| Project INBRED ALLIS CHALMERS | |
+14truckin42 thatrandomguy Chopperhed matthew sidor MSteele323 CraftsmanKid1 CityRedneck W1ldyOvvnZ DICE464 F150F250F350 AcreFarm Jordan dangeroustoys56 muddstir 18 posters |
muddstir Member
Join date : 2012-01-22 Points : 5039 Posts : 318 Location : Western,PA
| Subject: Project INBRED ALLIS CHALMERS January 27th 2012, 10:58 pm | |
| Started this project around 4 to 5 years ago, then I bought a house an it went on hold. This fall I dug out all the parts for it and picked up where I left off. I don't have a lot of pics from then til now but ill try do put something together later on but for now here is what i'm working with. That's the body i'll be using, the motor was gone when i got it and the transaxle was locked up. I also scraped the frame and front end, I wanted a stronger set up in those areas. I'll have to take new pics of the frame i made this weekend my other pics are really blurry.
Last edited by muddstir on January 29th 2018, 8:56 pm; edited 2 times in total | |
Age : 54 Join date : 2010-02-10 Points : 7078 Posts : 1726 Location : Florida, USA
| Subject: Re: Project INBRED ALLIS CHALMERS January 28th 2012, 8:09 am | |
| Good project - Chunk did that with his offroader after the original pan chassis split - he used angle for a new frame . Whats the plans for it? Rock crawler, mudding, trailriding?
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS January 28th 2012, 1:12 pm | |
| It's more of a prototype for my next build. Around were I live truck mud bogging is huge and now they are starting to do atv bogging, so I want to make a lawn mower to enter in to the fun. This one is more of an all around mower not really for the deep mud. If every thing turns out ok I'll give it to the girlfriend and start the next one and if not then it's back to the drawing board. | |
| Subject: Re: Project INBRED ALLIS CHALMERS January 31st 2012, 6:36 am | |
| If anything, go with bigger tires with good tread- ATV or AG wheels - turf tires are basically near worthless in mud - if its for 'normal' type mud, the open trans should be fine.
Ive been wanting to experement with setting up a ' 4x4 tractor ' - mounting a trans under the front - best type of trans would be a noma rear steer - but ill have to make something up.
Just had too many other projects in the shed to work on my agway. | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS January 31st 2012, 2:02 pm | |
| I got the tires taken care of already. For rear tires I have 26x12x12 kenda bear claws sitting at the house. The front should be here today or tomarrow and they are 24x8x12 kenda bear claws. I wanted more of a difference in the tire sizes but thats the biggest and smallest the company had in that brand with a 12in rim. The tread looks meaty but not overkill like other mud atv tires, and their alot cheaper in the price factor too. 4 brand new alum rims, 4 brand new tires, mounted and shipped for $476 couldn't beat it in my book. | |
Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5357 Posts : 170 Location : Ontario Canada
| Subject: Re: Project INBRED ALLIS CHALMERS January 31st 2012, 6:23 pm | |
| i ran a locked rear axle with 25 12.5 12 bear claws like you have, best tires i have ever used. aggressive enough to get through anything but not too much so that it bogged my motor down | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS January 31st 2012, 7:45 pm | |
| - Jordan wrote:
- i ran a locked rear axle with 25 12.5 12 bear claws like you have, best tires i have ever used. aggressive enough to get through anything but not too much so that it bogged my motor down
It's good to hear you like this tires, I never ran them before so it was a shot in the dark when I ordered them. One question though how do they perform in the snow, the fluffy stuff and the hard packed stuff? | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS January 31st 2012, 8:07 pm | |
| Does anybody know about what year this body is from? I have no clue what year it was made. F150F250F350 has a Deutz-Allis in his big green beast monster mower build with the same body different color. I also seen some Simplicity's with the same body, and if memory recalls it correctly I think I've seen some Case's too. | |
Jordan Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 1st 2012, 11:18 am | |
| - muddstir wrote:
It's good to hear you like this tires, I never ran them before so it was a shot in the dark when I ordered them. One question though how do they perform in the snow, the fluffy stuff and the hard packed stuff? they worked pretty well, the problem i had was the stock front tires kept trying to sink in the softer snow so i drove it more on the plowed roads instead | |
| Subject: Re: Project INBRED ALLIS CHALMERS February 1st 2012, 5:25 pm | |
| I have a pair of smaller atv wheels ( came off a yamaha quad) for the front and and a pair of giant wooly booger atv wheels for the back - i cant complain on the price - $20 for the pair of front tires, $30 for the two 9" rims and $25 for the pair of wooly boogs - front atv wheels will come in handy for the 4x4 setup. | |
Jordan Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 1st 2012, 8:23 pm | |
| im actually starting a 4x4 lawn tractor soon shhhhh! lol front axle will be outta a 4 wheel steer noma i dont have a garage to work in, only a shed with my four wheeler in it and i hate working in the mud so thats why i havnt started yet...i have a frame front and rear axles motor, i dont think im missing anything to do it | |
| Subject: Re: Project INBRED ALLIS CHALMERS February 3rd 2012, 9:05 pm | |
| Best /easiest way to do a 4x4 conversion - it wont be a 'true' 4x4 unless the rear trans is locked - but the front cant be locked , other wise you cant steer.
