 dual battery set up on murray
5 posters
biscuit
biscuit
dual battery set up on murray Empty
PostSubject: dual battery set up on murray   dual battery set up on murray Icon_minitimeDecember 3rd 2011, 5:20 pm
I want to hook up a dual battery set-up on the murray. not for 24 volts, but for extra goodies like a radio and cell phone charger. Has anyone done this before? after stripping it down i have the room to stick another battery on her. i could always just run a power point to another battery, and just throw it on the battery tender at night. i am setting her up for ice fishing.
PostSubject: dual battery set up on murray   dual battery set up on murray Icon_minitimeDecember 3rd 2011, 8:39 pm
i would run a 650 car battery if you have room where the existing battery is. that will still run down but last longer than 2 mower batteries. you still might need to charge it on the down time unless you have a long drive back from the lake. just dont crank it too long if it doesnt want to start, thats a good way to mess up a starter. car batteries will crank longer and harder than mower batteries
biscuit
biscuit
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeDecember 3rd 2011, 8:48 pm
Well she runs fine. Cranks right up. Dp a car battery just might work. Thanks. Tried to post pics from phone, but had trouble
biscuit
biscuit
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeDecember 18th 2011, 6:26 pm
Well I managed to change my avatar pic its a 2002 Murray with a 12.5 b&s engine. Found a 197? Hood in my private lawnmower boneyard. Pulley swap (6" on rear and stock on front), 4rear wheels on it till I can get 4 tires from tsc. Velocity stack intake, carb off 2008 craftsman 17 HP, custom exhaust with Harley muffler, Harley tail light and truck horn.
dagr8tim
dagr8tim
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 5:30 pm
I've considered something like this. I've also considered the possibility of using an old car alternator run off the motor for charging/running accessories. Something like that and a car battery (even like a group 58 with 550 CCA's) would be great. I know the battery for my mower is 300 CCA.
http://buckeyejeeps.com
ferg
ferg
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 6:51 pm
I would recommend using an alternator from a small diesel engine from a boat, or a jet ski. you can get alternators that are about 40 amps
http://www.classicparts4cars.co.uk/mini-alternator---gxe2211-208-p.asp
it means that you have more power going to the wheels!!!!
and then you can have bigger lights ect. you should use a small battery from a small car (any petrol import Cool )
dagr8tim
dagr8tim
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 7:03 pm
That's a pretty cool idea. I wonder if you could mount it between the frame rails and use the pulley on the alternator as an idler.
ferg
ferg
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 7:10 pm
yeah I think that it would be best to have it high and dry. you could maybe use the top of the engine, (where the fly wheel guard is!! and fab a pulley to go on that. then mount the alternator near the back of the engine. make sure you make a thread if you do do it!!
dagr8tim
dagr8tim
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 7:12 pm
Maybe mount it in an ammo box with the pulley sticking out. I think that would be easier than trying to put it under the hood.
ferg
ferg
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 7:24 pm
No I think it would be best to have is at the top. there would also be some large gauge wiring and some relays to go with it .
the john deere 318 has a pto at each end of the engine, one for the deck and one for the drive. I think that it would definitely best the have it under the hood. you could proably make or get a pulley that will go into the fly wheel. also if it was an idler pulley there would be problems with the belt type. a fan belt that goes on an alternator is usually flat and you would have a lot of trouble getting everything to match up.
dagr8tim
dagr8tim
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeJanuary 1st 2012, 7:33 pm
True, it may be worth while to play with some ideas.
CornShuck4CE
CornShuck4CE
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeApril 10th 2014, 6:13 pm
Chevrolet one wire altanater is the most universal. But you could us a toyota altanater off like a 80s model 22R thay are v belt and pritty small ansd around 40 amps
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeApril 10th 2014, 6:55 pm
this hasnt been touched in 2 years... please do not dig up old "dead" and crusty threads, kinda pointless. thanks
dagr8tim
dagr8tim
PostSubject: Re: dual battery set up on murray   dual battery set up on murray Icon_minitimeApril 12th 2014, 10:26 pm
Be that as it may, the toyota alternator isn't a bad ideas.
Personally I'd just rather get a decent sized marine deep cycle battery and call it a day. If you placed the battery in the right place, you could add weight in a way to promote traction.
» Better dual battery setup
» Is it a good idea to switch the old battery for a car battery?
» Battery ah
» Dual Carbs
» Dual Carburetors?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: General Electrical Topics-
