| All Around Use Tractor AKA The Monkeywards | |
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5206 Posts : 392 Location : west chazy ny
| Subject: All Around Use Tractor AKA The Monkeywards Tue Jun 03, 2014 11:12 pm | |
| Hey guys I got a new project going some members might remember me others not lol it's been like a year ugh. Anyways I picked up a 83 Montgomery wards which share the same design as the wizards mtd ect. This one has the factory 5speed peerless witch is the main reason I bought it as I don't care for the variable speeds lol. Stuff I've done so far -Peerless Transaxle with bearings and seals. I've pulled and diss assy/cleaned/fozzy locked axle/added air vent with hose/sealed case with sealant/engine honey added as the lube/4" pulley shimed pinion for less up & down movement. -Built double pulley clutch along with linkage/relocated pedal to left side/rear and clutch pulley retainers. -Belly cover to protect belt/pulleys/linkages from sticks ect -Added pillow block bearing to steering column/added shim under gear for less play/upgraded steering linkage/right side spindle hole drilled for pin instead of retainer clip. - Old b&s 10hp flatty removed and replaced with 1990 b&s vanguard 14hp ohv with full oil pressure lub/4 1/2" front pulley
Lots more to do lol pics soon lol | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
Age : 25 Join date : 2013-04-05 Points : 4962 Posts : 661 Location : New Smyrna Beach,Fl
gearheadmike Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Wed Jun 04, 2014 7:41 pm | |
| I've should of took more pics when I started but here's some and more to come. Not much customizing right now just upgrading and bettering the original stuff. When I first got it Belly pan install for clutch/belt protection. Double clutch better then original single Fozzy lock for the trans my first one ever cleaned it up with grinder went together good. Trans just back together with the pulley swap and lube added. My battery holder angle corners front and rear with rubber hold down. Bearing added to reinforce the steering column instead of the $hity plastic one. Added a better tie rod end to steering rod instead of the sloppy original 90degree bent metel one. Right spindle nothing big added shims & drilled hole for carter pin as I don't trust the original retainer ring Also got new oil and filter and carb cleaned today fired right up from sitting 5 years just need slight carb adj and new plug. Also got starter solenoid mounted. What's left befor test drive -adj carb -wiring -mount fuel tank -engine pulley belt retainers - bolt hood on | |
| Subject: Re: All Around Use Tractor AKA The Monkeywards Wed Jun 04, 2014 7:43 pm | |
| For a MTD, thats impressive man! Mine was also a turd, but you just need to put time into it and make it right, awesome. what kinda tires are you putting on it? And how do you like that lincoln? i was looking at one myself | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4579 Posts : 467 Location : Greensburg, PA
gearheadmike Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Wed Jun 04, 2014 8:22 pm | |
- For a MTD, thats impressive man! Mine was also a turd, but you just need to put time into it and make it right, awesome. what kinda tires are you putting on it? And how do you like that lincoln? i was looking at one myself
I'm not sure yet would like to have a set of sport quad rear tires as I want it for road/dirt/lawn/offroad. And my welder I love best welder I've had. I got it for a steal $50 one day I hope to get the regulator and tank for it other then that it's all set up for gas.
Last edited by gearheadmike on Wed Jun 04, 2014 8:33 pm; edited 1 time in total | |
gearheadmike Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Wed Jun 04, 2014 8:23 pm | |
| - camomanusa wrote:
- Im liking it! I have the same one but it has square headlights instead of round, would you say its newer or older?
Hard to tell mines a 83 but I also for got a wizard with same hood but rectangle headlights prob all in the 80's tho | |
gearheadmike Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Wed Jun 04, 2014 8:30 pm | |
| Altogether I had 3 of these including the one I'm working on now. My first tractor I started off-roading /romping with My lifted one I had The one I have now. | |
camomanusa Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Thu Jun 05, 2014 7:23 am | |
| [quote="gearheadmike"] My lifted one I had Do ya have a diagram on how exactly you did the steering on this? I wanna know for when I start building my Ford. | |
gearheadmike Member
| Subject: Re: All Around Use Tractor AKA The Monkeywards Thu Jun 05, 2014 12:26 pm | |
| I don't have a diagram as I built it off the top off my head. Steering shaft and tie rods were from a atv 2x3 box steel axle with bronze bushings and center pivot with 3/4 spindles from a snapper. I had to weld 2 arms on the drop frame to mount a bearing to to hold the bottom of steering shaft. Then cut and welded up my tie rods to size. It was. Direct steer setup.i might have pics. | |
