| 1987 honda fourtrax foreman 4x4 | |
Speedfreek241 Member
Age : 26 Join date : 2013-07-12 Points : 4330 Posts : 137 Location : Loxahatchee
| Subject: 1987 honda fourtrax foreman 4x4 November 1st 2013, 11:53 pm | |
| Does anyone have a wiring diagram or know we're to find one because I can't find one. I need to know if they have a regulator on them because my bike doesn't and has no spark. By the way it's a trx350 model | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7319 Posts : 2914 Location : Ontario Canada
| Subject: Re: 1987 honda fourtrax foreman 4x4 November 2nd 2013, 1:02 pm | |
| I don't have a diagram, but I can tell you this- the regulator does not affect the ignition system. You could have a wiring fault, cooked CDI, bad plug, bad coil, bad trigger... Lots of possibilities.
Basics first. Try another spark plug. Disconnect the kill switch right from the CDI. After that, you're into testing... | |
Age : 28 Join date : 2013-04-10 Points : 5762 Posts : 1408 Location : Galway NY
| Subject: Re: 1987 honda fourtrax foreman 4x4 November 2nd 2013, 2:39 pm | |
| - Doc Sprocket wrote:
- I don't have a diagram, but I can tell you this- the regulator does not affect the ignition system. You could have a wiring fault, cooked CDI, bad plug, bad coil, bad trigger... Lots of possibilities.
Basics first. Try another spark plug. Disconnect the kill switch right from the CDI. After that, you're into testing... i got it for him doc. we did it in chat last night. i am a member on a honda forum where we have almost all honda manuals | |
| Subject: Re: 1987 honda fourtrax foreman 4x4 November 2nd 2013, 4:56 pm | |
| I have tried a new stator, coil and spark plug. I'm thinking that it may be all in the key switch because one day I was driving and shut it off and it never fired back up. Plus my key sometimes doesn't work. | |
| | | | Sponsored content
