 Rpms on onan
Kleatus
7 posters
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms on onan   Rpms on onan Icon_minitimeMarch 13th 2017, 4:50 pm
Does anybody know how to increase rpms on a B48m onan
http://Kolbyrector@icloud.com
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 13th 2017, 5:29 pm
Should have an adjustment on the throttle linkages somewhere. I wouldnt mess with the Onan too much, if something blows replacement parts are $$$$$$$$$$
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 13th 2017, 5:41 pm
3600 rpm max for an opposed onan... they are extremely strong and built to lug (torque rather than high rpm HP)  the 18 hp onan actally producrs about 26 hp at 3600 rpm
they were designed to be run continuously at 1800 rpm, and HP was rated at that rpm
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 13th 2017, 7:30 pm
I agree with what is said, also my Onan if rev'ed too high will vibrate pretty bad. If speed is what you want, I'd look into pulley sizes.
Rpms on onan Sig115PROJECTS:
Rpms on onan Sig214Rpms on onan Sig314
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms for onan   Rpms on onan Icon_minitimeMarch 13th 2017, 8:23 pm
No it's for a pulling tractor the class it will pulling in is the 16-18 stock modified
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpm for onan   Rpms on onan Icon_minitimeMarch 13th 2017, 8:24 pm
So where will it produce the most horepower
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpm for onan   Rpms on onan Icon_minitimeMarch 13th 2017, 8:27 pm
I was only gonna rev it at about 4000 rpm is that to much
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 13th 2017, 8:38 pm
Are Onan engines pressure lubricated? If not I wouldn't wanna rev it too high without any oil mods.
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms for onan   Rpms on onan Icon_minitimeMarch 14th 2017, 9:07 am
It doesnt have a oil filter so I don't think it is pressure lubricated I might just run it at 3600
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 14th 2017, 11:45 am
The 2 I happen to have are. Rpms on onan 2240318088
Rpms on onan 316508e59b08223ed200cf3a8243a321
Who knows what the competitor engine was...
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Coil for onan   Rpms on onan Icon_minitimeMarch 14th 2017, 5:42 pm
A Kohler magnum
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 14th 2017, 6:34 pm
Yeah I wouldn't risk it with that ol' engine, if you are looking for high RPMS I'd go for a Briggs single. Unless it has to be horizontal shaft.
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 14th 2017, 6:38 pm
Briggs single for vertical, or a Honda GX series for horizontal. Both of which are way easier to find parts for if you mess something up, but will never produce the torque that the Onan does
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 14th 2017, 7:37 pm
Yeah Onans are work horses, pretty good for garden tractors and stuff. Also like CQ said, parts for Honda and Briggs engines are way easier to find and cheaper. As opposed to Onan parts, which can break you haha!
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 14th 2017, 9:56 pm
3600... hp drops off about that point... carb and exhaust limit high rpm, as does the valve spring pressures (valves start to float)
TedTheDestroyer
TedTheDestroyer
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 15th 2017, 10:54 am
My welder with a CCK doesn't have an oil filter but it is pressure lubed
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 15th 2017, 11:07 am
it is pressure lubed... it has an oil pump... at least my 1969 version does
if it IS a B48m, it has an oil filter... it may be internal, on the pick up tube screen, but it should be there... the oil pump is like a vw pump... two gears that rotate and squeeze the oil between them creating the oil pressure.
http://www.searspartsdirect.com/model-number/b48gga0183475a/0776/1503500.html
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms for onan   Rpms on onan Icon_minitimeMarch 15th 2017, 12:00 pm
Can't use Briggs cause it has to be horizontal and Hondas just wouldn't be a good torque motor but if I run the onan at 3600rpm it should be fine right and what kind of weight oil should I put in it I'm gonna put royal purple or Lucas in it
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 15th 2017, 12:12 pm
I think you want to run conventional dino oil. The synthetic eats away at the gaskets of older engines. That's what I've read anyway. For weight, I would just run normal SAE 30
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 15th 2017, 12:18 pm
10w30 is what it was designed for... just like a car... as for additives, slick 50 (half a bottle) will help keep things cool
for pulling, the onan's torque is gonna help you more than the high rpm's horsepower... max torque is in the 25 to 2600 rpm range
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms for onan   Rpms on onan Icon_minitimeMarch 15th 2017, 8:10 pm
It doesn't really matter because it's got a little oil leak coming from the oil pan or the front bearing cup which I just lapped the valve decarboned the piston and valve shaved the eyebrows a little set the valve lash and replaced the front seal in the bearing holder and replaced the gasket on the front bearing holder so 10w30 oil will be good for high temps
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 15th 2017, 8:44 pm
Do these old, (well atleast in my case... ) engines need a zinc additive? We have some old v8s that without the zinc the cam will eat itself... I dont believe oil is the same as it was 40 years ago.
Kleatus
Kleatus
Rpms on onan Empty
PostSubject: Rpms for onan   Rpms on onan Icon_minitimeMarch 15th 2017, 8:46 pm
Royal purple and Lucas have lots of zinc to prevent from engine wear and the metal from breaking down
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 16th 2017, 8:58 pm
slick 50 uses PTFE (Teflon).... it will run for quite a while WITHOUT oil.... don't use it on engines that are not broken in
Rpms on onan Empty
PostSubject: Re: Rpms on onan   Rpms on onan Icon_minitimeMarch 16th 2017, 10:38 pm
Good info to know.
Rpms on onan Empty
Rpms on onan
» Onan twin cyl!
» more rpms from a briggs 12hp flathead
» Can you help me with an onan engine?
» onan ignition
» onan manuals
