 race car style ignition
2 posters
hutch17
race car style ignition Empty
PostSubject: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 7:58 am
Like the title says, I'd like to make a race car style ignition for my lt1000 with the 16.5 hp briggs. I've read on the forum that you need a relay to switch the polarity of the feed to the coil. I was wondering if anyone has used an on switch to turn the circuit on and then a momentary push button for the starter as seen in many race cars, mud trucks, ect. Any help is appreciated thanks in advance!
PostSubject: Re: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 8:47 am
I'm a bit confused here... Switching coil polarity? Ignition?
If its a simple pushbutton start you're after, it's dead simple, no relays required. You'd need to run a positive feed from the battery, thru a momentary button, thru a fuse, to the trigger terminal on the starter relay (solenoid). Run the kill wire from the magneto coil to a toggle switch, then from the other switch terminal to ground.
That's the simplest form. Sure enough, you COULD make it more complex than that. How complex do you want it?
You COULD I suppose, use a relay on that same toggle switch to make it so that it cannot crank with the switch off- then again, you could just use a DPDT switch. There's probably 10 ways to handle this.
hutch17
PostSubject: Re: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 9:27 am
I read a thread in which someone said you need a relay but that was when using an automotive ignition. I guess mine is way simpler. What size wire would be sufficient?
hutch17
PostSubject: Re: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 10:46 am
I'd also like it to not crank with the switch off, as that's pretty much the point of the switch haha.
PostSubject: Re: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 10:54 am
I would think the point of the switch, is to shut the engine OFF...
18ga wire is more than plenty. Both circuits are low-current.
hutch17
PostSubject: Re: race car style ignition   race car style ignition Icon_minitimeAugust 10th 2014, 4:50 pm
Ok awesome thanks a lot for the help!
» onan ignition
» Ignition switch help
» Homebrew HiPo ignition
» Kohler ignition module - bad or something else?
» Direct replacment ignition coil?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Wiring Systems-
