 Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]
mowerjunkie03
tater195
Crafty
TedTheDestroyer
sadeoo7
rarbaugh07
rstolz
STUNTMAN JON
MasonMcK
redzz02
tscustoms
Rockinator
cablguy2
40 posters
Go to page : Previous  1, 2, 3 ... 12 ... 22  Next
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Empty
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 6th 2016, 11:19 pm
Paint colors: Orange for the tin work, white grill. I think the tubing and bumpers are going to be black on this one. Not sure yet on the wheels. And I've never bought any new engines so far. I pick stuff up at some swap meets pretty often.
Sears suburban for parts. Simplicity frame for size comparison.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4890_zpszi65exu8
The stock muffler might be neat to use. I'm taking the steering and front axle out of this one.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4891_zps5ccxblvx
Removed the 633. Cast iron input pulley is a slight issue as I can't weld to it. The other 633 I have also has a cast pulley. Gotta work on freeing up the hubs. The other 633 had 3 lug hubs but I can't even use them for spares because I broke them taking them off. Shouldn't need spare hubs anyway. If you break one of these before the trans I think you've probably also broke your leg or something.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4893_zpsigigs7zc
tscustoms
tscustoms
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 7th 2016, 8:10 am
Dude that's mint sears.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 7th 2016, 8:40 am
Getting on well cheers Muffler looks neat. Could flip it up horizontally and put a rain cap on it.
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 7th 2016, 10:48 pm
thats a whole lot of tire, im gonna love this one good luck!
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 8th 2016, 12:28 pm
The suburban is kind of a nice one to just hack up for parts, but a lot of it will get used, so it's not wasting too much I guess. I would have built that into something, but since I already did the baja sears, figured I'd do something different.
As for the exhaust, I've never really been a stack guy for some reason. I have a megaphone that would be neat to use too, so I might make the muffler and megaphone with a flange so I can switch between them.
Current status is the hubs on the 633 are soaking. I heated them up once a little to break them loose. Removing the original sears tires off the rims so I can paint them up and mount the kendas. Need the new tires mounted so I can get things lined up where they need to be. Stock tires are somewhat lower I think.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 10th 2016, 9:25 pm
Things are so far moving along pretty good. Both 5 lug hubs are off the 633 without breaking them. So now I've got two 633's without hubs on them. One is stripped of pulleys ect. and ready to be taken apart for locking.
Compared front axles. Top one is from an older 10hp suburban, maybe 67-68? Bottom one is from the 70-71 12hp pictured earlier. The newer one is thicker so decided to stick with that. Steering is slightly different also. Note the steering arm on the left spindle of the smaller axle. I didn't want to use this setup as I don't have any spare cast arms if I broke that one. And being cast, I wouldn't be able to weld it up too good.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4896_zps45lzeoh8
Here we've got the ugly brackets all torched off. Started smoothing them up. You can see the pivot/bell crank in the top of the pic that the newer suburbans used.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4900_zpscwkisfea
Front hubs fit pretty close on the spindles. the tin dust cover which is welded in place needs to be trimmed off for the hub to slide back all the way into place.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4904_zpsbsvdu199
Here you can see where I cut around the edge of it with a grinder. There's a heavy washer welded in place against the inside of it.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4909_zpsbtnmdcd6
Got my wheels set in place and decided to mock up the front a little to see how things are going to go.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4911_zpstx8hfpkv
This doesn't mean anything is nessesarily going anywhere close to where it is in the picture, but I think the frame is probably going to be just slightly higher than this. Frame can either be moved forward or back, whatever best fits front and rear axles. I've gotta get the rear tires mounted and on a 633 so I can line everything up at the same time before I do anything. Hood will be later once I have a rolling frame. Just set it there to get an idea of the look. I think it's going to turn out pretty good.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4912_zpstiung5zx
MasonMcK
MasonMcK
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 10th 2016, 9:52 pm
Where did you get those front hubs? I need some 5x4.5 wheel hubs for a 3/4" axle and I wonder if they have 5 lug versions.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 10th 2016, 11:31 pm
Good progress, looks like a mud dragster with the front end all kicked out. Again, i vote the rear fenders, would work good with a straight bar rear bumper like mine, and the rear tires could look all kicked out from the narrow fenders. just going to make a single panel metal dash like the baja?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 11th 2016, 11:28 am
Looking good! Them large skinny tyres look neat against that narrow grill.
Edit:
Could you use the sears mudgaurds?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 11th 2016, 4:04 pm
bmikarts.com I bought the front hubs, bearings, and front wheels from them. They had a pretty good selection of different hubs. Might have something.
With the whole go anywhere theme going on, I'll probably have to use fenders at least in the rear, maybe front also. Dash will probably end up sort of like the baja sears, except I think most of my switches will be up high possibly in front of the steering wheel. I had an idea to make a sort of roll bar in front of the steering wheel with a couple of lights on it. Not sure yet how that will go.
Edit:
I could use them, but I might make my own from plastic. Or I might try to use the simplicity rear fender modified slightly.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 11th 2016, 5:06 pm
Plastic fenders would be neat. The engine looks nice in the mid frame.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 12th 2016, 9:55 pm
Decided to use a couple of hydraulic reservoirs I had from a couple of self propelled paint sprayers. Heavy enough steel where they will be easy to weld. Both have an area where the cap was and two threaded holes for the hydraulic hoses. Once I know where it will go on the tractor, I can cut them in half and make one bigger one. For a gas cap I'll weld on a filler neck from a toyota tundra. I happen to have one that's pretty rust free. Far right is a briggs stock 7-8hp gas tank, center is a stock briggs 10-11hp tank.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4921_zpsgdkofmzi
Here's a link to the grill decal just so I can find it again. I'll probably get a couple and maybe put them on the sides of the hood.
