nothing, and a good working one is worth enough to cover the swap to a manual trans and more!!
PostSubject: Re: pulley swap on a hydro   pulley swap on a hydro Icon_minitimeFebruary 8th 2013, 12:36 pm
what is hard to figure out is that the pulleys are 3 1/2" pulleys 1:1 and I would put a pully on the motor not tranny. What pulley size would you recomend doing for a small pulley swap?
» pulley swap on a hydro
» Pulley swap hydro?
» hydro swap out
» mtd pulley swap
» Pulley Swap
