 Heavy duty, hand made toolbox.
Heavy duty, hand made toolbox.  Empty
PostSubject: Heavy duty, hand made toolbox.    Heavy duty, hand made toolbox.  Icon_minitimeApril 15th 2013, 11:29 am
Here is a toolbox I made about 3 years ago. Outer metal is all 11 gauge, drawers are 14 or so. 3/8 plate for top/workbench area. Large vise. All welding, cutting bending, painting done by me. Weighs 880lbs, EMPTY. Probably close to a ton full. If you bend metal for a living, check out the double bend doors. Tricky to do, but cool.
Top locks when you shut the bottom doors. Side box locks from bottom doors also. Drawers just slid on angle iron, but slide easy when greased. Has lifting holes so I can load it with the crane. Hitch is from when I had it at work, used electric carts to tow it to the job. This thing is loaded with tools, need a little more room. Enough to work on just about anything.
Just thought I'd show off... LOL. I've seen some that make mine look sad, guys at work have used full bearing slides and such. I have a second one that is similar at work, not quite as nice.
Heavy duty, hand made toolbox.  2142_zps2345e360
Heavy duty, hand made toolbox.  2146_zpse7def028
Heavy duty, hand made toolbox.  Toolbox006_zps36ce1d10
Heavy duty, hand made toolbox.  2144_zpsf0f9f053
Heavy duty, hand made toolbox.  2143_zps070a7326
PostSubject: Re: Heavy duty, hand made toolbox.    Heavy duty, hand made toolbox.  Icon_minitimeApril 15th 2013, 11:34 am
Make me one, just not as heavy lol. Itll probably outlast any Snap-On box.
Now you need to make a frame for it with some big AT tires and a wider wheelbase to tow it on the trails, lol.
PostSubject: Re: Heavy duty, hand made toolbox.    Heavy duty, hand made toolbox.  Icon_minitimeApril 15th 2013, 11:49 am
Think I'm going to need a bigger tractor to tow this off road!
I tried to tow it once to my pole barn, from garage. Made it about 50 feet, then sunk. I don't even remember how it got out.
This box goes to Haspin every year with us.
PostSubject: Re: Heavy duty, hand made toolbox.    Heavy duty, hand made toolbox.  Icon_minitimeApril 17th 2013, 5:49 pm
Schweet bounce
» Project search: heavy duty body
» project GT Heavy
» Heavy Loads
» Been lurking awhile, first post with new project. Lifted Craftsman!
» Would a Sears Surburban be too heavy for a off-roader?
