 98 chevy tahoe transmission problems
crafsmankiller
98 chevy tahoe transmission problems Empty
PostSubject: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 8:53 pm
The transmission in my moms tahoe wont shift out of 2nd,or maybe third,idont know bout tue gearing, but it runs 4700 rpms at 60 mph. The fluid smells burned, it has 147000 miles on it. Anybody know what could be wrong? I really need some help
meigs man
meigs man
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 9:27 pm
sounds like the speed sensor or throttle position sensor one of the two.
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 9:42 pm
Try changing the fluid and filter how long since its been changed?
http://www.lastdropgarage.com
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 10:14 pm
Idk how long ago the filter change was. We bought it used at 130000 miles. What are tell-tale signs of a sensor going out?
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 11:11 pm
Then it probably needs serviced I've done this before and the fluid smelled burnt and it wasn't shifting right I did it and it fixes it so it may work I'd try it before spending $$$$$ on a rebuild
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 15th 2013, 11:58 pm
Ok ill relay the info. Thx for the help.
do you know how much fluid it needs?
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 9:22 am
Not sure you'd have to look that up
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 11:50 am
Ok ill do that. Could the overdrive belt be burned up? It jerks when you get on the gas from coasting.
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 12:02 pm
Have you Reyes taking it out of overdrive?
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 12:08 pm
Really sounds to me by the Rpms that your not getting out of second and it's probably blown unless its the filter and fluid
meigs man
meigs man
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 12:36 pm
Had a 98 chevy van the throttle position sensor went out it stayed in second gear would not go on up in to drive or over drive. And I had a 97 Buick that would not go into over drive that was speed sensor.
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 4:43 pm
Ill be sure to relay the info. Wheres the throttle sensor at.
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 4:48 pm
It shouldnt be blown tho, it's never slipped since weve had it.
meigs man
meigs man
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 4:52 pm
3in x 3in square box on the intake close to throttle cable.
meigs man
meigs man
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 4:54 pm
3in x 3in square box on the intake close to throttle cable. just google throttle position sensor and the year and type of car it will show it.
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 5:47 pm
It will go into drive right but won't shift up past 2nd right
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 10:10 pm
Ya thats whats happening. It seems to be stuck in 2nd.
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 16th 2013, 11:49 pm
Just try what I suggested If that doesn't work bring it to an tranny shop and if u want to test the speed sensor hook it up to a scanner
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 17th 2013, 4:47 pm
Thats what were planning on.
crafsmankiller
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 19th 2013, 5:03 pm
Soooo. We changed the trans oil and filter. It didnt help. It wont start moving till the revs get to 4000 and then it barely moves so the trans is completely
Shot. Were getting a 91 honda accord from my uncle.
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 19th 2013, 5:25 pm
You could try a junkyard trans if you know how to put a tranny in I know by me u can bring it back and get store credit it's like 150$
crazykid1994
crazykid1994
PostSubject: Re: 98 chevy tahoe transmission problems   98 chevy tahoe transmission problems Icon_minitimeAugust 19th 2013, 5:34 pm
could be a bad torque converter even
» peerless 739 transmission problems : advice needed
» 1995 chevy 1500
» '84 Chevy K10 Lifted Pickup
» ATLTF.COM Chevy Race Truck
» lifted craftsman
