 Portal Axles #UltimateLift
Moose
ZSmachines
TooIngenious
9 posters
Go to page : Previous  1, 2
TooIngenious
Portal Axles #UltimateLift - Page 2 Empty
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 20th 2014, 12:29 am
Doug Fackler wrote:
Milled steel. Pretty uncommon though. Might be able to find something in heavier equipment.
My friend's dad has a machine shop. I'll see what he can do.
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 20th 2014, 8:26 am
I like this Idea, not from a practical standpoint, but Ive always liked the Idea of portal axles. to get gears that will hold up you need to use the final drive gears, not the smaller gears used for speed selection. final drive gears out of a wheel horse or sears garden tractor would make a good choice.
TooIngenious
TooIngenious
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 20th 2014, 9:12 am
So use the bull gear and whatever the gear that rotates it is called?
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 20th 2014, 9:11 pm
If you get them custom made, you could get them so that bearings can be press fit into the center. Then you wouldnt have to have live shafts and could use bolts or solid shafts through the case.
TooIngenious
TooIngenious
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 21st 2014, 1:33 pm
I'm not quite following what you're saying. In my mind I would still need a shaft on the top for the top gear and a shaft for the bottom gear, or sprockets if I go chain. I would need a couple bearings to support each gear/sprocket. Those bearings, in my mind, would fit into the housing so that the shafts could slide in and out as I needed to do maintenance.
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 21st 2014, 5:32 pm
Oh yeah thats right, youre doing 2 instead of 3. I was thinking of the intermediate gear.
TooIngenious
TooIngenious
PostSubject: Re: Portal Axles #UltimateLift   Portal Axles #UltimateLift - Page 2 Icon_minitimeDecember 21st 2014, 8:08 pm
Nothing is really set yet, but I may go with two or three. I still might go with chain. I'm not really sure. It all depends on how deep I wanna get into it, I guess.
» Portal countdown.
» Trans-Axles
» Cheap 3/4" axles?
» MTD axles in a Peerless
» Sleeving axles?
