$75 tractor project
+6 Craftsman1998
TokyoDrift99
Angchor
pukesniffer
10 posters
Author Message pukesniffer New Member
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: $75 tractor project May 26th 2014, 6:22 pm just got an old tractor not sure what make it is but got some pics to show. any ideas of the make let me knowVIDEO
Angchor Member
Age : 67Join date : 2014-04-14Points : 4422Posts : 491Location : Index, Washington pukesniffer New Member
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Angchor Member
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: Re: $75 tractor project May 26th 2014, 7:03 pm if im lucky when i get some of the crap paint off ill get some clues as to what it is
redlinemotorsportts Mod erator
Age : 27Join date : 2013-03-18Points : 7486Posts : 3131Location : raleigh nc Subject: Re: $75 tractor project May 26th 2014, 8:18 pm Score dude!! Thats a sears, not sure on the model, but probably a ss12.
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire TokyoDrift99 Member
Age : 25Join date : 2014-03-28Points : 4037Posts : 111Location : Vermont Subject: Re: $75 tractor project May 26th 2014, 8:57 pm Does it run? What does it have for an engine? Cool project.
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: Re: $75 tractor project May 26th 2014, 9:00 pm not sure yet it started to rain too rain today got compression and spark so im hopeful that it will run with gas
Age : 23Join date : 2014-01-22Points : 4574Posts : 546Location : north carolina Subject: Re: $75 tractor project May 26th 2014, 9:38 pm 75 not bad for a sears ha a old sears, you should make it a lifted offroader
TokyoDrift99 Member
Age : 25Join date : 2014-03-28Points : 4037Posts : 111Location : Vermont Subject: Re: $75 tractor project May 26th 2014, 10:21 pm It should run, but you might need to clean/rebuild the carb depending on how long it sat, and if it had ethanol gas in the fuel system.
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: Re: $75 tractor project May 31st 2014, 12:31 pm i got it to run today!!! had to reset the points and get a new condencer. the make shif gas tank i used only let me rum a couple min at a time but it goes. gona try to get the tank cleaned and drive it today as well i hope if the rain holds out!!!
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire kawasaki220 Established Member
Age : 23Join date : 2014-01-22Points : 4574Posts : 546Location : north carolina pukesniffer New Member
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Craftsman1998 Veteran Member
Age : 26Join date : 2013-10-30Points : 5155Posts : 1068Location : New jersey craftsmancole Established Member
Age : 25Join date : 2013-04-05Points : 4965Posts : 661Location : New Smyrna Beach,Fl Subject: Re: $75 tractor project June 1st 2014, 3:11 pm Its definatly made by sears but it might be a roper, if it is, its pretty rare.
camomanusa Member
Age : 25Join date : 2013-09-15Points : 4582Posts : 467Location : Greensburg, PA Mitch'sgarage Member
Age : 25Join date : 2014-03-24Points : 3945Posts : 46Location : Omaha, Nebraska Subject: Re: $75 tractor project June 11th 2014, 9:44 am If you are not all about keeping the tractor stock you could make a new frame for it that is lower and lighter. then put the body on that and build a sweet racing mower. That is what I would do with it but what I have seen in the mower community and with my self racers are not cheap to build. I'm not trying to tell You what to do that is just what I would do, it would be pretty sweet!
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: Re: $75 tractor project June 11th 2014, 7:03 pm i could make a racer.... i just found 2 other sears tractors look to be a bout the same year(66-70) but went i stop the cat is never home..... so for now a mudder... and then a mudder for my son ..... then a racer... but got some work to do on this one... having some grounding problems with the electrical.
k2500life Veteran Member
Age : 27Join date : 2013-06-19Points : 5374Posts : 1135Location : Southern Florida pukesniffer New Member
Join date : 2014-05-06Points : 3877Posts : 16Location : jefferson,new hampshire Subject: Re: $75 tractor project June 20th 2014, 6:19 pm so im waiting for some parts to come in the mail but here is a little of what is to be done next!VIDEO
$75 tractor project
