| LMM's Bike Trike! | |
+6jonnya redlinemotorsportts mr.modified dwcopple kawasaki220 LAWN MOWER MUDDER 10 posters |
Age : 23 Join date : 2013-04-08 Points : 5186 Posts : 913 Location : Central Pa
| Subject: LMM's Bike Trike! July 17th 2014, 9:24 pm | |
| I started building a trike out of my very first bicycle. It was a 2005 (I think) Huffy Rocket 20". I got it when I was five or six, possibly even seven I honestly don't know. I still ride it, well I used to ride it until both my tires blew out while I was riding it. Also my grips and pedals are falling apart. So I think I can reuse the front tire by putting a tube in it. I also found a nice length of 3/4" rod that will work perfect for my axle (same kind of stuff I used on the Rally Mower). I am trying to get 15x6.50-8 front tires to go on the back, but I only have 6.50-6 rims that have bearings of bushings on them. Any ideas on how to mount a set of rims on? I also went rummaging through my junk-yard with some 2+2 and a screw driver. Looking through all the string trimmers that I have. First one I checked was a toro with a missing trimmer head and a leaky gas cap. Took off the air filter sprayed in some 2+2.... Pulled the cord ONCE.... AND.... BAM it started! First pull! So I took it back into the shop and started stripping everything off except for the motor and the clutch. Found out that the clutch housing and the clutch mechanism are two different pieces. So I took the cone that holds the clutch to the motor (press fit bearings) and I cut it down so I can weld a sprocket on the shaft. Took a sprocket that looked like a good size (thinking gear ratios), and welded it to the shaft. That is all for today. Tomorrow's work will be (hopefully) will include:
Finding bearings of bushings for axle supports. Fastening sprocket and hubs on axle. Making brakes (I am thinking scrub brakes like on an old gokart). Making foot pegs, brake pedal, throttle, and kill switch. Making chain right length. Putting on tires. ^^ Slicks from a ZTR mower that the guy replaced but are still good LOL Paint? Test-Ride!
Hopefully I will have pictures tomorrow. | |
Age : 23 Join date : 2014-01-22 Points : 4548 Posts : 546 Location : north carolina
| Subject: Re: LMM's Bike Trike! July 18th 2014, 9:09 pm | |
| now i understand what you are doing like it but i think it shuld be a hybrid motor and pedeling keep it up like it | |
dwcopple Member
| Subject: Re: LMM's Bike Trike! July 19th 2014, 8:35 am | |
| gonna stuff the tires into huge PVC pipes and make a drift trike that is all the rage right now??? | |
Age : 34 Join date : 2013-11-02 Points : 7141 Posts : 2907 Location : New Jersey USA
Age : 27 Join date : 2013-03-18 Points : 7460 Posts : 3131 Location : raleigh nc
| Subject: Re: LMM's Bike Trike! August 7th 2014, 7:33 pm | |
| Nice, you might want to run some tubing or plate gussets from the rear hard tail to the part on the frame where the seat goes into, like this: Edit: I know you are going to renforce it, just making some suggestions. | |
| Subject: Re: LMM's Bike Trike! August 7th 2014, 8:59 pm | |
| Did you ever have a Honda or Honda Clone? They have two flanges that stick out with holes in them that the tank mounts to. these flanges stick out on each side of the seat post. I was planning on welding flat steel to the frame and bolting it to these flanges like a four-wheeler with motor mounts on the top and bottom that reinforce the frame. I was also planning on making something like that. | |
| Subject: Re: LMM's Bike Trike! August 7th 2014, 9:22 pm | |
| - LAWN MOWER MUDDER wrote:
- Did you ever have a Honda or Honda Clone? They have two flanges that stick out with holes in them that the tank mounts to. these flanges stick out on each side of the seat post. I was planning on welding flat steel to the frame and bolting it to these flanges like a four-wheeler with motor mounts on the top and bottom that reinforce the frame. I was also planning on making something like that.
