 Need some help in diagnosing a runaway throttle issues on 20hp v-twin
MCRideout
9 posters
MCRideout
Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Empty
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 5th 2013, 9:51 pm
I should still open the case and check for damage right?
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 5th 2013, 10:17 pm
Probably wouldnt hurt. If you think its busted, you dont need stuff plugging your lube system.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 9:15 am
MCRideout wrote:
The governor is toast. Now it's time to crack open the case and replace it. If I plan on running a foot throttle should I still run a governor?
On my motor i didt run the gov and ran my throttal cabel straight to the butterfly on the carb and worked good for about 1-2 weeks but it did mess up the carb alot so i hooked the gov back up and ran great but i dont know if yours would do the same thing but it might.
Yeah i would crank it open and chek it out.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 4:03 pm
I only have to remove the engine from the frame, drain the oil and pop off the bottom cover right?
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 4:09 pm
Yeah i would think.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 4:20 pm
truckin42 wrote:
Yeah i would think.
What?
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 4:29 pm
Thunderdivine wrote:
truckin42 wrote:
Yeah i would think.
What?
Read the post befour mine.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 6:56 pm
Yes- crack it open. You do not want governor bits floating around in your sump. Drain the oil and yank that bottom cover. Be ready for the camshaft to fall out...
Also- if you are going to run the throttle straight to the carb, you need to set up a pedal stop so the cable doesn't yank too far/hard. Set the stop so that once the throttle plate gets to WOT, you cannot push the pedal any further. The throttle stop can be as simple as a bolt, placed in such a way as the pedal contacts the bolt head, and you can adjust it.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 8:59 pm
Thanks Doc,
I drained the oil and took the engine out tonight. I can't find any identification labels on the engine anywhere. Do you know where I could find this information? I'll need to order a new governor and a case gasket.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 9:04 pm
Should be on the tinwork somewhere, either stamped directly or onto a tag.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 9:07 pm
Look on the top of the valve cover the number will be stamed on the top of the valve cover and clean them real good so it easyer to see them.
Im positve the number are on the top of the valve covers.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 6th 2013, 9:27 pm
Got it! Thanks! You were right. I had to use steel wool on the valve cover to get the information. Now it's time to look up my parts and place the order.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 7th 2013, 6:53 am
Another case solved!
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 7th 2013, 12:15 pm
Glad i could help.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 14th 2013, 9:43 pm
These two videos say it all...
I took the engine apart and replaced the governor. I put everything back together and drove it around my yard. Two minutes later it failed again. I'm going to have to rip it apart AGAIN. Something must have failed other than the governor gear and counterweights.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 17th 2013, 7:44 am
This is a mystery to me now... The governor is fine.
https://www.youtube.com/watch?v=hn-L0Hq4C9I
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 18th 2013, 9:16 pm
Okay... when you say " it failed", could you be a bit more specific as to exactly what happened?
MowBandit
MowBandit
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 18th 2013, 9:24 pm
ok from that video it seems like something is getting stuck open if i was you i would check all of your linkage and make sure there free and not hitting anything and binding up have you adjusted the gov any?
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 18th 2013, 9:47 pm
Verify governor adjustment again. Procedure is as follows:
Loosen the pinch bolt that holds the governor arm to the governor shaft. Turn the arm until the throttle butterfly hits wide open throttle. Holding it there, now turn the shaft in the same direction till it stops. Holding both in place, retighten the pinch bolt.
Edit- sorry bout that. Was having a wireless signal issue, and couldn't view the video until now...
MowBandit
MowBandit
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 18th 2013, 9:52 pm
i agree with doc one this one check the gov then start it up and see how it runs im thinking that the owner before you was messing around with things he wasnt sopposed to lol
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 27th 2013, 10:48 pm
It's back together but I'm afraid something will go wrong again... I'll probably try to start it up and run it tomorrow night.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 28th 2013, 11:49 am
Ok let us know what happens.
MCRideout
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 28th 2013, 9:37 pm
I put it back together and took it for a spin and it seems to be holding!
I even tested it up a hill to load up the engine. The governor kept everything in check. I noticed the transmission was whining though up the hill, not sure what that's all about. I started mocking up the exhaust and I should have it finished by the end of the week.
Thanks for the help everyone! Let's keep our fingers crossed that thing thing holds out!
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 28th 2013, 9:50 pm
FAN-TASTIC! I'm VERY pleased that you've got it straightened out! Time to crack into that tranny... LOL- If it ain't one thing, it's the next.
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 28th 2013, 10:26 pm
maybe it needs more grease. im not shure, some trannys wine like that, if its not super loud, than it might be normal. sounds good, glad this project is coming along!
PostSubject: Re: Need some help in diagnosing a runaway throttle issues on 20hp v-twin   Need some help in diagnosing a runaway throttle issues on 20hp v-twin - Page 2 Icon_minitimeMay 29th 2013, 9:56 am
If its a hydro it will wine.
I know my hydro wines and also our John Deere x740 transaxle also wines.
» 125cc throttle issues
» 20hp opposed twin
» Gain 2hp more on your 14/16 and 18/20HP Vanguard V-Twin!
» 18 horse briggs v-twin full throttle surge
» Briggs Opposed twin Starter and Flywheel issues
