 Heat my garage?
Craftsman Dude
TroyBilt Pony
9 posters
TroyBilt Pony
TroyBilt Pony
Heat my garage? Empty
PostSubject: Heat my garage?   Heat my garage? Icon_minitimeOctober 25th 2013, 9:45 pm
Hey guys, I got a detached 2 car garage I want to heat but have an issue. Its at my aunts and I can't run a wood burner due to not be able to exhaust it.. so what other options do i have? I want to keep it cheap as possible and safe. Thanks, TBP.
Craftsman Dude
Craftsman Dude
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 25th 2013, 11:17 pm
Propane heater should heat it quickly when you need it and wont have to worry about it any other time.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 26th 2013, 7:20 am
Or a forced air heater if you have the space.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 26th 2013, 7:57 am
You could use a kerosene heater like I do. The type in question burns very clean, and you need only to crack a window or door by an inch for adequate ventilation. They are radiant only (no fan) but you could use a pedestal or box fan nearby to circulate the heat.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 26th 2013, 9:09 am
I had a Kerosene torpedo style heater but my buddy bought it. I need to do this cheaply guys.. Very limited on cash atm due to purchasing my truck soon.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 26th 2013, 9:21 am
When you say "torpedo" do you mean the type that throws a big open flame? I don't suggest that type. I mean the catalytic type.
Budget is my middle name (my mom's to blame, LOL). When I decided I needed an alternate garage heating method (electrical is waaay too costly) I put out a CL ad. I traded a chainsaw I no longer needed for a kero heater.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeOctober 26th 2013, 12:19 pm
I need to heat my garage too, and i have a old Kerosene heater too, might use it. just use a fan to circulate the air? Hmm
Rocky Rhodes
Rocky Rhodes
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeDecember 30th 2013, 11:33 pm
I've been using several types in my shop. I like having several units to fire up and get the temps up quickly.
Propane Tank Top heater works well for when you're standing fairly close (within 6 feet max). I use a 20lb tank and it lasts about a month or more. I usually use this for a short time (30 minutes) on cold mornings.
Kerosene uprights - I use two. Spaced well apart from each other. I use these to quickly get the shop up to a comfortable temp. (I have an 8' flat ceiling) I don't leave them on for more than an hour at a time.
Electric space heaters: Again, I have a couple. Sometimes the temp in the shop fluctuates and these can help moderate the temps because all the non-electric heaters I use don't have adjustable thermostats. All electric heaters I've seen have adj. thermos.
And lastly... the centerpiece of my heat comes from a free standing wood burning fireplace. Probably the most economical for me as a woodworker since I burn all my scraps plus some split wood.
I remember using torpedo heaters burning kerosense and they always seemed to stink pretty badly. Maybe bad maintenance but my upright "K" heaters do a pretty good job when I just want to add some quick heat fast but for a short period. I wouldn't hesitate to run them 100% if I didn't have other options. Hope some of this is helpful.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeDecember 31st 2013, 6:32 am
Dont uprights use a wick, while FAs just burn it raw?
slim67
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeDecember 31st 2013, 9:51 am
I have a King 10Kw electric heater hanging from ceiling but when its really cold, I fire up my propane torpedo for a few minutes until its comfy then the electric maintains it from then on. Another factor to consider is insulation and ceiling height. I did my own blow in insulation and put a ceiling fan to keep pushing the warm air down. If it was me and without knowing anything about your garage i would get a propane torpedo and aim rear towards a window or crack open door.
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeDecember 31st 2013, 10:16 am
i have a big buddy heater in my shelterlogic garage in a box. it does OK, it can get it up to about 50 degrees F in the immediate area around it, plus it throws some kickass radiant heat. idk how it would do in a large area, you might be better off with a salamander. you can pick up a small LP one from TSC for 100 bucks. should be good for a garage, ive actually been thinking about grabbing one. http://www.tractorsupply.com/en/store/masterreg%3B-gas-forced-air-heater-60000-btu?cm_vc=-10005
Craftsman1998
Craftsman1998
PostSubject: Re: Heat my garage?   Heat my garage? Icon_minitimeDecember 31st 2013, 10:38 am
Use a kerosene Heater or a bullet heater. i use both a bullet heater is less efficient it smells more. a regular kerosene heater does not smell as much.
Heat my garage?
» Is it possible that the starter won't work because of the heat off the engine?
» Heat treating 101: The bake sale
» The LUV-bug is in the house(garage)
» Tools/Garage Stuff
» who has the biggest garage
