| mods & tips | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 14th 2014, 1:45 pm | |
| post mods & tips that you have used and know work. post a discription and pics, if you can. some ideas are brake upgrades, engine tips, tranny tips, belt & chain tips, and whatever else you come up with. ![mods & tips Icon_biggrin](https://2img.net/i/fa/i/smiles/icon_biggrin.png) | |
RCG Member
![RCG](https://2img.net/u/2812/37/66/46/avatars/571-85.jpg)
2016 Build-Off Finalist
![mods & tips Empty](https://2img.net/i/empty.gif) | |
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 15th 2014, 9:51 am | |
| here is an easy way to get rid of those stupid carb silinoids! go find a push mower carb and take the bolt out of the bottom of the carb: ![mods & tips Projec59](https://i.servimg.com/u/f56/18/62/03/97/projec59.jpg) now you have to grind it down about 1/4", get the best gasket you have, take the silinoid out of your carb, and put this one in. this is what you would thake out: ![mods & tips Projec60](https://i.servimg.com/u/f56/18/62/03/97/projec60.jpg) this helps clear up your wiring and engine bay. you can also just cut the plunger off of the end of it if you want. | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 15th 2014, 9:58 am | |
| I circled the end of the plunger that i cut off ![mods & tips Projec76](https://i.servimg.com/u/f56/18/62/03/97/projec76.jpg) | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: Re: mods & tips January 15th 2014, 10:20 am | |
| I took the pulley off and manually took the belt and put it in the "V" pocket. It didn't hug the belt on the sides, just on the inside flat part. | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 15th 2014, 10:22 am | |
| I know, that is the problem........... | |
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: Re: mods & tips January 15th 2014, 11:36 am | |
- I took the pulley off and manually took the belt and put it in the "V" pocket. It didn't hug the belt on the sides, just on the inside flat part.
5/8" belt ring a ding dong | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 15th 2014, 8:00 pm | |
| thanks for the responses' guys! | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: mods & tips January 30th 2014, 10:02 am | |
| if you do a pulley swap and you can't get the right belt, or you are to cheap to buy a new one, just use idier pulleys to put tension on the belt ![mods & tips Projec83](https://i.servimg.com/u/f56/18/62/03/97/projec83.jpg) I did this to my brother's white (MTD) yesterday to, got to post how I did that too. ![mods & tips Icon_razz](https://2img.net/i/fa/i/smiles/icon_razz.gif) | |
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: Re: mods & tips January 30th 2014, 2:02 pm | |
| when placing a double pulley clutch, try to get the flat pulley as close as possible to the trans pulley... more wrap around the pulley means less slippage. Be sure to place the clutch on the slack side of the belt. | |
![mods & tips Empty](https://2img.net/i/empty.gif) | Subject: Re: mods & tips May 14th 2014, 12:47 pm | |
| - Thunderdivine wrote:
5/8" belt ring a ding dong I was using a 5/8 belt! | |
| mods & tips | |