Im not sure thats a secure anchor point, i mean aluminum tabs ment for a 5lb gas tank, but if a shock load comes, then youre looking for a new frame and engine because it broke and bent. I mean, you can try, just dont want to see that nice engine ruined. | |
| Subject: Re: LMM's Bike Trike! August 11th 2014, 10:04 am | |
| I found out that TSC has a weld in pulley hub that had the same outside dia. that the inside dia. of my sprocket is. WOOHOO! So I must get one of those and all that's left is....
LIST: Sprockets, Chain, Brakes, Gas Tank, Line, Filter, Handlebars, Brake Lever, Twist Throttle, Cables (Brake, Throttle), Tires (Slicks Drift Trike style yo!), Paint,
Will also need a reducer from 1/4 to whatever size fuel line that the clone uses.
All for today will update as the build goes on! | |
| Subject: Re: LMM's Bike Trike! August 18th 2014, 10:55 pm | |
| Looking pretty good. Best part is that it's light, easy to move around, and doesn't take up much space in the garage. Looks like it might be a wheelie machine. | |
jonnya Member
Age : 49 Join date : 2014-08-19 Points : 3837 Posts : 95 Location : Norfolk, England, UK
| Subject: Re: LMM's Bike Trike! August 20th 2014, 4:05 am | |
| Good work fella! I wish I was doing stuff like this when I'd been 13, top skills!
| Subject: Re: LMM's Bike Trike! August 21st 2014, 12:39 pm | |
| Yes a wheelie machine is what it is. I rode rode it yesterday. Even with posi it turns fairly good, even on grass. I also found out that my bushings are worn through already. So I ordered some ball bearings and made a custom carrier made of a piece of pipe with the bearings tapped in and a grease fitting installed. I just got done with it so I will weld it together this afternoon yet. It seems to be holding up really good. I forgot to mention that I got a brand new tire for the front for free.
That is all I got for right now, will continue updating as it goes. | |
| Subject: Re: LMM's Bike Trike! August 21st 2014, 7:09 pm | |
| Lets see some riding videos or some finished pics! | |
| Subject: Re: LMM's Bike Trike! September 18th 2014, 3:20 pm | |
| did u get the tenshoner on it or made a vid i really like this i think i might make one my brother | |
| Subject: Re: LMM's Bike Trike! September 18th 2014, 7:06 pm | |
| Figured out it wasn't my chain. It was the 5+ year old centrifical clutch that sat out in the rain and got rusted for about 4 years. It was rattling and making noise right before it hit the high RPM setting. That is why I could never hit full speed, I was never sure what the sound was. I cleaned and lubed it really good and it worked, once, I got it going out through my parking lot and I must have hit 40MPH. Time to change the gearing lol with the off camber from lowering the rear of the bike and the posi traction and not being able to turn it got pretty sketchy. lol. I may take a video of it sooner or later. Currently it is sitting in my trailer taking up space, lol.
I did put front brakes on it and a finger throttle. The throttle I used a bicycle brake lever and positioned it right at the rise in the bars. This let me use it as a thumb throttle. The front brakes are ran exactly like they would be on any regular bicycle. | |
| Subject: Re: LMM's Bike Trike! November 26th 2014, 10:53 pm | |
| Maybe some tin fenders would look classy on the back. Im sure you wernt exactly bone dry, lol. Very cool build tho, better than 3dmachines thats for sure. | |
| Subject: Re: LMM's Bike Trike! November 26th 2014, 11:00 pm | |
| lol yeah I couldn't stand having to operate a manual clutch on something like this. I like being in control with BOTH my hands on the bars. I will have to see about the fenders.. I know where I can get a front one, but the motor and drive is in the way for rear fenders. I'll see what I can do. And yes, I was 100% completely dry blasting through slush at 20+ mph with no fenders. Thank goodness for Carhartt Jackets and Bibs! *sarcasm, I still got soaked!*
Last edited by LAWN MOWER MUDDER on November 27th 2014, 10:36 am; edited 1 time in total (Reason for editing : I honestly don't know...) | |
