| Craftsman II with quad suspension | |
ThatTractorGuy New Member
boggo Member
Age : 29 Join date : 2010-08-22 Points : 5284 Posts : 64 Location : australia, victoria
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Craftsman II with quad suspension October 24th 2012, 12:45 am | |
| I'm doing the same thing except I built a complete custom frame rather than using the original quad and tractor frame. I wanted to keep the donor quad frame complete for sales purposes, and the tractor frame was too spindly. | |
| Subject: Re: Craftsman II with quad suspension October 24th 2012, 8:37 am | |
| - Chopperhed wrote:
- I'm doing the same thing except I built a complete custom frame rather than using the original quad and tractor frame. I wanted to keep the donor quad frame complete for sales purposes, and the tractor frame was too spindly.
Yeah i get exactly what you are saying. I just dont have the money or tools to do it that way. So far i have less than 100 into it and i dont even have a welder and grinder right now so Im not going to be so quick with updating progress. PS: i never did mention to everyone that its powered by a 20hp opposed .! | |
| Subject: Re: Craftsman II with quad suspension October 24th 2012, 2:15 pm | |
| Borrowing a welder for the next couple days so i cam get the front end and rear hubs welded all up. Its a gas welder so should have strong welds. I hope to have it rolling today. Stay tuned for updates.(: | |
greener179 Member
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5038 Posts : 306 Location : Silk Hope N.C.
| Subject: Re: Craftsman II with quad suspension October 24th 2012, 7:58 pm | |
| Yeah i do but im going to wait till its rideable atleast . Right now we are fabbing the rear hubs so stay tuned people. | |
| Subject: Re: Craftsman II with quad suspension October 25th 2012, 9:43 pm | |
| Well some major issues came up . In the process of welding stuff still. But right now nothing is gunna be gettin done for a good minute. IM NOT ABANDONING THE THREAD THOUGH.! | |
| Subject: Re: Craftsman II with quad suspension November 2nd 2012, 11:31 pm | |
| WELL. got the rear wheels all welded up. it totally will sit on its own now. However I need to grind and reweld some of the welds on the front end. I just wouldnt trust them going down a trail. I also need to keep an eye out for a rack and pinion. ANY ONE HAVE ANY IDEAS FOR STEERING??? KEEP IN MIND IM GOING TO TRY TO FIT A 20hp opposed in there too so itll be a squeze ANY SUGGESTIONS HELPFUL | |
| Subject: Re: Craftsman II with quad suspension November 4th 2012, 7:23 pm | |
| yeah Im up to the same spot on mine too, I'm thinking 3/4" shafts through pillow block bearings. it will take 2 shafts and at least 4 bearings to cover it. Since I'm using a warrioir front end I will use the stock warrior steering colum for the bottom. It fits the tie rod ends perfectly.
I helped a guy build a kit Shelby Cobra a couple years ago. It only had 1/2" steering shafts with a collapsible section. I figure 3/4" shafts with a steel wheel and a padded center should be fine.
| Subject: Re: Craftsman II with quad suspension November 10th 2012, 10:58 pm | |
| had horrible luck with this chassis. a could welds broke when i added weight to the front. so im just going to start fresh on another craftsman that I have. still going to be using the same tires/wheels and a-arms. going to try to snag a steering rack from my scrap yard too. I will update asap | |
