$45 for just the tire - i almost bot a pair up north for the agway - i was super pissed when the local one had a pair of atv tires mounted on rims for $65 on clearance each and someone else bot em.
Yeah mine was just the tires.
Age : 54 Join date : 2010-02-10 Points : 7078 Posts : 1726 Location : Florida, USA
Since this is a tire post - i thought of a couple ideas that might be useful.
For offroading- what about a hommade beadlock rim? Run some tubes and air em down when climbing/mudding for ultimate traction.
Probably be best to invest in a set of tubes actually anyway, sticks n stuff poking the tires - on the mod MTD i put tubes in the back tires just to seat the beads ( sidewalls bent in quite a bit ) .
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6378 Posts : 899 Location : PA pittsburgh and pymatuning
Youd only really need to do the rear tires ( if 2 wheel drive) - could probably get some metal cheep at a scrap yard or old car frame. Tubes would definitly help reguardless - get one of those small cheep 12 volt air compressors and use aligator clips on the battery to air em up for the ride home.
redzz02 Site VIP
