 How fast does your tractor go?
D.U.B.S.
Bandit1
avrappy
CornishMorgan
Murray modder
ibdalovely1
Chopperhed
Tractor Man Jeff
xxXMowerdudeXxx
Webmaster
MSteele323
indianaboy93
Mississippi1313
Chunk
arild365
24 posters
Go to page : Previous  1, 2
Tractor Man Jeff
How fast does your tractor go? - Page 2 Empty
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 12:56 pm
Mine runs right at 15mph, according to my Iphone.
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 1:03 pm
My tractor goes about 7-8mph.
Chopperhed
Chopperhed
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 1:30 pm
Both my stock Fords max out at 8.5 mph.
The off roader is currently geared for 65 mph.
I intend to get it down around 50 for better acceleration off the bottom.
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 3:25 pm
Actually, mowercycle gang is running 44-45mph, on the GPS, flat out. But really we run 35mph tops when racing, and 10 mph on the trails.
These speeds were darn near uncontrollable before. With the custom front end, solid axle rear end, and upgraded steering, you can drive no hands at top speed. Not that I recommend that.
No stock axle/geometry front ended tractor should go over 20mph. They have severe camber in the king pin, causing unstable steering at higher speeds. We fought this for years before researching and building new front ends.
ibdalovely1
ibdalovely1
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 3:32 pm
my craftsman 12.5 brigs governed has i think a 5 on the ft and the back and dose around 20 had to weld the ft axle solid and then i cracked the frame welded that to from the death wobble gonna reinforce the whole frame this summer to make it more solid and do the direct steer and would like to lower it dono if i have the talent to doso yet
Last edited by ibdalovely1 on Tue Feb 19, 2013 4:49 pm; edited 1 time in total (Reason for editing : typos)
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 3:46 pm
I use a golf cart axle turned upside down for clearance. As far as the axle and linkage related to the golf cart axle, There is no slop. As for the currant way I have the axle mounted the the rest of the steering, there's plenty of slop.
Murray modder
Murray modder
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Feb 19, 2013 5:00 pm
55 on a rebuild vertical racing mower that ate a clutch yesterday...20 on a twin.used on forest running.
CornishMorgan
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeWed Feb 20, 2013 6:43 am
My Sat Nav says mine does 10 MPH, I going to do another pulley swap in to once its rebuild so i can get about 15mph. 10 is a little too slow for my liking.
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeWed Feb 20, 2013 9:41 am
My gen1 racer did about 15 on a flat with its pulley swap. My Craftsman only did about 8 last I tried cause we couldnt get it out of third because of the shift lever.
avrappy
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeSat Feb 23, 2013 8:06 am
cheers My 1990's Craftsman does 25 or so with a 8 HP B&S.[url=HTTP://WWW.FLICKR.COM/PHOTOS/AVRAPPY/ MY CRAFTSMAN]HTTP://WWW.FLICKR.COM/PHOTOS/AVRAPPY/ MY CRAFTSMAN[/url]
Bandit1
Bandit1
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeSun Feb 24, 2013 5:28 pm
Mine does about 45-50 mph depending on the ground im driving on. My theory was if i hit the mud going fast enough i aint gonna get stuck What a Face
Chopperhed
Chopperhed
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeSun Feb 24, 2013 5:30 pm
Momentum rules, but the bounce might hurt. cheers
Bandit1
Bandit1
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeSun Feb 24, 2013 5:43 pm
It does hurt.. Id like to run double belts on it with seperate clutches and different sized pullys so that I could have a lower gear for water crossings.
Chopperhed
Chopperhed
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeSun Feb 24, 2013 5:47 pm
Good idea.
Add a drive pulley, and pick up a 3 stage stepped pulley.
You could run 3 different ratios,
D.U.B.S.
D.U.B.S.
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeTue Mar 19, 2013 8:03 pm
My Murray Goes 15 MPH, but I plan on making it at a minimum 35 MPH. (Maybe Faster?)
My other mowers will be rock crawling slow.
Tyler91000 Murray mudder
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 08, 2013 10:57 am
I've got a older Murray riding mower with a 6speed peerless 12 hp ic Briggs and Stratton. I welded a 7in pulley onto the engine and put a 3 in pulley into the trans axle my top speed with about 165lbs does 35MPH that's sketchy as hell with the large amount of play in the steering I have. Fun tho get a lot of looks passing vehicles on town on your lawn mower!
xxXMowerdudeXxx
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 08, 2013 11:14 am
Now that i took the gov off mine, it does almost 40mph
PostSubject: speed   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 08, 2013 5:36 pm
on my snapper, when the carb doesn't flood out (flamethrower anyone?) I was clocked by the police officer on duty last winter @ 38mph. I have had it as fast as 45-50, but it really didn't like that much.
When the widebody is done I estimate it at or around 30 top speed, 6th gear with throttle pinned.
Kel
Kel
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 08, 2013 6:41 pm
[img]How fast does your tractor go? - Page 2 Thorha10[/img]
GPS'd at 53.7 MPH
Briggs 12Hp...Serial 25 block with a #28 crank with internal mods/porting,head shaved.
Kel
http://www.xtrememowermayhem.com
mudmonkey06
mudmonkey06
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 08, 2013 7:33 pm
0 mph its in pieces lol
RandyC
PostSubject: Re: How fast does your tractor go?   How fast does your tractor go? - Page 2 Icon_minitimeMon Apr 22, 2013 7:32 pm
Mine tops out at 60 kph I don't want it to go to fast. I want to turn it in to a mudder..
» Half Fast Pulling Tractor
» how fast should this go
» fast allis
» Where do you ride, and how fast do you go?
» Fast go kart
