 what thing should be done
Jerbear0612
crazykid1994
tman9114100
9 posters
tman9114100
tman9114100
what thing should be done Empty
PostSubject: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 7:34 am
what thing should i do to my mower to make it offroad?
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 9:02 am
Find mower, remove deck, drive offroad.
tman9114100
tman9114100
PostSubject: thanks   what thing should be done Icon_minitimeAugust 23rd 2013, 9:06 am
i already have one, i was just wondering if there was anything that i dcould do to help it perform offroad
crazykid1994
crazykid1994
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 9:38 am
Pulley change. Better tires
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 10:25 am
The single best improvement to offroading capability is locking the rear axle.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Jerbear0612
Jerbear0612
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 11:44 am
like mentioned above, pulley swap, better tires, lock the rear end. Id say gas pedal and some skid plates couldn't hurt either
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 2:29 pm
And maybe a lift, snorkel, stack, winch, tow rope,
http://www.lastdropgarage.com
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 3:23 pm
Lock, aggressive tires, gas petal, bypass the safety sensors.
Murray modder
Murray modder
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 7:16 pm
This guys knows it!
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 7:32 pm
honestly single best mod would be put some quad tires on the back and larger front tires, then a pulley swap, and then lock the rear axle, but is not needed ive conquered many holes without one, gas pedals and stacks wont help you perform better, just makes it cooler and although the gas pedal is nice to have
redzz02
redzz02
also heavy springs on your clutch so the belt does not slip
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 8:35 pm
Actually the stack helps because mine likes to bog out when my pipe goes under but I'm in Florida with like 4 ft of water in one of my trails so depends if you have water or not
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 8:36 pm
And also helps if you stall under water to start it
redzz02
redzz02
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 9:28 pm
My stuff runs good and as long as you keep the tons a little she doesn't big down, but yes stacks are good for when your continuously in deep water but also makes you sick with the exhaust blowing in your face for too long
redzz02
redzz02
PostSubject: Re: what thing should be done   what thing should be done Icon_minitimeAugust 23rd 2013, 9:30 pm
Rpms up * not tons
» WheelHorse C-81 "Mud Pony"
» So, what should I do with this thing?
» 72 sears suburban
» This MTD 990 thing is becoming an addition.
» What Welder is the best for mower modding?
