| 1968 Simplicity Landlord Offroad | |
+8donaldcon Doug MasonMcK MatthewD marmower KyleDeere79 rstolz 1997 Murray 12 posters |
marmower Member
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | |
![Creepycrawler](https://2img.net/u/2812/37/66/46/avatars/999-39.jpg)
Age : 37 Join date : 2013-07-02 Points : 4945 Posts : 731 Location : Logan Ohio
Rockinator Member
![Rockinator](https://2img.net/u/2812/37/66/46/avatars/2502-41.jpg)
Age : 23 Join date : 2016-01-16 Points : 3335 Posts : 164 Location : Canada
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 18th 2016, 7:52 pm | |
| Looking great man! Them vampires should make it almost unstoppable! Would love to see a video of it going through the snow! | |
marmower Member
![marmower](https://2img.net/u/2812/37/66/46/avatars/2413-17.jpg)
Age : 23 Join date : 2015-10-23 Points : 3298 Posts : 46 Location : Michigan
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 19th 2016, 3:51 pm | |
| - Creepycrawler wrote:
- looks good, Love the new tires! Im digging the intake too, just dont forget to add a air filter
Thanks, I'm hoping on getting a high flow K&N style air filter but I'm still broke | |
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 20th 2016, 8:09 am | |
| In my opinion UNI filters are way better for offroad then K/N, They do much better at getting the dirt out of the air before the motor, and are much much easyer to clean. | |
donaldcon Member
![donaldcon](https://2img.net/u/2812/37/66/46/avatars/2291-72.jpg)
Age : 38 Join date : 2015-04-28 Points : 3883 Posts : 397 Location : Roseville, OH
marmower Member
marmower Member
MatthewD Veteran Member
marmower Member
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 26th 2016, 6:16 pm | |
| - MatthewD wrote:
- Nice air filter. Any ideas where your gonna put it?
Yea I think i figured out a spot to put it. Ill just have to build a guard for the bottom part of the filter so it wont get completely covered in mud or ill lift the hood up a little bit to put it under the hood this is where im thinking of putting the filter if i dont raise the hood ![1968 Simplicity Landlord Offroad - Page 2 Dscn1810](https://i.servimg.com/u/f68/19/34/75/62/dscn1810.jpg) | |
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 26th 2016, 9:35 pm | |
| You could put it on top of the hood somewhere, might look kinda ugly though. Not sure if you mentioned it before, but what kind of transaxle is in that thing? You have a regular disk style clutch like a cub cadet? | |
marmower Member
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 27th 2016, 8:00 am | |
| - mr.modified wrote:
- You could put it on top of the hood somewhere, might look kinda ugly though. Not sure if you mentioned it before, but what kind of transaxle is in that thing? You have a regular disk style clutch like a cub cadet?
I wish it had the disk style cub cadet clutch but it just has the regular v-belt clutch, which if you look closely at the first picture that I posted of the machine you can see part of the clutch system. But as for what kind of transaxle I couldn't tell ya, not now anyways but when I get home from school I'll look and see. | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![1968 Simplicity Landlord Offroad - Page 2 Empty](https://2img.net/i/empty.gif) | Subject: Re: 1968 Simplicity Landlord Offroad January 27th 2016, 12:39 pm | |
| the simplicity tractors have a transaxle made in-house by simplicity. they have a horizontal input shaft that is parallel to the axles. They have a driveshaft hooked to a right angle gear box that has two output shafts, one on each side of the tractor, one for the attachments and the other for the transmission drive. it has a belt from the ragb to the trans. | |
