I have been working with tractor since i can remember. Ive been tractor pulling for a few years and i kept on asking how fast does it go! it only went like 5 mph. So now i decided to make a racing tractor.
[img][/img] I started with a pos it didnt move didnt crank over didnt stear. IT DIDNT DO NOTHING!!! $30 you cant go wrong
[img][/img] Started taking it apart and getting rid of all the wires.
[img][/img] The oil was solid BLACK and slidgy. the whole combustion chamber was full of oil, gas and water.
[img][/img] Rear push bar.
[img][/img] Footrails and dual exhaust.
[img][/img] Brush guard.
[img][/img] Got a hood mounted.
[img][/img] Got a 6 speed spicer.
[img][/img] Got a set of fender mounted and want muddin!
[img][/img] Filled in holes in fenders and made a belt plate.
[img][/img] Remade the shifter.
[img][/img] Filled in the holes and made the dash fit the hood nicely and got all new wires, switches and indicator lights.
[img][/img] Mad wheelie bar and i just need to mount the wheels.
[img][/img] Took the muffler out and mad it a straight pipe dual exhaust.
[img][/img] got a bunch of parts powder coated.
[img][/img] putting it back together.
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7745 Posts : 3044 Location : Lebanon County, PA
[img][/img] the hood and grill is off a WHITE tractor
the footrails are off of a cow pusher off my friends pickup
[img][/img] [img][/img] ( that shifter in this pic i tryed and it worked but it was very sloppy and i couldnt get into 6th gear. ) i have a 5 1/2 inch engine drive pulley and a 3 inch rear end pulley the drive pully is nicley centered but it isnt completly flat so it has a slight wobble and i think im gonna try to put a bigger drive pulley like a 8 or 9. but then ill need to move the clutch because it almost hits the drive pulley
Ddwannabe Member
Age : 30 Join date : 2013-03-17 Points : 4305 Posts : 63 Location : Sheldon Iowa
ya i know! but the trany needs work now. and after im done with that im gonna get a bigger drive pulley and move the clutch. so hopefully it WILL RIP hardcore!
Ddwannabe Member
you may be jealous but i put ALOT of hours and $money$ into it. i have about $600 into it right now and im guessing it'll end up around $750 when im done.
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4560 Posts : 327 Location : Rindge, NH
that is a lot lol
Ddwannabe Member
that is a lot lol
ya! at first i thought it would only be around $250
Murray modder Member
Join date : 2012-11-23 Points : 4767 Posts : 356 Location : Somewher in Va
