| Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] | |
+9Doug Chasetown TheBeal mr.modified redlinemotorsportts Thunderdivine MatthewD Rockinator Off Road Domination 13 posters |
Off Road Domination Member
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] March 6th 2016, 7:34 pm | |
- Holy smokes, that things huge! How much do you think it weighs? What id do is run the stock grill, and get a big sheet of sheet metal and bend it up/cut it up around the engine so it pokes through, and you wont be cutting the stock hood up. Ive sold stock hoods before for a little bit too.
Yea Its very big and its only 7.5hp! Im guessing it weighs about 150+lbs but I think im just gonna cut the hood and put a hood scoop over the hole so it looks good it will save me the time | |
Age : 22 Join date : 2016-02-17 Points : 3269 Posts : 74
Age : 34 Join date : 2013-11-02 Points : 7156 Posts : 2910 Location : New Jersey USA
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] March 6th 2016, 8:15 pm | |
| The engine. I need a small diesel with electric start to run two alternators and on occasion an air compressor. That one might be kind of big, not sure. It needs to fit into a 30" diameter tube with at least some extra space to get it in and out. I've heard of that lombardini name. I was going to use one of those yanmar clones like fearless front used for his tractor. I'll have to look around I guess. Small diesels are expensive. | |
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] March 6th 2016, 8:21 pm | |
| - mr.modified wrote:
- The engine. I need a small diesel with electric start to run two alternators and on occasion an air compressor. That one might be kind of big, not sure. It needs to fit into a 30" diameter tube with at least some extra space to get it in and out. I've heard of that lombardini name. I was going to use one of those yanmar clones like fearless front used for his tractor. I'll have to look around I guess. Small diesels are expensive.
yes this engine is great it starts and runs well its 7.5 hp so should be good for your project I happened to have one of these arrow boards because my family owns a construction company but you can pic up one of these engines for $375 on ebay its alot cheaper then the 10hp clones but bigger and most of them have oil sumps | |
| Subject: Re: Sears Super Diesel March 13th 2016, 9:32 pm | |
| Just a little update on the tractor and the engine. About 2 weeks ago we found out the starter was good and just needed to be regrounded. Then we painted the starter flat black changed the oil and oil filter so we dont have to worry about that later. As of right now the motor being bolted down to the tractor and we are seeing how it looks with the hood on. I should have some pictures tomorrow. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5740 Posts : 1993 Location : Northern Ireland
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5704 Posts : 1402 Location : Central PA
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] March 24th 2016, 6:19 pm | |
| - TheBeal wrote:
- Was the gas tank originally under the seat?
Im trying to figure out how it should go on the one I have, a ss16 I believe. No it was under the hood like the other sears suburbans are this one is a st16 not an ss16 the ss16's have the gas tank under the seat but if it did I would have moved it for lights and a rack but thats my opinion. | |
Chasetown New Member
Age : 39 Join date : 2014-12-10 Points : 3640 Posts : 12 Location : Chesterville Ontario
Rockinator Member
Age : 23 Join date : 2016-01-16 Points : 3396 Posts : 164 Location : Canada
Rockinator Member
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] May 8th 2016, 9:09 pm | |
| - Rockinator wrote:
- I would consider something else since youll have to cut the hood to make that work. Id try making a side exhaust that exits by the floorboard so the smoke is under you not right beside you. But thats a personal opinion.
Thanks for the opinion I think I am still going to keep the stack though worst comes to worst I can Just take it off make a different exaust and put an intake snorkel where the hole was | |
Age : 27 Join date : 2013-03-18 Points : 7470 Posts : 3131 Location : raleigh nc
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] June 8th 2016, 4:45 pm | |
- Looking very good, i agree with the turbo, a lot of work for not to much pay off really. Looks like it fits in there better than i thought. Engine pulley should net you some good speed and crawling still in first gear.
Yea I think it will have a good ratio | |
| Subject: Re: Off Road Domination's Sears Super Diesel [2016 Build-Off Finalist] June 8th 2016, 6:20 pm | |
| Subject: Re: Sears Super Diesel August 13th 2016, 11:21 pm | |
| The diesel runs and drives! got the alternator wired and mounted rims painted and tires mounted bottom grill piece painted mounting plate cut finished clutch and both belts are on fully custom exhaust with custom exhaust support hood being fit right now along with hood scoop and a hood extension and bought some led pod lights and a 7in light bar This thing is really starting to come together and soon will be torn down for paint! | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6530 Posts : 2101 Location : Norway, Europe
