| Li'l Red 1 | |
+22SebastianAlbrecht darkside0914 Buck richie thomas Dave.MTD Double W Cross Ranch Crazy_Carl biggasmowers HILLBILLY RICH BriggsBandit99 Lawren Wimberly TheBeal prancstaman mr.modified tater195 Warren Evans RichieRichOverdrive MatthewD AllisKidD21 MightyRaze Doug CraftsmanQuad19 26 posters |
| Subject: Re: Li'l Red 1 January 13th 2018, 6:08 pm | |
| Yep you’re right AK. The snow hogs are more like a knobby | |
Age : 25 Join date : 2016-07-10 Points : 8564 Posts : 5190 Location : Ontario Canada
| Subject: Re: Li'l Red 1 January 13th 2018, 6:14 pm | |
| Yeah pretty much, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15597 Posts : 10945 Location : Oklahoma
| Subject: Re: Li'l Red 1 January 13th 2018, 8:57 pm | |
| I already saw a diff in the yard. | |
Age : 22 Join date : 2016-10-29 Points : 7177 Posts : 3999 Location : Lewisburg, KY
| Subject: Re: Li'l Red 1 January 13th 2018, 10:38 pm | |
| Bet they'll do ya good! Look a bit small though? | |
| Subject: Re: Li'l Red 1 January 13th 2018, 11:24 pm | |
| Maybe, but I don't have much to crawl around here. Mostly trail stuff around here. | |
| Subject: Re: Li'l Red 1 January 14th 2018, 12:53 am | |
| Tire are still settling in. They are about half an inch wider since the pictures were took. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6377 Posts : 1434 Location : east dublin georgia
| Subject: Re: Li'l Red 1 January 14th 2018, 1:52 am | |
| Looks good man, love the camera mount. I've been trying to figure out how I want to do mine | |
| Subject: Re: Li'l Red 1 January 14th 2018, 9:37 am | |
| Thanks. I'm not 100% on my camera mount, but it works for now. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5310 Posts : 2561 Location : Rochester, New York
| Subject: Re: Li'l Red 1 January 14th 2018, 2:53 pm | |
| I love the x-tracs man. I have little pizza cutter ones on my Green Machine and they work great for trail riding and they look cool and aggressive. | |
| Subject: Re: Li'l Red 1 January 23rd 2018, 5:48 pm | |
| Hey Mighty, didn't you say you were going to make a skidplate at one time? What ever became of that? | |
| Subject: Re: Li'l Red 1 January 28th 2018, 6:03 pm | |
| Sad day, I have tried to get Red started all day and no luck. I was going to use him to work around the yard. Carb was leaking gas, I fixed that. Only think I have not checked yet is the plugs. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4907 Posts : 1944 Location : Kansas
| Subject: Re: Li'l Red 1 January 28th 2018, 7:14 pm | |
| Awe, so sad. Mabye a pinched coil kill wire? i have had them wear through on where they enter the engine and are squeeshed between sheet metal. | |
| Subject: Re: Li'l Red 1 January 28th 2018, 8:23 pm | |
| I finally got around and did some proper troubleshooting. Issue was with the plugs. They were oil fouled. Did some cleaning up and got it running again. Not smoking, and when I had it opened up a year ago, there did not seem to be any leaking past the rings. I do think I know the issue and it was my own cause. | |
| Subject: Re: Li'l Red 1 January 31st 2018, 12:08 am | |
| Little shot of Red Hood-less. LOL Seems to fire right up now. Needs a little fuel flushing and all should be good again! | |
| Subject: Re: Li'l Red 1 April 8th 2018, 6:42 pm | |
| So.... Red is currently in the non-running category. I am thinking a tank and bowl drain. I fear my gas has lost it's boom. | |
| Subject: Re: Li'l Red 1 April 8th 2018, 8:29 pm | |
| seems odd. How long has the tractor been sitting? I'd drop the bowl first and see what the gas looks like in there. | |
| Subject: Re: Li'l Red 1 April 8th 2018, 10:09 pm | |
| I only had about a half inch in the tank and it looks like it has water in it. I'm guessing the carb is the same. I got some fresh boom juice tonight. We'll see if that is what the 4 cycle ordered. I'll pull the bowl drain and drain the tank tomorrow. | |
| Subject: Re: Li'l Red 1 April 9th 2018, 8:43 pm | |
| Got the water out and flushed the system. Had squatch out too trying to get it started. Neither was a go. Squatch is just a weak battery. Red, I just could not get any fire to it. Pulled the plugs and they were wet. Cleaned them up and tried again. No go. Pulled them back out to check spark. Nothing. Unplugged the kill wire and still nothing. I had a couple plugs from the briggs in a bucket that I am putting in Kal. I put one of them on a wire and ZAP! ZAP! ZAP! Put those plugs in and VROOOOM!!! Not sure why the plugs messed up like that, but that appears to have been the issue. I took it around back to the wet spot. It had been soaking all winter. Lets say it was a sticky mess. I buried Red down to the transaxle. LOL. No pix or video due to the phone was dead by this time. | |
| Subject: Re: Li'l Red 1 April 10th 2018, 7:15 am | |
| It's good that you found the culprit. I've only had a problem spark plug once and I didn't figure it out at first either. | |
| Subject: Re: Li'l Red 1 April 10th 2018, 7:27 am | |
| I knew about the bad gas, so that is what I tackled first. | |
| Subject: Re: Li'l Red 1 April 10th 2018, 7:39 am | |
| That's weird. I had a spark plug problem once, was kinda weird. Never suspected it lol. But sure enough, I replaced it and ahe ran. | |
Buck Member
Join date : 2017-11-01 Points : 2859 Posts : 282 Location : Eastern Ontario
| Subject: Re: Li'l Red 1 April 10th 2018, 6:10 pm | |
| the spark plug is the first thing i check when ever i have a no start, it tells you alot, and its the easiest to check
3 things to make a engine run spark, compression and fuel. take one out no BOOM | |
| Subject: Re: Li'l Red 1 April 10th 2018, 7:41 pm | |
| Exactly. Yeah after I got rid of the bad gas, it was the first place I went for. | |
| Li'l Red 1 | |
