 Welds, will they hold up? (or maybe bolts)
Craftsman Dude
motorizedeverything
Krawler86
10 posters
Krawler86
Krawler86
Welds, will they hold up? (or maybe bolts) Empty
PostSubject: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:05 pm
So my friend welded up the planet pairs in my Sears 6 planet diff, and since they have been sitting on my desk for so long, ive begun to question their strength.  My friend, after a few inquiries, always said "it will be fine for what you are doing".  Im not 100% confident, so im here with pics to either get a confidence booster (IMO unlikely) or get told that there definitely needs to be more heat and penetration into the tooth contact areas, and not just a "bridge" across the backs.
Man, the pictures really make the light surface rust really stand out.  After welding and cooling, i accidentally left them in my truck when i got home, and they surface rusted a little before i had a chance to oil them.  They arent as bad as they look in some of the pics, the flash really made some of it look bad.  But it all wipes off with a wet fingertip, so i know its nothing serious.
Pair 1
Welds, will they hold up? (or maybe bolts) Img_3155
Welds, will they hold up? (or maybe bolts) Img_3156
Welds, will they hold up? (or maybe bolts) Img_3157
Welds, will they hold up? (or maybe bolts) Img_3158
Pair 2
Welds, will they hold up? (or maybe bolts) Img_3159
Welds, will they hold up? (or maybe bolts) Img_3160
Welds, will they hold up? (or maybe bolts) Img_3161
Pair 3
Welds, will they hold up? (or maybe bolts) Img_3162
Welds, will they hold up? (or maybe bolts) Img_3163
Welds, will they hold up? (or maybe bolts) Img_3164
This i noticed first on pair 3, but i noticed it on other pairs when i looked for it.  The weld is not present where the gear teeth make contact with eachother.  But only a weld "bridge" across the backs of the pairs to bind them together.  You can see light through where the teeth almost make contact.  Im assuming this is the bottom level of the penetration.
Welds, will they hold up? (or maybe bolts) Img_3165
So either tell me they will be fine with 27x11 Kenda Bearclaws and i shouldnt worry, or tell me to take them to a more experienced welder and have them welded together into 3 blobs that barely resemble gears.  This is new to me, ive seen welded diffs in real trucks, and for those, the people i know that welded them wanted everything welded to everything.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:07 pm
i see very little penetration there. if it was me, i would grind it off the best of my abilities, and re do them. what kind of welder are you using?
motorizedeverything
motorizedeverything
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:08 pm
i don't think they will. Do you know if they still fit in the case? Does everything still rotate freely?
Krawler86
Krawler86
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:12 pm
Yeah, everything bolts up back into the case just fine.  They were tacked, and then removed for the weld they got.  Its basically the same diff FearlessFront has in the Suburban, just with 6 planets, instead of 4.  Theres room everywhere.
Willis:
I didnt weld them, im a very green beginner.  They were welded with a Miller 110 FCAW. Im building this tractor in my appt. livingroom, no welding for me. Im making everything bolt on.
I have an idea for a locker idea, bolt on only. Il draw up a little mockup and see what you guys think. If i do my bolt locker, I would use it in conjunction with these mildly welded gears, as i dont think the gears would even see any of the load with my idea.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:14 pm
either way, i would start over, crank that thing up all the way and bubblegum the piss out of it. tripple pass if you have to
Krawler86
Krawler86
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:32 pm
Since i have to have welding done by someone else, (i dont own one anymore, and have no garage or place to weld in or on), id like to be able to do everything myself.  Ibe veen building all bolt on stuff so far, so why not a bolt on locker.
Im glad i posted about the welds, they are not strong enough, i was right, unfortunately.
So i came up with this, before my friend offered to weld the gears for me.  Totally bolt on and removeable, i just dont know how strong it would be.  I think strong enough, but i dont know.
Heres an overview with no internals installed
Welds, will they hold up? (or maybe bolts) Img_3166
So, being as either main side case of the diff is a machined piece, the side gears that drive the axles are machined, and the weak link ive seen from pulling vids, is the sintered planets splitting in half.  This locker method would bypass all the planet gears and make them useless.  I know the side gears are strong because they broke an axle shaft without breaking a sweat.  My thoughts are to bolt the side gears directly to their corresponding side plates, using probably 6, grade 10.9 metric shoulder bolts, or 6 gr8 thoulder bolts, sized correctly so all the shear loads would be on the shoulders.  Il do some research and see what the best shoulder bolts would be for high shear stress.
I sharpied a quick 6 and 8 bolt pattern on the side gears.  I think i like the 6, it leaves more material, and 6 is easier to center than 8 with the tooth count.
Welds, will they hold up? (or maybe bolts) Img_3167
Where it would come out the back of the carrier side
Welds, will they hold up? (or maybe bolts) Img_3168
And gear side.
