Ok since this turned from a just bombin around the yard to a mowron style special I had to move it to the rally mower section and give it a new name. I started out just wanting something to tinker with and learn with so I experimented with it did a tranny swap locked it and lubed it then I did a tire swap tinkered with the engine and was content with it... For about a month.
Then I got to looking around at various pics for the skid deere when I was researching stuff for that and I was inspired! So work began on the deere yet again! It ran fine pulled great and was fun to drive so I had absolutely no reason to mess with it but I did anyway.
The base goals for the build are as follows: Goes fast Looks good Drives good Can keep up with the mowrons? (I think thats more of a driver mentallity thing Ill have to work on) :p
I already have a engine and I got a 820 through ebay (needs a pretty good bit of work) so drivetrain is pretty good to go. The major things are going to be reinforcing the frame for the transmission and eliminating as much of the frame flex as I can which means a lot of welding and angle iron and skid plates.
Now for the pics of progress!
Locker block
Just noticed the bat peeking through the crankshaft hole lol
Monolithic steering box that I am going to take apart eventually just to see how it works!
I could pretty much take the whole thing apart with a 1/2", 7/16", and a 5/8" wrench and socket I still got a ways to go but the rest is mostly fabrication/assembly and paint!
Pros: Precision machined 0 runout on the axle goes together beautifly
Cons: They expect me to run this with grade 3 bolts holding the bull gear to the hubs? not much room for a brake rotor on the areas machined for a key. No lock collars for the bolts not sure if this is a con yet buuuuuuuut... Broached aluminum bull gear hubs... time will tell.
I ordered this for simplicity sake so I could just slap it together and be done with it and I love the quality of it there may be more cons than pros listed but I assure you it is worth the money or at least I hope so.
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4953 Posts : 919 Location : Defiance, Ohio
Is the hood fiberglass or metal if its metal i would extend or raise the hood if its fiberglass i would put a smaller engine in it because its hard to work with fiberglass And you can't weld it lol
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6402 Posts : 1434 Location : east dublin georgia
Yeah it is a fiberglass hood and a kohler oppy dam fine engine but alas it doesnt fit, the third option I am somewhat reluctant to do is build a hood but I dunno if I wanna go that route
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
Dang stright! I was in the same position. Wanted the engine but didnt want to cut gaping holes in my hood. What do? Turn it sideways and only a minimal cut and air filter mod. Of course the exhaust is tricky but hey, i dont need a choke cable. I just reach forward and pull on the arm, spring loaded
Hmmm... well for now I'm gonna run hood less for the tractor party got bigger fish to fry atm but when I get around to it I'll probably build something custom
Age : 37 Join date : 2013-07-02 Points : 5021 Posts : 731 Location : Logan Ohio
I'm with red and doc on this one, way to cool of a hood to chop up and I always liked how when you turn a twin sideways the carb sticks out the hood to one side. At least do a test fit and show us how it would look
Im thinking Ill just build a new hood for it this winter I kinda wanna go automotive style and have removeable side panels then I can have a sick front bumper and not have to worry about being able to tilt it kinda like the JD 400 series
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
well bad news guys the kohler wont work for the deere :/ the 18.5 would be awesome and all buuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuut... Id rather have a 20hp intek vtwin :p I was helping out a older neighbor and he had a pos yardman in a corner said the tranny was locked up so I said I could probably fix that but he didnt want it anymore. I didnt even look at it just was thinking itd make a neat hood ornament for the massey so I slapped a log chain on it and drug it home with the massey after I got the yard crap pulled around that I was going to do I took a look at it.
Low and behold 20hp briggs intek vtwin I was to wore out to dance so I stood there and yayd :p Ill post pics someday. I included it in my update video so will link it here when it is done
Now for the bad... well kinda... It has a valve leak somewhere when I spin it I can hear it bypassing a valve on the compression stroke so the valves need to be reseated Im guessing, however since I got the motor for free I can take the money I was going to spend on it and invest that in performance parts/machine work aka port, polish, shaved heads, billet flywheel (I know cast iron is unlikely to explode but I like the idea of higher voltages to the plugs the bigger the spark the better), racing cam, better springs, billet rods, and lastly my personal favorites billet polished valve covers and roller rockers!!! Now is all this really nessicery? No not really but I am going to pick away at it one piece at a time and have it done by the next tractor party.
Brrr. Do you have one of those kerosene rocket heaters? Point it right at the engine block. That'll get it to start without ether.
Hard to tell from the vid, but did you adjust the valves so the compression release would operate properly? It definitely was not working upon initial cranking.
Looks way to cold there to be working on metal outside.
