 Slant Industries T111 (John Deere 111) [Pic heavy]
802 Customs
B440
Craftsman1998
MoMower
Moose
15 posters
B440
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Empty
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeJanuary 12th 2015, 4:28 pm
Brrr. Do you have one of those kerosene rocket heaters? Point it right at the engine block. That'll get it to start without ether.
Hard to tell from the vid, but did you adjust the valves so the compression release would operate properly? It definitely was not working upon initial cranking.
Looks way to cold there to be working on metal outside.
802 Customs
802 Customs
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeJanuary 12th 2015, 8:33 pm
Great start! I've got one of those jd 111's, very tough little machine, mine just needs a little more leg room. I would love to swap in a twin, but for me oppys eat too much gas, and I will probably just end up tweaking the governor on the 11 horse flatty.
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeJanuary 16th 2015, 12:05 am
@b440 I unfortunately don't have a kerosene heater been looking at them but I keep having to buy truck and tractor parts but I have been looking at block heaters so I may invest in one of those well see :p I have a lot more free time in the winter than spring and summer so I gotta do my work in the winter while the construction season is slow
@802 you don't really have to just tweak the governor I was never really a believer in the "bolt on power" of carb swaps but I have a 10 horse in my simplicity that I swapped the carb off the deere onto 11 horse carb on a 10 horse motor you'd be surprised it was kinda hard to get tuned I have to mess with it when the weather changes but it seems to have a bit more oompf in the rearwards department so if all else get rid of the governor and slap a 12.5 carb on that's what I may end up doing with the motor I pulled from the deere!
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeJanuary 16th 2015, 12:32 am
Oh and I did do the valve lash but not sure about the compression release setting I am learning on the fly here am more familiar with diesel than vtwins
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 7th 2015, 8:00 pm
so it was about 40 degrees F today got a whole lot of stuff done between the massey and the deere even got the work space cleaned up a bit to have some room to work!
Anywho I started on the front suspension or lack thereof cut a piece of 1.5" square thick wall tube for the axle need to order some 3/4" heims for the adjustable hangulations and stuff and I also got a piece of flat bar for the mounting of the heims!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 AqELw80l
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 XplXlOtl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 NgFbeaNl
Did I mention badass?
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 MxRvxasl
Gonna keep the stock hood around till the vtwin is built the 12.5 should fit ok for now.
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 8th 2015, 11:13 am
That looks pretty sweet, should be real strong.
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 8th 2015, 7:59 pm
got the idea from the racing mower association :p was talking to a racer in canada that had that set up and he was satisfied with it. Dunno how the heims will handle jumps though
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 11th 2015, 1:54 pm
Did some "welding" today really need more heat in my welder.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 HkNKglul
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 BLONVFRl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 F0kQTeol
Something else to note! welding around a oily messy grassy frame sucks! I set it on fire a couple times.
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 13th 2015, 4:05 pm
spent 5 minutes dropping in the heims today allows me to get into the brackets and all that fun steering stuff. They are looking good though!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 RCThtYrl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 2bkP3jgl
just gotta order spindles and stuff!
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 13th 2015, 8:32 pm
I'd recommend some triangles... Especially where that axle is welded to the frame...
Other than that she looks good!
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 13th 2015, 9:51 pm
yup waiting to get some more 1/4 flat stock for gussets and stuff it aint gonna be pretty but itll be strong!
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 14th 2015, 9:45 am
Yea, only weak point is where the flat stock is welded to the beam. Just throw in a gusset where the nut is or the like and should be fine. You'd have to drop it very hard do bend that all up
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 14th 2015, 9:06 pm
yeah been throwing around gusset ideas Ill figure one out eventually lol. Now! I had a pretty fun day! What do:
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 ElzFNWol
These
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 VDlLECtl
This
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 XpFxf1Rl
And this have in common?
One bad gas tank :O
So I got the idea of strapping a bomb to the back of the deere for a gas tank... Sound like a bad idea? Probably but Im doing it anyway!
I got half a airtank and was beating it around the shop trying to figure out if I wanted to weld a cone on or what then I thought of gluing in a pvc joint so that is what I started doing!.
