| Tractor tips/tricks & mod's that DIDN'T WORK. | |
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Tractor tips/tricks & mod's that DIDN'T WORK. December 9th 2013, 6:22 pm | |
| Have a failed success story you wanna share? It may teach someone later on down the road, learn from your mistakes, lots of headaches, or prove someones original idea as a bad one. My experience was when i build my clutch on the wrong side of the tractor, it suppose to be on the slack side. The engine pulls the belt from the rear pulley to the front, and you dont want a clutch there, you want it to be tight like a rope. This pic illustrates what i was dealing with on my setup. | |
Age : 49 Join date : 2012-04-05 Points : 5704 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Tractor tips/tricks & mod's that DIDN'T WORK. December 9th 2013, 8:07 pm | |
| - Stretch44875 wrote:
- But all my ideas work!
There has to be something that either didn't work, didn't work very well, or not good enough to the point where you wouldn't recommend doing it. | |
Join date : 2013-06-01 Points : 4813 Posts : 578 Location : West Virginia
| Subject: Re: Tractor tips/tricks & mod's that DIDN'T WORK. December 9th 2013, 8:10 pm | |
| i would not recommend putting a much larger engine pulley on a unit w/ vari drive. My pony did 23mph (GPS) w/ 7 inch engine and 7.25 transaxle. Id much rather have gone a 4 inch motor to 4 inch transaxle after my vari bombed Turning a peak of 5700 RPM didnt help much either | |
| Subject: Re: Tractor tips/tricks & mod's that DIDN'T WORK. December 9th 2013, 9:22 pm | |
- Woah, you can sense engine rpm? Forget the tach I want, I'll just drill a hole and put you in my dash!
Lol i got the el cheapamatic 13 dollar tach off ebay lol | |
| | | crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4896 Posts : 412 Location : livingston texas
| | | | 1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
| | | | Sponsored content
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
