 Custom exhaust on Briggs I/C 16.5hp
jaymz_eric
Custom exhaust on Briggs I/C 16.5hp Empty
PostSubject: Custom exhaust on Briggs I/C 16.5hp   Custom exhaust on Briggs I/C 16.5hp Icon_minitimeJanuary 14th 2013, 9:36 pm
hey what kind of pipe and what diameter is used to make a exhuast stack on a briggs I/C 16.5hp single cylinder??? thanks guys!
PostSubject: Re: Custom exhaust on Briggs I/C 16.5hp   Custom exhaust on Briggs I/C 16.5hp Icon_minitimeJanuary 14th 2013, 11:08 pm
For pipe, you can use anything as long as its not plastic.
You will need to find the diameter yourself. To do that, you can look up parts for your model number, or take a tape measure (or analog/ digital caliper for better results) to find the inside diameter of the hole. I believe threading is fairly universal for exhaust.
If it a flange exhaust system, its a matter of either finding a flange that will fit your model or making one from scratch.
CornShuck4CE
CornShuck4CE
PostSubject: Re: Custom exhaust on Briggs I/C 16.5hp   Custom exhaust on Briggs I/C 16.5hp Icon_minitimeApril 8th 2014, 7:45 am
I used 1 inch steel hydraulic tubing. My brother ownes a hydralic store so i used his tube bender and made a custome exaust. Runs down under right foot board and turns out in front of the rear tire. If its an OHV motor its not threaded so you will have to make a flange or cut the old one off and weld it on. I used a 4 doller screw in muffler from TSC to quietner down some.
» New Custom Briggs Opposed Twin Exhaust?
» Custom dual exhaust on a Twin 16 Briggs & Stratton and some old build pics
» Exhaust/Stack Ideas
» V-Twin Briggs exhaust glowing red on one side
» Best exhaust for a Briggs Opposed twin? (Straightpipes)
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Exhaust-