Welds, will they hold up? (or maybe bolts) Img_3169
So now my choices are gamble with the bolt on locker i made up, and spend cash on 12 bolts and assorted hardwares, or take the gears to a pro welder and get them welded proper for probably alot more than the hardware.
What do you guys think of the bolt on locker?
Craftsman Dude
Craftsman Dude
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:45 pm
I wouldn't trust those welds either if you want it welded take it to a local community college and have the Instructor weld it up for you.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:47 pm
Weld everything on those gears that wont interfere with you putting them in.
Fearlessfront did it in one of his videos. Should look it up and see how he did his.
Krawler86
Krawler86
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:50 pm
I showed my friend that vid, which is why i went with this method.  That and finding noone else locking up one of these transaxles, doesnt lend much to alot of variation.
My only problem with welding is money, since my friend is convinced that these are fine.  I dont know anyone else to weld them, so money is a concern.  Which is why im thinking 12 nice shoulder bolts will be WAY cheaper than paying a welder.  But if someone says they tried to bolt these gears to the sides like i thought of and it blew the side gear to pieces because of the holes in it, id be gung ho cashing out on a good weld job.  But the cheap side of me that loves bolts and nuts wants to try the bolt on.
I always come up with ideas after ive already executed a previous idea.  Damn hindsight.
Also, what about a weld bead all the way around the perimeter of the side gears. bypassing the planets in the same way my bolts would, but with welds so the strength would be greater?
The community college instructor is not a bad idea.  I live fairly close to a PCC campus.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 6:54 pm
A VOC center should do it for free or very cheap. I remember welding all sorts of odd stuff when I was in Auto.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 7:25 pm
I'd try to cut a piece of large diameter pipe to go around the shoulder bolts... it will enclose the bolts and spread the clamping force evenly around the gear...
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 7:47 pm
I'll echo what others have said... I wouldn't trust those welds. I don't think your friend has an idea of how much pressure these gears can be under.
We used to weld up our difs before we started going with solid axles and have had multiple welds fail... when a weld fails in a transaxle it typically jams in between some gears and blows the case apart - which is never a good ending for a romp.
Have someone weld the bejeezus out of them, or try your bolt on option. Or both! Why not?
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Krawler86
Krawler86
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 8:23 pm
What do you mean?  Like the ID of the tube would contact the OD of the bolt heads?  Or like a large washer to cover the entire gear surface?
The way im imagining things, the bolts would essentially just be dowel pins, and the head / nut would just hold it in, all the force would be on the bolts and it should only need minimal clamping force to the face, as friction on the face is negligible.
Hmm, the more research i do, im kind of liking the bolt on locker idea. If i use some fancy hardwares, so far the metric 10.9 in 8mm OD is looking the most promising, though 8 is the largest OD i feel comfortable drilling. Id kind of like 6mm, but im unsure of their strengths. Still researching.
I like that the bolt on locker has a 0% chance to release slag into the trans, and if i lockwire the bolts and nuts to the diff carrier, even if they break, they cant wreak havok.
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 8:27 pm
I think maybe if you do individual sleeves on each one that were the same length and clamped it on that it would work even better. Would give it even more of a surface to rest on and give you less wobble (should there be any).
Krawler86
Krawler86
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 29th 2014, 8:31 pm
Im factoring cost of a real nice drill bit perfectly sized to give the shoulders a slight tap in interference fit.  Im going for 0 wobble.  My reservations on a sleeve, is it further reduces the shear pin size / creates 2 different metals to shear instead of a solid homogeneous bolt / pin.
I like the ideas of pins though.
Maybe a hybrid, 3 bolts and 3 peened in hardened dowel pins?
Moose
Moose
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 30th 2014, 1:37 am
Grind off the weld as best you can as stated above find a local shop have them preheat to 400 degrees and then tag that ship up!
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 30th 2014, 8:40 am
I would talk your buddy into welding a little on the opposite side of the current weld and run it, to me drilling holes in the gears is asking for trouble
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 30th 2014, 10:53 am
Is there room around the smaller gears? then I would get made a watercut or laser cut Locker gear, disc from your local supplier. If not i would make it by hand.
Like a big disc, with the gear pattern all around to lock it solid.
motorizedeverything
motorizedeverything
PostSubject: Re: Welds, will they hold up? (or maybe bolts)   Welds, will they hold up? (or maybe bolts) Icon_minitimeJanuary 30th 2014, 8:44 pm
man i wish i had a water jet
» lifting the GT6000 (no welds)
» Are My Welds Good Enough?? A Short Discussion
» Bolts & Nuts?
» Does anyone know how JOHN DEERE HYDROSTATIC HOLD UP
» New users on hold.
