 TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!
802 Customs
muddstir
rarbaugh07
Carshowkid
CornShuck4CE
Mitch'sgarage
Angchor
Murray modder
camomanusa
mudmonkey06
motorizedeverything
TroyBilt Pony
untrusty huskee
B440
83ratrodmurray
the craftsman mudder
Moose
T-Dub13
mrkadage
JamisonCampbellRacing
Craftsman1998
PuppetKicker
Marines2621
MowBandit
redzz02
50 posters
Go to page : Previous  1, 2, 3, 4 ... 13 ... 23  Next
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Empty
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:05 pm
looks good, i wish the frame im workin on was in that good of shape Razz
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:07 pm
Thanks, Oh and this was pretty rusted. But I cleaned it up when i dissasembled the Craftsman.
Should I bother weld up all the holes? To clean it up?
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:11 pm
im doing that on mine, but its cause i plan on putting this in tractor shows, and im wanting more experience in body work so this is like a experimant for me to learn what i can do, and what i need to learn
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:31 pm
looks really good, gonna be a heavy lil sum bitch!
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:32 pm
Sounds good, I might do the same. Then you should get a piece of brass or alloy to clamp behind the hole, that way you'll weld up those holes real easy and without a 1 lb lumb of welding wire on the backside  Very Happy
Need to get some Countersunk 5/16" bolt for the left side, if the pulley will mount like this.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 A75A35D9-0327-43D6-8411-FFB42515F6F3_zpseu9zfuqq
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 A54F9528-CA5F-4722-B9AC-75387410EA73_zpslprac0h7
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:35 pm
Thanks! Heavy? ya think, hmm well maybe... some but I allready "ordered" the gearbox mount in Alloy 6082 at the cutter at work.
Since I mount it like this, I can use aluminium.  Very Happy
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:38 pm
Your gunna weld the box steel so the 700 plate is flush with the frames motor deck right?
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:43 pm
Nope, Lowered like you see in the "mockup". Why did I miss something?
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 5:52 pm
Why like that? i guess you could run a belt like that but it being flush would look alot better in my opinion, probally help in clutch making too
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 6:02 pm
I'm trying to keep this small and low to the ground that's why.  And for the Hilliard clutch to track properly on the "V" and not just "/" this was the way to do it. For a perfect Tracking.
Idk tbh, I'm new to belts not connected to a CVT Very Happy
Here is the rear fender(well one from the web) As you can tell, not much room for a 700 in that square spot.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 B1921f86-6f61-47fd-9b1d-d791231245d5_zpsc1ef3259
Here's the seat pan I'm getting,
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 T2eC16FkE9s4Z-UBLBR0OLQCJw60_57_zpse031930d
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 8:25 pm
kinda the same seat as mine, less broken lol. i didnt know you were puting a clutch on it-or i just forgot.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 14617611
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 7th 2014, 9:20 pm
Love your clean builds man
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 8th 2014, 4:42 am
thank you Sir!
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 9th 2014, 6:40 pm
Nice, and I yes had the Hillard clutch from before, so I decided, why not try it. It's only rated up to 13hp so we'll see how it handles the 20hp.
Playing around with mock ups, on how to do steering and rear axle mount.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 59B79214-17CE-4885-84AD-CBE90A7BA709_zpsil26giaf
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 675E36C2-0883-4B54-B4D7-1BDB531EBEE0_zpsmiswkypl
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 9th 2014, 7:26 pm
I'd look like a monkey ridin a milk jug on that thing lol
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 9th 2014, 8:42 pm
Might as well stich up a seat and put it on the 700  lol!
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 9th 2014, 9:02 pm
I was thinking that too red. Stick a 1/2" piece of soft rubber in between the 700 and the pan and go that way.
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 10th 2014, 2:24 am
No no, that's too close to the steering wheel. The ass needs to be on the "hitch" plate or even further behind.
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 10th 2014, 2:25 am
So will I lol
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 12th 2014, 4:56 pm
Dash / Console build, Use some old cardboard or plain paper as templates.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 5027F0D3-BB15-4A27-A6FA-4FE60D94B96B_zpsjl2jyom5
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 E3584690-4FCA-4C08-B1DF-D048AD15331A_zpsz5gkfyme
I'll use the part that I cut of the hood, to re-inforce the end of the "new" hood.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 33B8F674-A3BC-4A56-BC30-024F1F6FFC80_zps1pe5xnyr
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 1:35 pm
Since my V-Twin won't come until feb, worst case march (together with the rest of the bigger parts), I decided to CAD one up in paper. After a great amount of copy work and some forrest's later i managed to get one to 1:1 scale of the Briggs V-Twin.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 89BD388B-807D-468E-ADE5-723B8852876D_zpsa68cg1id
It's actually bigger than i Tought or imagined.
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 37B826DB-F7A8-4024-BBDF-B4DCB79B16AA_zpstkhzpc9a
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 906670FC-DD5B-45F2-85C1-C8132AF12ACE_zpstmfvb4bm
TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 E1C8047E-866B-4569-AC8B-5D6A89B12B0E_zpsigjgneor
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 2:52 pm
Mine hangs off the sides of the frame too and it's probably half the size of the frame
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 2:58 pm
Shoulda banned CAD from the contest. Now we have to rely on your shipping delay or the rest of us are doomed lol.
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 3:02 pm
Yeah that's just cool looking tho, and so does this, the outline is missing so the exhaust ports + about 4" protruding further out than that whats showing here  bounce
And I might cut 2" in the front, but that would mean I would have to dissasemble either the engine or hood for an airfilter inspection.
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 3:03 pm
lol no I doub't that  Very Happy
PostSubject: Re: TD's John Deere 210 R - "Help I Shrunk my John Deere 210"!   TD's John Deere 210 R - "Help I Shrunk my John Deere 210"! - Page 3 Icon_minitimeJanuary 13th 2014, 3:49 pm
Need some of you Nor'eastern boys to head out on yer boats and hijack his shipment lol
Only diff in how TD lays his stuff out is a computer draws the stuff on the paper... I sketch... cardboard/posterboard is the BEST way to mock up sheet steel or tinwork. To all you fellers who need to do some fab work in metal, spend a coupla bucks on some posterboard and tape FIRST. It will save you a LOT in the long run.
TD has his drawings and access to a water cutter... He'd be a fool not to use them. Nothing he does though couldn't be done with a torch, some die grinders, and some elbow grease. This contest is all about imagination and fabrication, and THAT TD (and a lot of others here) has in spades.
Milk drinkers
Page 3 of 23Go to page : Previous  1, 2, 3, 4 ... 13 ... 23  Next
» John deere SLX 38
» John deere or Cub
» 1970 John Deere 110
» Got This John Deere 110 For $200
» John Deere 111