This one guy made a center setup for the gear shifters , front and rear - a central stacked pulley could be used .
The plus's are either engaged or trans in neutral for 2 wheel drive - minus is the trans pulley would always be rotating in either setup unless some sort of lockout is made.
I havent touched my agway since last year - mainly cause my nephew is too busy hanging with his peeps , instead of his cool uncle - ill hopefully get it going later this year - need to get those wheels out of my shed. | |
Jordan Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 4th 2012, 6:38 pm | |
| i have it all ready to go the only problem i see is that the steering axle wont steer far enough to give me a decent turning radius, and the only thing i still need to figure out is how to run a belt to the font axle, i need to find a way to mount a second pulley onto the crank of an engine that way i have a stock belt and a short one going to the front....maybe ill take a shot at building a dual pulley at school? | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 4th 2012, 10:02 pm | |
| Around 5 years back I thought about doing a go-cart axle in the front to make one 4x4. It then got complicated with bearing, brackets, flanges, machine work, u-joints ect. It had a lot of downfalls, it was pricey to build, no suspension, and not sure it would steer correctly due to the geometry of how it was setup so i gave up on that system. | |
Jordan Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 4th 2012, 10:39 pm | |
| yeah i felt the same way, even with the steering 6 speed axle i have its still going to be a lot of work but im doing it because i got the tractor with a working tranny for 50 bucks so i think its worth a shot | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 4th 2012, 11:04 pm | |
| Here is how I made most of my frame-- It started out as a sheet of flat 11ga (.125 thick) metal, I sheared it into 5in strips(4pcs total) [img] [/img] Then I wrote a program for the punch machine and I ran the strips I sheared ( all the machine did was notch the corners for bending and put holes in it for mounting it together/bolting stuff to it.) [img] [/img] Then it went to the press brake to bend up all the side at 1in, this formed it into a channel that became my frame rails. [img] [/img] | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 4th 2012, 11:19 pm | |
| - Jordan wrote:
- yeah i felt the same way, even with the steering 6 speed axle i have its still going to be a lot of work but im doing it because i got the tractor with a working tranny for 50 bucks so i think its worth a shot
Give it a shot and if you get stuck with a issue let me know and I'll see if i can help you. I never did mess with one of those trannys but I'm pretty good at fab work and design. | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 5th 2012, 2:48 pm | |
| After the frame rails were bent I welded all the seams and bolted it together. I sled the body over the frame to make sure it fit then welded it all together. I then had to make it wider up in the engine bay, so I cut about a foot out of each side then welded it back on with about 2in offset on each side. Then I bent some angle up to patched some gaps and to make the lines of the frame flow better. Added a couple mounts for a jack shaft and called it good. (This was a bad pic- the frame blended in with the background- so I tried to make it better but computer was slow so I gave up.) Next weekend I'll try to get my rear and frontend mounts posted and that's about how far I'm on it. Oh yeah my rims and tire came in on Thursday so some day I'll try to get a pic of them up. [img] [/img] | |
Jordan Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 5th 2012, 4:20 pm | |
| - muddstir wrote:
Give it a shot and if you get stuck with a issue let me know and I'll see if i can help you. I never did mess with one of those trannys but I'm pretty good at fab work and design. i can see youre good at the fab work by your pictures you just posted, and if i have that problem itll definately end up on here because i want it to work lol i have a four wheeler thats 4 wheel drive but i wanna keep it in good shape because its worth a lot more then a lawn tractor and some of the work i use it for im not happy using it for because i know its hard on it but my other lawn tractors just cant do it | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4938 Posts : 208 Location : Tennessee
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 5th 2012, 11:13 pm | |
| - AcreFarm wrote:
- Great work so far. I'd love to have a shop equipped that well!
Thank you . The shop is were I work and the nice thing about the owners is as long as I do it on my own time I can use all the machines, welders, and tools plus I get metal real cheap. | |
AcreFarm Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 6th 2012, 1:24 pm | |
| I worked in a weld shop for a while that let us use the equipment on our time. We could buy new material at cost, and cut-downs at scrap price. Too bad Everything else about working there sucked LoL | |
muddstir Member
| Subject: Re: Project INBRED ALLIS CHALMERS February 10th 2012, 9:24 pm | |
| - dangeroustoys56 wrote:
- Thats the way to do it - custom one off frame. Nice fab work.
Thanks, But the pic is crappy it don't show all the flaws and gaps and stuff. For the amount of money I have into that frame (free) I can't complain, I just hope it's strong enough to hold up to the beating its going to get. | |
| Subject: Re: Project INBRED ALLIS CHALMERS February 13th 2012, 7:02 pm | |
| Hey, gotta be better then a factory setup - most tractors are just a steel pan and everythings bolted to it . Only thing ive seen close is the factory murray C channel frame under my late 90's machines. | |
