| 11hp tecumseh, worth building? | |
Jamus Established Member
| Subject: 11hp tecumseh, worth building? December 13th 2010, 3:59 pm | |
| I have a craftsman 11hp tecumseh motor that came on my murray widebody. Are tecumseh engines worth messing with? My thoughts were to gradually rebuild it as a horizontal shaft motor and build a gocart with it. | |
| Subject: Re: 11hp tecumseh, worth building? December 13th 2010, 8:20 pm | |
| Some people think teccys are the greatest motors- other dont like em- me, id rather use a briggs. I do have a running ( well was running when it went on the bench) 12HP ohv teccy i might slap on something someday - it leaked oil thru the breather badly tho. Now does it run? If it runs, id use it on a beater or something- itd be good for a go kart. If properly modded, a verticle shaft can be mounted horizontally. Flat heads are better suited for it- as OHV motors need oil in the rockers, but if theyre tilted so far and the oil level is adjusted correctly, they can be used as well. Heres a briggs 14.5 hp ohv on a racing tractor: I watched this thread and the guy said he kept breaking cranks , i imagine its because of over revving it and it was gone thru with all aftermarket pieces. In 'normal' use id say itd be pretty reliable. Id mount the motor so the governer is up ( so you can keep it in the motor- and wont leak oil) - the exhaust would need clearance and importantly, the carb would need a custom intake to be mounted in its normal position. Some year i might tinker with one of my verticle shafts and mount one sideways - i think the crappy 10HP off my agway would be a good canadate. | |
| Subject: Re: 11hp tecumseh, worth building? December 13th 2010, 8:27 pm | |
| My 11hp is a flathead so no problems there. You didn't mention it, but would an oil slinger/dipper be needed on the end of the crank? I've seen some 5hp briggs converted and they needed it to supply proper oil. I'm just really bad about seeing things sit and go to waste. If the motor runs, I'd spend extra money putting it into something just to make use of it. Homemade golf cart was another idea I had rattling around that I could use this motor for. | |
| Subject: Re: 11hp tecumseh, worth building? December 13th 2010, 9:01 pm | |
| Id leave the slinger intact - itll still splash oil up to the bottom of the piston . Yeah i kick myself for junking some decent tractor stuff i had before we moved here and even before i moved south.
Right now i have something like 8-10 spare motors that run, and a couple ive been meaning to see about rebuilding sometime ( decent block, just need rods/pistons/rings). Nephew just gave me the 11HP off his yazoo RER and also the transmission. | |
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
