| ZSmachines's Craftsman Rally mower | |
ZSmachines Member
![ZSmachines](https://2img.net/u/2812/37/66/46/avatars/1923-36.jpg)
Age : 25 Join date : 2014-08-27 Points : 3918 Posts : 221 Location : PNW
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | |
ericsp0f Member
Age : 32 Join date : 2014-09-29 Points : 3674 Posts : 32 Location : Maine
ericsp0f Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower September 30th 2014, 3:32 pm | |
| - ericsp0f wrote:
- ZSmachines wrote:
- Well only a vid overview for now...
] Plug in don't work on my cell :'( yea got it to play now jest need to post a video of it going | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 1st 2014, 11:39 am | |
| Ha YEp I do. My fronts are actually the ones that 1997 Murray was gonna use on his craftsman build! I am gonna try and post some pics too, but I don't know if I c am from my iPod... | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 5th 2014, 12:02 am | |
| So I was wondering if any of you guys knew any tips and tricks to making a ton of power with an Oppy. Anything helps, as I really don't know how to make power. And also kinda want to know what transaxle I have ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) | |
ericsp0f Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 5th 2014, 10:31 am | |
| Can u post a pic of it I may be able to tell u brand off jest that thin I can tell u ware to look to find the model tag as far as mor power I can't help much mabby mor air and a bigger card | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 6th 2014, 11:43 am | |
| well it needs the heads to be removed to remove carbon buildup, so i was thinking about doing headwork while they are off. and i want to internally speed up my tranny, but i dont know how.. ill try and post pics today. i need a bigger front pulley, as the belt will slip a bit when i drop clutch in 5th gear... l | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 8th 2014, 11:34 am | |
| they have a higher gear ratio than peerless. mine looks good, in fact i just transplanted it into the murray because it looked better than a peerless. | |
ZSmachines Member
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 8th 2014, 2:55 pm | |
| - ZSmachines wrote:
- Is there a way to internally speed them up?
This trans (in the video) is a peerless 930. If you have a spare trans-axle of the same kind you may be able to do THIS. | |
ZSmachines Member
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 10th 2014, 2:58 pm | |
| It all depends what your needs for the tractor are. If you will be racing and have direct steer setup on it I would go handlebars. That way you can have a twist or thumb throttle and your brake setup on there. If you are doing romping with stock or modified steering (i.e. Rack& Pinion) I would leave the steering wheel. Remember if you will be romping with big meaty front tires you won't want direct steer. It would be hard to turn with the big tires. Now look at the ARMA racers. They run 13" or 15" tires or something like that. They are fine with direct steer, along with that you would want direct steer or modified steering if you will be going over about 30mph. It gets pretty sketchy.
PS- Modified steering can also include if you go through your steering and essentially "race prep" it. This means- Grease fittings, bronze bearings (or even new plastic ones), and just taking all the slack out of it.
It is all personal preference... | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower October 10th 2014, 11:55 pm | |
| I have direct steer, as I use the tractor as short transportation, and I was tired of the craftsman steering shenanigans so I ripped it all out and went direct. Switch those big beefy tires it appears to be fine o small super easy trails, but I haven't really gone on anything big yet.. | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower November 10th 2014, 8:19 pm | |
| Well small not much of an update, but the snow is supposed to come on Thursday, and I need to get this thing ready for winter romps. Any tips and tricks? Have never done it before.. | |
ZSmachines Member
![ZSmachines's Craftsman Rally mower Empty](https://2img.net/i/empty.gif) | Subject: Re: ZSmachines's Craftsman Rally mower November 12th 2014, 3:24 pm | |
| If you want belly pan, sheetmetal would do just perfect. Now, if you are looking for a skid plate to bash off rocks you will need something thicker. | |
ZSmachines Member
