| 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 | |
+45jsisti845 Angchor Moose DirtyD T-Dub13 Rkeefe99 Lawren Wimberly crafsmankiller donfordguy camomanusa 1997 Murray Jedi TroyBilt Pony mr.modified GenevaCustoms FOSWMT crazykid1994 matt-man (509)Mowers Stretch44875 k2500life dylansrockinrigs Marines2621 LAWN MOWER MUDDER motorizedeverything craftsmancole goesman WellThatsSurprising Doc Sprocket MowBandit Ddwannabe Kel TheRainbowBoxer greener179 redlinemotorsportts Murray modder mudmonkey06 Ariens YT11 truckin42 xxXMowerdudeXxx richie thomas Doug Chopperhed gearheadmike Thunderdivine 49 posters | |
Thunderdivine Veteran Member
| | | | motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4701 Posts : 356
| | | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| | | | Doc Sprocket Site VIP
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 7:47 pm | |
| That's insane... I LOVE it! What are you planning to do to deal with the sag in the chain? You don't want the chain particularly tight, but the sag could cause you to throw the chain. Maybe some idler wheels for support at the midpoint? Perhaps a spring loaded tensioner to help take up the slop without it actually being too tight? | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 7:53 pm | |
| - Doc Sprocket wrote:
- That's insane... I LOVE it! What are you planning to do to deal with the sag in the chain? You don't want the chain particularly tight, but the sag could cause you to throw the chain. Maybe some idler wheels for support at the midpoint? Perhaps a spring loaded tensioner to help take up the slop without it actually being too tight?
Yea, will give the chain all the slop it needs with a proper guide/ tensioner. Will build this into the chain guard wich will also house the nut cracker, short shifter. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 7:56 pm | |
| - motorizedeverything wrote:
- does the chain hit the shiftier
Yeah now, but nothing is bolted down, it will clear it, but the shifter axle will be cut down as well. I dont like those Square fasteners anyways, ill just use a setscrew type to lock an axle spacer on it. | |
| | | Guest Guest
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 7:57 pm | |
| You may have already addressed this but, what about your clutch? Given what I see, can I safely assume you intend to use a torque converter and/or centrifugal clutch mechanism? Really curious about this now, as my front engine snapper is getting resurrected and further modified in a similar fashion... |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 8:07 pm | |
| - prometheusEDI wrote:
- You may have already addressed this but, what about your clutch? Given what I see, can I safely assume you intend to use a torque converter and/or centrifugal clutch mechanism? Really curious about this now, as my front engine snapper is getting resurrected and further modified in a similar fashion...
Ya a heavy duty CVT made for big ATVs and heavy golf carts, not to be compared to the 40 models etc. A centrifugal clutch will never work, never seen one rated for 20hp + and those are really made as a momentary on-off switch, they burn easy. A CVT won't in the same manner. Tho heat is an issue also on a CVT. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 8:09 pm | |
And thanks, and you probably know what tensioner im planning to use, like on dirt bikes, they have a chain holder and also keeps the tension. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 8:21 pm | |
- Oh, I must have missed something. I thought you were getting one of those slick CVTech units outta Quebec... No?
Ya ordered one from UK, then went ages waiting for it. Then the seller told me he was out of stock and wanted to sell me a model 40. And never found any nee supplier for the CVTech, so ordered the Comet 780 from MFG instead. But if this works as planned I might, try again on a CVTech unit. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 8:24 pm | |
| The CVTech units are pretty bad@ss, but pricey as heck. I know the formula SAE guys use them and swear by them. I'd live one, but I think my wife would end up wearing my manly bits as earrings if I spent that much on a transmission. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 May 31st 2013, 8:30 pm | |
- The CVTech units are pretty bad@ss, but pricey as heck. I know the formula SAE guys use them and swear by them. I'd live one, but I think my wife would end up wearing my manly bits as earrings if I spent that much on a transmission.
Yea indeed they are, and haha | |
| | | | redlinemotorsportts Moderator
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 June 2nd 2013, 8:50 pm | |
- Thunderdivine wrote:
- redlinemotorsportts wrote:
- Is it going to be a nut shifter? (in-between the legs) lol
yea Well it looks like a good amount of sheetmetal work. I also like how clean your workspace is, I always make a mess. Yea its a ton of work, mostly designing it tho, building it is the easy part. And its clean cause its at my work garage. Its to clean tho meaning I need to spend time looking for the tools i need every time. When normally there is order in my mess in my garage. | |
| Who is online? | In total there are 74 users online :: 0 Registered, 0 Hidden and 74 Guests
