 Welding SMAW D1.1 3g position.
5 posters
Welding SMAW D1.1 3g position. Empty
PostSubject: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 1st 2014, 2:22 pm
So Ive been going to Voteck welding. Im enjoying it for the most part. I do not enjoy however the AM class. Half of them are morons... to put it politely.  lol!
These pieces are made from 2 3/8in 7in long X about 3in cut with an included angle of about 45*. 22.2* on each piece. They are set to a 1/4in backing bar with a gap approximately 1/4in -/+ 1/16in.
When it is tacked together, it is welded using SMAW, or stick welding in the the 3g position, otherwise know as vertical up. I used 3/32 7018 at about 94-98 amps.
I believe we are allowed up to 1/8in inclusion and still pass for certification.
The piece on the left is the Root bend, you can see 2 small boogers, I believe they are from small amount of slag where there was a gap between the 3/8in plate and backing bar. The bend was slightly off center, but it still would pass.
The other piece, the Face bend you can see right in the middle is where I didnt grind down quite far enough. It actually looks worse than it really is, when it was bent it makes the welds more pronounced. Instead of it being smooth like when it was ground down, you can actually feel the weld beads.
Hopefully, I can do this again when it comes test time. ...and hopefully i got all my facts right up there lol
This coming week I will start over again, but this tin in the 4G, or overhead position.
Welding SMAW D1.1 3g position. D1_1_p10
Welding SMAW D1.1 3g position. D1_1_p11
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 8:21 am
Is it really that bad? Or was everyone speechless?  lol!
Gona work on overhead today.... maybe.
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 10:50 am
I didnt see this at first, and really I can't make out the welds Welding SMAW D1.1 3g position. 1222323911 lol
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 11:31 am
I cant make out the words lol.
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 1:13 pm
yeah, i never saw this either
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 3:43 pm
looks like doo doo... do it again
aincha done yet?
I wanna see you butt weld 2 3/8 plates and bend 'em like that THAT would impress (mean old man grin)
PostSubject: Re: Welding SMAW D1.1 3g position.   Welding SMAW D1.1 3g position. Icon_minitimeMarch 10th 2014, 8:05 pm
aincha done yet?
Hmmmmmmmmmmmmmmmmmmmmmm...........................................
lol
» Welding problem please help!
» which welding wire is better?
» Welding help Needed..
» welding rims?
» What Welder is the best for mower modding?
