  Allis Challmers 710 Tractor
Moose
8 posters
 Allis Challmers 710 Tractor Empty
PostSubject: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 18th 2014, 9:18 pm
Finelly got myself a new tractor.
Pulling tractor.
1970s Allis Challmers 710 garden tractor.
4Speed with reverse. 3F 1R
6 1/2 Hp Brand new Harbor freight motor.
Runs and drives good. It originally came with a 10hp kohler did good for a while but then it desided to quit.
But the 6 1/2 horse motor does pretty well..Better than the 10hp lol.
Let me know what you guys think.
 Allis Challmers 710 Tractor R10
 Allis Challmers 710 Tractor Unname10
 Allis Challmers 710 Tractor Tt11
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 18th 2014, 9:44 pm
I personally would have liked the pull start still intact. I would have rigged up a cool jack-shaft setup running from the pully on the other side of the motor. Couldn't be too hard just some shaft two pullies and two pillow block bearings. Right?
Moose
Moose
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 1:56 am
Looks like it needs a diesel :p good ol Allis though
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 12:13 pm
That's a good idea their and I would do it if this wast a pulling tractor. But by doing it that way im gonna have to worry about belt slippage during the pull. Plus by doing that I need to have shelids coving the whole belt system in order to pull.
A diesel motor is in my future plan lol.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 2:18 pm
any particular reason why its backwards?
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 5:01 pm
thats how cubs and deere's ran them to willis, q
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 5:09 pm
Will, that is so the tranny turns the right way. Isn't your Bolens like that?
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 19th 2014, 11:30 pm
Its backwards becauses the transmission needs to turn counterclockwise so the gears work correctly but the motor
turn clockwise so in order for everything to work I need the motor to turn counterclockwise so by running the motor backwards
everything works correctly.
Also for a tractor with stock gearing in 3rd gear at about half throttle it goes pretty fast. In 1st gear it makes an
excellent crawler.
MoMower
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 22nd 2014, 2:19 pm
Cool tractor. Love the looks. And if it runs, it's useable.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeAugust 30th 2014, 2:10 pm
Thank, Its currently not running.
Update on the tractor, the 6.5 hp worked good for awhile but once everything got broke in things went down hill from there.
I pulled the 6.5 motor off and put it one the Mud Machine and for this tractor im gonna find another motor for it
But finding a motor for this tractor ist easy around my area. I need a kohler k series motor..k241-k341.
 Allis Challmers 710 Tractor Fkkfk10
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeSeptember 3rd 2014, 8:21 am
She will be running and driving hopefully by the evening!
I finally found a new motor kohler k321 (14hp) Internals look good and clean. Hast ran in 10-15years but I was told that this motor runs so I guess we will see lol. Has spark. But i need to finsh the wiring and finsh up the fuel system, put some oil and fuel in it and fire her up.
I also go some pics...Tell me what ya guys think?
 Allis Challmers 710 Tractor Allis310
 Allis Challmers 710 Tractor Allis210
She barely clears the hood
 Allis Challmers 710 Tractor Allis110
 Allis Challmers 710 Tractor Allis410
MoMower
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeSeptember 16th 2014, 10:21 am
Looks like a.perfect fit. And if it spins.and ain't cracked, it will run. Good looking tractor btw.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeSeptember 17th 2014, 8:13 am
Well it does run it just runs like crap, idels half decent gotta keep playing with the fuel/air mixture screws to keep it runnin on
and idel but it will not throttal up, all it does when u throttle is up is starts to miss real bad then trys to die. The times when I do get it to throttal up it wont say throttal up and the same rpm for no more than 10seconds. I don't know what the problem is?
Its got fuel,spark,and compression.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeSeptember 17th 2014, 10:15 am
try putting the choke on when you throttle up. also, try adusting the points.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeSeptember 17th 2014, 2:06 pm
Well iv tried running it with the choke on but it tries to die, but I didt try chocking it while throttling it up
so ill give it a try when I get some fuel..I think its just not getting enough fuel. the points were replace and set I think to ethier .18 or .20 that's what I was told to set them to from kohler.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeJanuary 6th 2015, 2:32 pm
Update, This the tractor is currently sittin in my shop all in pieces and striped down the the frame and console.
Gonna be fully rebuilding it here soon. When its done it will look nothing like an Allis Chalmers 710. 710 2.0 lol.
Murray modder
Murray modder
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeJanuary 6th 2015, 2:46 pm
Allis Chalmers.....1420.
PostSubject: Re: Allis Challmers 710 Tractor    Allis Challmers 710 Tractor Icon_minitimeJanuary 6th 2015, 2:49 pm
Good idea. That will be the new number for the tractor when it gets repainted. 1420
» allis chalmers 710 6 speed off road tractor
» Allis-Chalmers B-110
» fast allis
» 67 Allis Chalmers B-10 manual/pdf?
