 Li'l Red 1
darkside0914
Dave.MTD
HILLBILLY RICH
BriggsBandit99
tater195
Warren Evans
26 posters
Go to page : Previous  1 ... 11 ... 18, 19, 20 ... 24  Next
Li'l Red 1 - Page 19 Empty
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 16th 2019, 2:30 pm
Still without charging my battery, I jumped on Red and she fire right up still. I guess my $8 coil is what the Dr. ordered to liven the old oppy back up!
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 24th 2019, 11:11 am
MightyRaze wrote:
Got the 820 cleaned.  Now for Santa to bring me a new 1" live axle.
Danceparty
Li'l Red 1 - Page 19 11241810
Li'l Red 1 - Page 19 11241811
Finally broke down and ordered my 1" live axle for the 820 doc locker. Seeing how these thing split in the middle with welded gears. I could see why, there is some center flex play before I took it apart. I figure Doc Lock was the way to go to reduce or eliminate the center flexing. I already have a hub, just need to make the keys for the gear. I think I will notch the hub AND weld the keys in. Just need to find the steel. I may have some in the scrap pile maybe.
Li'l Red 1 - Page 19 Sig115PROJECTS:
Li'l Red 1 - Page 19 Sig214Li'l Red 1 - Page 19 Sig314
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 24th 2019, 11:16 am
Looking forward to seeing what ya come up with Mighty!
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 29th 2019, 7:49 pm
All right.... last piece of this puzzle is in.  Now to start putting it all together and get it done.  I will be doing this at a slow pace.  Don't want to mess up the locker.  That can be a costly mistake.
Li'l Red 1 - Page 19 01291910
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 29th 2019, 7:54 pm
Should be good. Although I think the axle shaft is supposed to go through the ball bearings, not sit on top of them. Li'l Red 1 - Page 19 1098998679 Li'l Red 1 - Page 19 1098998679 lol!
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeJanuary 29th 2019, 8:01 pm
WHAT!?!?!?!  I have been lied to!
Li'l Red 1 - Page 19 2664539216
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 10th 2019, 6:35 pm
Well...
I went out on a limb and purchased a press for a regular drill just to try and have handy if it worked ok.
Li'l Red 1 - Page 19 02101910
Mounted to my bench I started thinking I need to start working on that 820 again and I also need to finish the repairs to Kal.
Yep... I did what you are thinking.  I screwed the hubs (one at a time) to the bench through the base of the press and gave it a whirl increasing the inner holes from 7/8 to 1".
To my surprise, it was rather easy and I could make the drill speed variable with my other hand and drilled out the hubs.
Li'l Red 1 - Page 19 02101911
Li'l Red 1 - Page 19 02101912
It was super simple and I just took my time.  Even at that my bit just cut through the hub no harder than cutting wood.  I was shocked.
Once drilled out I slid the 2 halves onto the axle and they are snug as a bug, but can slide down it.  No play at all.  I spun them around a few times and I do believe they are true to center as well, no offset bunders.
Now to find some 3/4 square stock and finish the center hub.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 10th 2019, 7:24 pm
Nice job! It's a good thing peerless didn't harden those sides like they did the bullgear. And btw, cast iron shouldn't need any lube as it by nature has graphite nodules in it. I think the only lubrication recommended for cast iron is lard or some kind of animal fat. Either way, you got it drilled out lol.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 10th 2019, 8:02 pm
I went ahead and hit it with some WD40 when drilling. I think it is made of fish oil.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 11th 2019, 2:19 pm
Yeah... I am currently trying to find 0.75" square rod of any kind at this time. I haven't looked hard yet. I may have to do what Doc did and cut up a hitch, but that would be some $$$ metal to scavenge when I have seen it cheaper by the yard. That and the garage is a bit cold right now and my roller work space has opposed engine #3 on it. I may try to get that thing running this week. Possibly today.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 11th 2019, 3:00 pm
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 11th 2019, 3:04 pm
Yeah, I may have to order it up online.  I was going to check a couple other sources first, but I just haven't got around to it yet.  LOL
I'll probably kick into gear with this thing (Li'l Red) next month I hope. I plan on getting it the most "Haspin Ready" that I can get it. Same with Kal.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 27th 2019, 9:06 am
Is it ever going to warm up?  Ugh.... hate cold garage.  820 is still in pieces on the work bench waiting for me to make the hub.  Looking at the next 10 days, no warm relief in sight.  Bah...
In other news, the 85 hood will go back on Li'l Red. It's waiting for me to install the 820 to go on.
Li'l Red 1 - Page 19 06261710
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 27th 2019, 3:18 pm
I really like how the hood is back on this one. It gave your Murray its own character.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeFebruary 27th 2019, 6:02 pm
I actually like both, but you are right.  It does give it a unique character.  Kind of an Old School Widebody.
SebastianAlbrecht wrote:
I hate cold Shops too!!
It sucks to work in the cold, and the cold tools pull the heat outta your body so quickly....
Also laying on the garage floor when you need to go under the tractor.  Cement will draw the heat from you fast!
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 8th 2019, 1:08 pm
Looks like I will have some extended free time next weekend, I have all parts needed to finish this but 1 thing.  Wheel hubs.  I figure I have a few options.
  1. Use the 820's wheels and get bigger new tires (12 inch wheels)
  2. Buy wheels and hubs or Make some wheel/hubs, use existing tires (8 inch wheels)
  3. Buy/Make some wheel hubs and get bigger new tires (12 inch wheels)
Option 1 or 2 would be the cheapest.  Although my tires are starting to get a little worn, I think I can get some 4on4 or 5on4.5 hubs and wheels fairly reasonable and reuse the tires.  Option 1 and 3 causes new issues.  For one, my front 16x6.5x8 tires will look super small against a 12 inch wheel tire.  They already look smaller than they should and I kind of like the lower 22" tires on the rear.
Decisions... decisions....  as far as mounting, it looks to be a direct bolt up.  My 820 even has the long shifter shaft.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 10th 2019, 10:42 pm
Just a little closer.  The only wrenching I got done this weekend was on the 820 locker.  I got my hub made and welded.  Slides in great but,,, I forgot to cut some room for the lip of the hub.  Easy grind down.  I had to lube up the axle just so I could get the ring gear assembly on.
Li'l Red 1 - Page 19 03101916
Li'l Red 1 - Page 19 03101915
Li'l Red 1 - Page 19 03101917
diddie
diddie
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 10th 2019, 11:03 pm
Looks good ! Nice work !
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 11th 2019, 3:41 pm
I'd Like to do this also with the 2300 in Kal. I just need an axle and hub.
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 11th 2019, 11:21 pm
I am 2 washers shy of buttoning up the 820.
Li'l Red 1 - Page 19 03111910
Just need the washer between the ring gear hub and the needle bearing.  I thought the one I had was 1 inch, but they were on the 7/8 part of the original axle..
PostSubject: Re: Li'l Red 1   Li'l Red 1 - Page 19 Icon_minitimeMarch 12th 2019, 11:15 am
I decided to go with option:
I'd just bought some 8" Rims with 1" center for Gokarts...
They should do fine on the Live Axle that will go in the 820!
It was a no brainer. I hope to have the 820 in the tractor this weekend. I'll need to make a front side brace for the trans, but that should be easy enough. The rest will just bolt up.
Li'l Red 1
Page 19 of 24Go to page : Previous  1 ... 11 ... 18, 19, 20 ... 24  Next