Simplicity 'S' decal
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 14th 2016, 9:21 pm
Took the one 633 trans apart today to lock it up. I planned on welding it, after creepycrawler told me his crew fragged one that had the diff gears flipped to lock it. But, after looking at it and thinking it over a bit, I decided to flip the diff gears without welding again as I did in the baja sears transaxle. I figured with my relatively mild tread tires and only 8hp to work with, I'd do some testing and see what happens. I didn't feel confident that I could get things stright either. I'd rather take a chance on flipping the gears than ruining it by welding the axles sideways. The baja sears hasn't seen that many hours off road, so just because that hasn't broken yet doesn't mean it will. Also this eliminates the risk of welding slag getting into a bearing ect. If one prys itself apart I can weld up the ones that didn't later.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4922_zps2k12ixes
One case half with some sludge at the bottom.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4923_zps8zu3ulwc
Bought a winch from tractor supply. 2500lb, smallest one they had. Looks ok. Supposed to be 49 foot of cable. I may get an extention cable to bring on board with me.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4924_zps8b1phf73
I plan on keeping this behind the front bumper somehow so I can still ram over trees and stuff without hurting it. My original plan was to outline the grill with pipe and have headlights on the side of the hood near the top like they do from the factory. Now I'm thinking use a smaller front bumper that has two headlights mounted close together behind it. Maybe come only half way up the grill.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4925_zps6hexou2l
Goal is to have a rolling frame by the end of next weekend. Still a lot to do before haspin and not that much time to get it done. One rear rim is cleaned and ready to be painted. With the trans done, all I need is to paint the rims and mount the rear tires. Then I can line it up and start welding the frame.
MasonMcK
MasonMcK
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 14th 2016, 9:52 pm
How are you locking the diff by flipping gears? Definitely interested in this.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 15th 2016, 12:32 pm
Cool winch! @MasonMck I think the way it works is the gears are flipped in the differential so that they lock together. You can look at the Baja Sears build from the 2014 build off for more details.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 15th 2016, 1:42 pm
There's two sets of spider gears on each side of the differential. Some 633's I think have three sets, unless they aren't 633's. maybe a different model or something. Anyway, here you can see the gears from both axles on top and bottom center. The spider gears on the left and right. Two more gears behind them are hidden in this pic. Notice how on one gear it only engages the bottom and the other the top.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4093_zpsmr53vdvi
In this pic you can see I flipped one gear from each set so each set is holding on one axle. This way the gears are locked together. These are from the baja sears build, but it's the exact same trans of course.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4088_zps8dbdmpsr
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 15th 2016, 3:34 pm
Yeah thought that's how it worked. The hat size or those Bearclaws on the rear?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 16th 2016, 8:05 pm
Rear tires are 25 x 8 x 12. Here's one of the rims before cleaning and paint.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4927_zpsjw3dlbnz
One rim painted and tire mounted.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4928_zpsa3xj7okk
Tread on these not super wild where it would be rough on hard packed surfaces. Maybe a little better than the rear tires on the baja sears. I'm tired of working on the frame already and I didn't start on it yet. I'm ready for making aluminum skid plates...
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 IMG_4930_zpspredpxfp
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 16th 2016, 8:08 pm
Yeah I know the feeling. I'm waiting on undercoat drying on my build.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 16th 2016, 10:34 pm
Honestly wont notice the tires that much until you are on the road. like my tires, super spread out and choppy is fine on the grass. Street running however, is roooough lol. Almost feels like the rear skates around.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 17th 2016, 4:53 pm
Bearclaws run fine on the road.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 17th 2016, 10:42 pm
Yeah the tread is relatively mild. Things are still more or less on track for having a rolling frame by the end of this weekend. Need to make sure I've got the best equipment to handle Haspin's rugged landscape, so I ordered a pair of these super high tech looking shocks for my front end. They're just cheap chinese stuff, but they look pretty neat. The ones i bought are about 12.5". Some people on motorcycle forums report them holding up ok. Should be fine for this project.
Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Test_p10
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 18th 2016, 7:37 am
Good progress! I saw the fragged 633, wasnt pretty. Had some big tires, and I think the they had some hours on that trans.
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 18th 2016, 2:19 pm
Thanks. What's the deal with some 633's having 3 sets of differential gears and some only two? The 3 gear set ones for tractors with a bigger engine? I can't use the moose knuckle method on the ones I have. The axle gears on mine are welded in place with no splines. I guess I'll weld the spider gears in the spare 633.
STUNTMAN JON
STUNTMAN JON
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 18th 2016, 2:24 pm
Are they a pair from a dual shocker like a monkey bike or did you have to buy separately?
PostSubject: Re: Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]    Mr.Modified's Simplicity Adventure Edition [2016 Build-Off Finalist]  - Page 2 Icon_minitimeFebruary 18th 2016, 5:56 pm
Shocks look good. Should stand iut on the machine. Looking forward to seeing the rolling chassis.
Page 2 of 22Go to page : Previous  1, 2, 3 ... 12 ... 22  Next
» TSCUSTOMS Dirty Burban [2016 Build-Off Finalist]
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» Chase Towns's Daisy FMC [2016 Build-Off Finalist]
» Maine Mud Mower's "Not the Norm" [2016 Build-Off Finalist]
» redzz02 Drift Missile [2016 Build-Off Finalist]