The airtank is kinda a oddball size when it comes to pvc fittings so I had to come up with a way to turn it down hence the tablesaw "lathe" my dad got a new bandsaw so I put him to work cutting out the circle because I couldnt cut a crooked line if I wanted to :v lol!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 QPbxlI3l
Huge mess.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 TDVOU8sl
Did the job though!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 4T0ah6gl
Looks ok but needs some lovins.
I used a box from one of my favorite places in the world to mock up the tail fin assembly not sure if Ill build that out of wood or metal or plastic or a combination. *shrug* Im gonna be bondoing the area between the 6" and 4" reducers to make it look a bit more like a continuous angle like the WWII bombs.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 UVJgT6il
So yeah Im not insane I just thought it looked cool!
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeMarch 29th 2015, 12:32 pm
wow havent updated in a while... Well I gusseted the front end and all that jazz got it figured out pretty good then removed the deck lift just to clean it up a bit and keep from being skewered in a wreck if it does wreck :p In the process of getting the head bolt out of the 12.5 that was stuck in there I found out the fins were cut deeper into the block than anticipated so it is now scrap. I took the intek crank case apart pulled the governor and checked to see if the holes lined up so were good there just need to get gaskets and all that fun stuff and Ill be up and running hopefully. On to the pics!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Sz1V3hel
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 873SwlKl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 B430KCHl
a possible spindle bushing of sorts still figuring those out.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 TDtOWH1l
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 A3g8KuDl
Motor test mount had to cut out for the oil filter and the drain line which needs extended.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 GBMIHWdl
Lack of deck lift lever, it is now just a tractor no more mow!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 YgXxZQHl
I test fitted the top half of the 820 and there are a few clearance issues that will need grinding.
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 IUh5hNIl
Out at mowron central! I brought the frame for q&a so it totally counts as a tractor pic!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 UBXlgAwl
The start of my shifter for the deere! I will be trying to do a few part series on how to layout and machine acrylic so you guys can make custom shifter knobs too!
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 3rd 2015, 4:15 pm
Just a bit of a update I dicked around in the barn a while the past week and got some shet done still lots to do but Ill get around to it!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 SMLxqeZl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 TmW7Rffl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Xttee4Nl
I left the data plate because it fit the military theme!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 VKXmDWTl
I stole the wheels off the massey because Im going to use the same wheel. I was going to get spindles and hubs from surplus center for a trailer axle but the measurments were leaning towards wheels thatd stick out a lot further than I wanted. This way the wheels are out far enough for stability but still look decent and give me room for fenders if I can find some I like!
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 QNwKwq6l
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 DxkqnfUl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 5Ftwx2Pl
Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 OZu1XVRl
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 3rd 2015, 11:37 pm
Those tires look killer on that thing. You could go with something similar.
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 3rd 2015, 11:39 pm
I agree, that thing looks sexy.
Check BMI for spindles.
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 4th 2015, 1:46 pm
I welded up the spindles from some pipe and plate and some 3/4" bolts I think they will work well just have to weld them in nice and hot. Got a nice 12.5 off Craigslist this morning just gonna pop the bottom delete the go near and put it back together no messing around with other stuff. As for wheels those will be staying because they are dot approved so yay high speed!
the old guy
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 4th 2015, 6:56 pm
Hey Moose What size are those front tires and where did you get them would like similar for my tractor
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 4th 2015, 8:21 pm
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 4th 2015, 8:25 pm
Get the same tires for the rear :v that would look pretty rally. Although not well offroad.
the old guy
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 4th 2015, 8:29 pm
Thanks Moose I'll check with my local tire dealer to see if he can get me a pair. he seems to be very reasonably price wise.
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 6th 2015, 9:07 am
They also have a pretty beefy load rating think the tire said something like 50 psi I'm running them at 30
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 6th 2015, 9:37 am
Looking good! You can run the tires at 15, better ride.
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 6th 2015, 10:50 am
The steel soldiers guys will love the theme at haspin!
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Moose
Moose
PostSubject: Re: Slant Industries T111 (John Deere 111) [Pic heavy]   Slant Industries T111 (John Deere 111) [Pic heavy] - Page 2 Icon_minitimeApril 9th 2015, 8:45 pm
yeah definitely concerned about ride quality doubt the seat will have room for springs lol so the rears will be aired down! @trb I hadnt even thought about that lol maybe I could trade it for a deuce...
» what could this john deere be?
» My Dynamark 836 and John Deere 100
» John deere SLX 38
» What do you guys think of this John Deere 300?
