 K361KOHLERS 4X4 WHEEL HORSE
K361kohler
7 posters
K361kohler
K361KOHLERS 4X4 WHEEL HORSE Empty
PostSubject: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 12th 2017, 4:01 pm
K361KOHLERS 4X4 WHEEL HORSE Img_5810
K361KOHLERS 4X4 WHEEL HORSE Img_5812
K361KOHLERS 4X4 WHEEL HORSE Img_5814
K361KOHLERS 4X4 WHEEL HORSE Img_5813
K361KOHLERS 4X4 WHEEL HORSE Img_5811
This will be my ATLTF 4x4 wheel horse entry. It will have a hydro front and rear transaxles. The front will be narrowed and have a custom steering. Heres a list of the parts
Vampire EDL fronts and rears
KT17 kohler with 2 into 1 header
This one will be a shorter wheel base then my other mud mowers
Lifted 6 inches front and rear
Light strips inside the hoods
Removable neons so i can take them off when i go mudding
Led headlights and taillights
Front winch and maybe rear winch
front bumper
rear rack
ungoverned hand throttle
and whatever else i think about
this project will take a while but will be done and boggin by the end of the buildoff
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 12th 2017, 6:10 pm
This sounds like it could be really cool! Have ya given any thought to maybe adding a suspension setup?
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 12th 2017, 8:21 pm
Cool! Sounds like quite the build. Can't wait to see this come to life!
K361KOHLERS 4X4 WHEEL HORSE Sig115PROJECTS:
K361KOHLERS 4X4 WHEEL HORSE Sig214K361KOHLERS 4X4 WHEEL HORSE Sig314
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 13th 2017, 12:30 am
Suspension would be difficult,having the front clutch operate with the rear clutch will be difficult enough,thanks hopefully it is really cool and will be unstoppable when it's done!!! Can't wait to get started on it
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 13th 2017, 7:37 am
Yeah I figured it'd be a real challenge, but I had to ask hahaha. Cant wait to see 'er take shape!
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 13th 2017, 7:03 pm
So I will have a live axle mounted under my transmission so I can speed it up a little,so I can have a 60 tooth on the transmission then a 40 tooth on the live axle and that will speed it up!!!! It will also make my steering ALOT easier to do,just waiting to get approved so I can start working on it
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 17th 2017, 3:09 pm
Still waiting to start on it,waiting for my post to get approved
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 17th 2017, 5:42 pm
I'm not sure who exactly approves the builds usually, but could be the admin's just have been busy. I'll look into it for you.
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 18th 2017, 7:27 pm
Ok thanks,Doug said he would approve it by the weekend but nobody has
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 18th 2017, 9:46 pm
Hey, the weekend isnt done yet! I gotchu. Sorry for the wait.
Craftsman1998
Craftsman1998
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 18th 2017, 9:53 pm
looks like it'll be a fun build good luck Smile
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 21st 2017, 9:10 am
It will be a fun but expensive build,I want to go with gorilla silverback 28x10-12 rear tires,and 6-12 duro fronts,plus axles,chains,sprockets,pulleys,brakes,and pillow blocks,it would cost way too much,oh yeah. I have only found 1 u joint that will work for 45 degrees and 1" shaft keyed,but it is $300 a piece,so if you guys have a better idea for my front steering using a live axle let me know,also thought about a cv shaft but they are also expensive,so let me know if you know a cheaper u joint or a cv shaft
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 21st 2017, 9:30 am
You could try to find some used stuff somewhere if you had a place to do that. Get a U-joint from the steering off a junk car or something like that. Might have to weld a shaft to it afterwards on one side or the other possibly.
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 21st 2017, 10:33 am
golf cart rack and pinion... also look for PTO universal joints at an AG store like rural king or tractor supply. instead of 1 inch keyed, look for 3/4 inch square, and grind a square profile on the end of the shafts
K361kohler
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 23rd 2017, 12:13 am
Yes,but still those won't get the angle I need out of them
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 24th 2017, 11:27 pm
What about using two of them? even if you had to make a "throw away" welded together setup.
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJune 25th 2017, 1:14 am
yup, 2 45's instead of a 90
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeJuly 31st 2017, 10:06 pm
Hey K361Kohler! Any luck with your u-joints or cv-shafts? Any new pix of the build? Hope wrenching has gone well for you!
PostSubject: Re: K361KOHLERS 4X4 WHEEL HORSE   K361KOHLERS 4X4 WHEEL HORSE Icon_minitimeDecember 2nd 2017, 1:29 am
I have unlocked your thread and moved it to the [ Off Road ] section, feel free to keep updating it.
» old wheel horse
» Destructive's 1973 Wheel Horse 12 (Wheelin Horse)
» Wheel horse work horse mud rig
» wheel horse 14 hp
» My wheel horse- needs a little fix
