| 35speed beast MTD/Toro | |
+10redlinemotorsportts Doc Sprocket greener179 Thunderdivine Stretch44875 redneckcarrow WellThatsSurprising TheRainbowBoxer truckin42 LAWN MOWER MUDDER 14 posters |
Age : 23 Join date : 2013-04-08 Points : 5210 Posts : 913 Location : Central Pa
| Subject: 35speed beast MTD/Toro April 17th 2013, 7:58 am | |
| Hey guys I'm working on a 35 speed MTD lawn tractor and I just wanted to throw it out there so tell me what you guys what you think. Sorry if I don't get pics up cause I'm new to the fourm | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5504 Posts : 1070
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5702 Posts : 1091 Location : Galion, OH
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5008 Posts : 407 Location : East Bethel, MN
| Subject: Re: 35speed beast MTD/Toro April 17th 2013, 4:17 pm | |
| - TheRainbowBoxer wrote:
- 35 Mph? or 35 gears?
It's going to have 35 speeds. It will use a 7 spd vari drive from a mtd and a 5 spd pearless so it'll have 35 gears | |
| Subject: Re: 35speed beast MTD/Toro April 17th 2013, 4:20 pm | |
| - truckin42 wrote:
- Sounds cool iv never heard of a 35 speed lawn mower.
Check out the thread that Jamus put up ''Montgomery wards trail tractor now murray wide body Lt'' on the second page he mentioned it. | |
redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 5125 Posts : 30 Location : maine
| Subject: Re: 35speed beast MTD/Toro April 18th 2013, 7:19 am | |
| - redneckcarrow wrote:
- thinking of trying same thing but I have a 6 speed trans
Awesome then it'll be a 42 speed tractor!! | |
| Subject: Re: 35speed beast MTD/Toro April 18th 2013, 5:39 pm | |
| So a couple minutes ago I was trying to get the mtd running n driving to see if everything works before I put TOO much time into this build and I put it in gear so the input shaft on the trans-axle wouldn't turn when I put the pulley on but it turned any in forward and reverse so i dunno whats wrong but thank goodness I wasn't planning on using that tranny because I do not have another that works. | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5702 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: 35speed beast MTD/Toro April 18th 2013, 7:26 pm | |
| The vari drive is really a CVT tranny, with infinte ratios between the top ratio and bottom ratio. They just called it a 7 speed, because they had 7 postions.
So you have a zillion ratio tranny.... | |
| Subject: Re: 35speed beast MTD/Toro April 18th 2013, 8:12 pm | |
| - Stretch44875 wrote:
- The vari drive is really a CVT tranny, with infinte ratios between the top ratio and bottom ratio. They just called it a 7 speed, because they had 7 postions.
So you have a zillion ratio tranny.... COOL I never really thought of it that way, so does that mean that i can make it have more speeds? | |
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 7:30 am | |
| You could make it have any ratio, but only between the top and bottom ratio. So instead of 7 postions, you could have 3, or 12 postions. All in how you set up the shifter. It won't go any faster or slower than before. | |
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 6:07 pm | |
- You could make it have any ratio, but only between the top and bottom ratio. So instead of 7 postions, you could have 3, or 12 postions. All in how you set up the shifter. It won't go any faster or slower than before.
Ok that makes sense now!! | |
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 7:24 pm | |
| I have a question does anyone know how fast stock mtd vari drives go roughly?? | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6544 Posts : 2101 Location : Norway, Europe
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 7:44 pm | |
| Thanks for the speed info but what pulley ratio should I put on when I get the 5 spd in (hopefully this weekend) I'm thinking 1:1 but not sure if that'll mess up the double pulley drive. Tell me what you guys think. | |
greener179 Member
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 8:01 pm | |
| - greener179 wrote:
- 1:1 ratio will work good
Ok I just wasn't sure if it'd work with vari drive so THX!!! | |
| Subject: Re: 35speed beast MTD/Toro April 19th 2013, 9:33 pm | |
| Like I said hopefully this weekend I will get the mst-205 peerless out of my toro (or mst-206 out of another dynamark/murray) and swap it with the single speed in the mtd I will also try to get the 20hp briggs out of my parts tractor to replace the blown 18 in the mtd now. WISH ME LUCK!! | |
| Subject: Re: 35speed beast MTD/Toro May 26th 2013, 12:26 pm | |
| I am sorry for the lack of work....with school, boy scouts, and everything else I do I didn't have much time to work on this .....BUT I now have made good progress this morning. I have everything ready all I need to do is get a pulley preferably 5'' and it needs to be compatible for a 5/8'' belt, I dont think tsc is open today but if it is I will get a pulley and get everything lined up then I might put my trans-axle in depending on if we have enough time. Hopefully i will get pics in tonight or monday night. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7319 Posts : 2914 Location : Ontario Canada
| Subject: Re: 35speed beast MTD/Toro May 26th 2013, 6:20 pm | |
| You're 13, and doing this??? Right on! Kudos to you- I absolutely love seeing young'uns learning how to wrench- you're a dying breed. Seems most kids are just too wired in to the technocrap these days. | |
Age : 27 Join date : 2013-03-18 Points : 7484 Posts : 3131 Location : raleigh nc
| Subject: Re: 35speed beast MTD/Toro May 26th 2013, 8:58 pm | |
| - Doc Sprocket wrote:
- You're 13, and doing this??? Right on! Kudos to you- I absolutely love seeing young'uns learning how to wrench- you're a dying breed. Seems most kids are just too wired in to the technocrap these days.
Agreed, I think lol. Im the only one im my grade that can build something up by myself in my garage in my hole grade, its sad. | |
