| lifting the GT6000 (no welds) | |
+3Backroadbomber 1997 Murray Alaskan Craftsman 7 posters |
Alaskan Craftsman Member
Age : 38 Join date : 2015-12-17 Points : 3316 Posts : 44 Location : Anchorage, Alaska
1997 Murray Veteran Member
| Subject: Re: lifting the GT6000 (no welds) December 24th 2015, 10:55 am | |
| cool. I have been trying to do a lift on my rig, since it looks funny with the lift on the front and big tires. I think the hardest part would be hooking up the hi/lo selector. It will be interesting to see how this turns out. | |
| Subject: Re: lifting the GT6000 (no welds) December 24th 2015, 2:20 pm | |
| Thats exactly my thinking as well. Buuuttttt since I took off my stock throttle which is pretty much a push/pull choke cable I figure I could reuse the cable as my high low selector.hooking it up wouldnt be too hard. Any thoughts? | |
Backroadbomber New Member
| Subject: Re: lifting the GT6000 (no welds) December 24th 2015, 11:10 pm | |
| I have a 60's Sears with the same transaxle and the hi/lo lever isn't all that easy to move... I don't know if a choke cable will have enough to move it. If there's enough room I'd suggest drilling a new hole in the tunnel for it lower and keep the stock linkage. | |
| Subject: Re: lifting the GT6000 (no welds) December 24th 2015, 11:12 pm | |
| Ill have to try that and get it mocked up. Currently im getting the rear hitch cut to fit around the pumkin hiusing of the transaxle. So far so good | |
| Subject: Re: lifting the GT6000 (no welds) December 25th 2015, 6:25 am | |
| Ok so heres the update...got a total around 5.5" of lift in the rear and I jacked up the front and put her on blocks to see what she'll look like when level, and man she looks sexy. Surprisingly enough my belt still fits!!! Theres a little less travel to put the clutch in now which is nice but it still fully enguages and fully disengages the belt. Next on the list is brakes and hi/low shifter. Before After Hitch plate and how its set up Had to cut the hitch to fit the 633 rear but ill get it guseted and welded later. | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4951 Posts : 919 Location : Defiance, Ohio
| Subject: Re: lifting the GT6000 (no welds) December 29th 2015, 3:25 am | |
| - Moose wrote:
- Could probably just lower the shifter make new brackets and bolt them up.
Yeah Ive been putting together kids toys from Christmas lol been busy but Im going to be lowering the shift arm like you all have been saying and Im trying to figure out how much lift Im doing in the front because I have 25" atv tires for the front as well lol. | |
| Subject: Re: lifting the GT6000 (no welds) December 29th 2015, 12:57 pm | |
| In pic #4 your belt is rubbing on the retainer. It will wear the belt out really quick that way. | |
| Subject: Re: lifting the GT6000 (no welds) December 29th 2015, 1:15 pm | |
| Yeah if you ditch that retainer it'll loosen your belt up a little and give you your clutch travel back. Or, if you don't want your belt hanging that low, I'd suggest to put an idler pulley on the bottom of the belt. But then that will be hanging low. Either way it's gotta go. | |
| Subject: Re: lifting the GT6000 (no welds) December 29th 2015, 9:17 pm | |
| So that retainer has been on the tractor rubbing like how you see it for a long time and Ive never had any issues but I think something is in order to get it out of there....I kinda like the short throw clutch lol. Also I have to add another clutch spring since I removed the brake linkage from the clutch to do a remote brake handle. | |
| Subject: Re: lifting the GT6000 (no welds) December 30th 2015, 1:41 am | |
| Well before your axle was higher, so your belt wasn't as tight on the retainer. But at the angle it is, I give your tractor 3 miles before it burns out the belt. | |
| Subject: Re: lifting the GT6000 (no welds) December 30th 2015, 10:13 am | |
| - Backroadbomber wrote:
- Well before your axle was higher, so your belt wasn't as tight on the retainer. But at the angle it is, I give your tractor 3 miles before it burns out the belt.
welp guess ill be laying out my extra pulleys and figuing a quick idler set up to keep the belt up out of the way. Thanks for all the help guys. much appreciated. | |
| Subject: Re: lifting the GT6000 (no welds) December 30th 2015, 12:46 pm | |
| - mr.modified wrote:
- Neat. Shifter just makes it through the frame huh?
yeah its enough to shift but the ball scrapes just barely making it almost impossible to lock it in gear so its an easy fix.....cant fix it till the build off starts lol. getting ansy | |
| Subject: Re: lifting the GT6000 (no welds) December 31st 2015, 8:12 am | |
| Here are some more updates on the GT hardest part was shaping the shifter to where I wanted it. everything else just came into play. this was an old single stage snowblower shoot director turn handle Im using as my shifter extension Threaded the rod to 7/16 or a standard 3/8 ths bolt removed old shifter knob to use it on the new shifter One of the most important tools in the metal fab lol everyone should have one. Shifter handle mocked up ready to test fit made measurements and heating up the solid rod for my bends Had to do a little trimming but in the end everything fit very well. new hand brake deal. so now my clutch and brake are separate. Disc brake hooked up and she stops on a dime. much nicer than stock setup Hope you all Enjoyed, more to come | |
| Subject: Re: lifting the GT6000 (no welds) December 31st 2015, 10:48 am | |
| that's coming along nice! now you need a set of 22" tall front tires Have you figured out the hi/lo selector? | |
| Subject: Re: lifting the GT6000 (no welds) December 31st 2015, 4:28 pm | |
| my goal is to get some 3/4" bore 4 bolt hubs from BMI karts or MFG Supply and slip them on the front spindles and run a 4.80 x12 trailer tire up front. and no i still havent done the hi/low selector yet lol the low on the tractor is really low so i need some more pulley options. I need a smaller trans-axle pulleybut im not sure what other pulleys will fit the tapered shaft on the 633 transaxle. | |
donaldcon Member
Age : 38 Join date : 2015-04-28 Points : 3961 Posts : 401 Location : Roseville, OH
| Subject: Re: lifting the GT6000 (no welds) December 31st 2015, 6:46 pm | |
| Don't change the trans axle pulley, change the engine pulley.
Bigger front pulley =less slippage.
| Subject: Re: lifting the GT6000 (no welds) January 1st 2016, 2:24 am | |
| not sure where to get a smaller front pulley because i have one of those wedge style ones where you tighten it up and the pulley wedged to the mount thats bolted to the engine | |
| Subject: Re: lifting the GT6000 (no welds) January 3rd 2016, 4:59 am | |
| Got my waterproof digital voltage meter in today and have it wire up to the ignition switch. Looks really nice in my opinion and I plated off the old throttle area. Getting her cleaned up....I still am having an issue figuring out what pulley to get for my engine....I'll post pics And here is my new bumper. Nothing fancy, but works and FREE. | |
